Kyocera FS-6530MFP A3 Mono Laser Multifunction Printer
Quicklinx: C5YFWS00 Mfr#: 1102MW3NL1
Type: Printer / copier / scanner
Functionality: Scanner, Printer, Copier
Output Type: Monochrome
Wireless Capability: Wired
Technology: Laser
£1,767.86 ex VAT
£2,121.43 inc VAT
With Kyocera's unique ECOSYS technology, this multifunctional device has been designed for an increased operating life and advanced reliability whilst reducing environmental impact and cutting printing costs. it is a reliable partner for workgroups that require a high level of functionality, easily accessible by touch panel, and represents the smart choice for eco-friendly, cost-conscious offices.
  • PRESCRIBE IIe
    With the Kyocera page design and control language PRESCRIBE IIe, even complex graphics, logos and forms can be created independently on the system and saved and updated in the printer. Consequently, integration into print files no longer applies.
  • The KM NetViewer
    The KM NetViewer enables complete monitoring and control of all ECOSYS printers and digital Kyocera multifunction units and thus provides ideal network administration. It also supports the standardized SNMP protocol.
  • Command center RX
    The command center RX enables to control and manage various settings by accessing the device via web browser.
  • ECOSYS
    ECOSYS stands for ECOlogy, ECOnomy and system-printing. With their long-life components, ECOSYS devices are designed to maximize durability and minimize the total cost of ownership with regard to maintenance, administration and consumables. The cartridge-free system means that the toner has to be replaced regularly and the drum unit every 100,000 pages. The modular design concept allows you to add workflow enhancing functions as required.
Kyocera FS-6530MFP - multifunction printer - B/W
Multifunction printer
Printing Technology
Laser (monochrome)
Max Copying Speed
Up to 30 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 30 ppm
Max Printing Resolution
Up to 600 x 600 dpi
Scanning
600 x 600 dpi
Original Size
A3/Ledger (297 x 432 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
297 x 432 mm (max)
Media Type
Envelopes, plain paper
Standard Media Capacity
600 sheets
Max Media Capacity
1600 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
300 sheets
Automatic Duplexing
Yes (copying) Yes (printing)
Connection Availability
USB 2.0, Gigabit LAN, USB host
Office Machine Features
Print from USB flash drive, HyPAS (Hybrid Platform for Advanced Solutions), Kyocera ECOSYS Technology
AC 230 V (50/60Hz)
59 cm x 59 cm x 69.4 cm
70 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
2-year warranty (France - 1 year)
Printing Technology
Laser - monochrome
Standard Memory
1 GB
Max Supported Memory
2 GB
Supported Flash Memory
CompactFlash
Copying
Max Copying Speed
Up to 30 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Exposure Modes
Text, photo, text and photo
Automatic Duplexing
Copying Features
2 on 1, 4 on 1
Printing
Up to 600 x 600 dpi
Max Printing Speed
Up to 30 ppm
Printer Drivers / Emulations
PCL 6, KPDL3, PDF, XPS
Automatic Duplexing
First Print Out Time B/W
8 sec
Scanning
Optical Resolution
600 x 600 dpi
Grayscale Depth
8-bit
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Max Media Size
A3
Min Media Weight
45 g/m²
Max Media Weight
256 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), Folio (216 x 330 mm), 297 x 432 mm, 98 x 148 mm
600 sheets
Max Media Capacity
1600 sheets
100 sheets
300 sheets
Input tray - 500 sheets - A3 (297 x 420 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 100 sheets size: 90 x 148 mm - 297 x 432 mm weight: 45 g/m² - 256 g/m² , ADF - 50 sheets size: 140 x 182 mm - 297 x 432 mm weight: 45 g/m² - 160 g/m² , Output tray - 250 sheets , Job separator tray - 50 sheets
Speed Details
Copying: up to 30 ppm (A4) - B/W , Copying: up to 15 ppm (A3) - B/W , Scanning: up to 40 ipm (A4) - B/W , Scanning: up to 20 ipm (A4) - colour , Printing: up to 30 ppm (A4) - B/W , Printing: up to 15 ppm (A3) - B/W
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
SSL, IPsec
Operating System Support
UNIX, Linux, Apple MacOS X 10.4 or later, MS Windows
AC 230 V (50/60Hz)
560 Watt
Power Consumption Standby
114 Watt
Power Consumption Sleep
0.9 Watt
Warm-Up Time
20 sec
First Copy Out Time B/W
7.8 sec
Consumables Included
1 x toner cartridge (black) - up to 3000 pages
TUV GS, ISO 9001, ISO 14001
ENERGY STAR Certified
Blue Angel Compliant
Limited warranty - 2 years , France: limited warranty - 1 year
59 cm
59 cm
69.4 cm
70 kg
Sound Emission
27.1 dBA (idle) / 47.1 dBA (operating)
C5YF Kyocera pf-470 500 Sheet Drawer In Stock £399.65
Functionality: Printer
Functionality: Copier
Technology: Laser
Max Print Speed: 30ppm
Max Paper Size: 297 x 432 mm
Brand: Kyocera
Price Range Ex VAT: £1500+
