With Kyocera's unique ECOSYS technology, this multifunctional device has been designed for an increased operating life and advanced reliability whilst reducing environmental impact and cutting printing costs. it is a reliable partner for workgroups that require a high level of functionality, easily accessible by touch panel, and represents the smart choice for eco-friendly, cost-conscious offices.
                PRESCRIBE IIeWith the Kyocera page design and control language PRESCRIBE IIe, even complex graphics, logos and forms can be created independently on the system and saved and updated in the printer. Consequently, integration into print files no longer applies.
                The KM NetViewerThe KM NetViewer enables complete monitoring and control of all ECOSYS printers and digital Kyocera multifunction units and thus provides ideal network administration. It also supports the standardized SNMP protocol.
                Command center RXThe command center RX enables to control and manage various settings by accessing the device via web browser.
                ECOSYSECOSYS stands for ECOlogy, ECOnomy and system-printing. With their long-life components, ECOSYS devices are designed to maximize durability and minimize the total cost of ownership with regard to maintenance, administration and consumables. The cartridge-free system means that the toner has to be replaced regularly and the drum unit every 100,000 pages. The modular design concept allows you to add workflow enhancing functions as required.
- Kyocera FS-6530MFP - multifunction printer - B/W
- Multifunction printer
- Printing Technology
- Laser (monochrome)
- Max Copying Speed
- Up to 30 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 30 ppm
- Max Printing Resolution
- Scanning
- 600 x 600 dpi
- Original Size
- A3/Ledger (297 x 432 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 297 x 432 mm (max)
- Media Type
- Envelopes, plain paper
- Standard Media Capacity
- 600 sheets
- Max Media Capacity
- 1600 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 300 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- Office Machine Features
- Print from USB flash drive, HyPAS (Hybrid Platform for Advanced Solutions), Kyocera ECOSYS Technology
- Power
- AC 230 V (50/60Hz)
- 59 cm x 59 cm x 69.4 cm
- 70 kg
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- 2-year warranty (France - 1 year)
- Laser - monochrome
- Interface
- Standard Memory
- 1 GB
- Max Supported Memory
- 2 GB
- Supported Flash Memory
- CompactFlash
Copying
- Max Copying Speed
- Up to 30 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Exposure Modes
- Text, photo, text and photo
- Copying Features
- 2 on 1, 4 on 1
Printing
- Up to 30 ppm
- Printer Drivers / Emulations
- PCL 6, KPDL3, PDF, XPS
- First Print Out Time B/W
- 8 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
- Grayscale Depth
- 8-bit
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Max Media Size
- A3
- Min Media Weight
- 45 g/m²
- Max Media Weight
- 256 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), Folio (216 x 330 mm), 297 x 432 mm, 98 x 148 mm
- 600 sheets
- 1600 sheets
- 100 sheets
- 300 sheets
- Input tray - 500 sheets - A3 (297 x 420 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 100 sheets size: 90 x 148 mm - 297 x 432 mm weight: 45 g/m² - 256 g/m² , ADF - 50 sheets size: 140 x 182 mm - 297 x 432 mm weight: 45 g/m² - 160 g/m² , Output tray - 250 sheets , Job separator tray - 50 sheets
- Speed Details
- Copying: up to 30 ppm (A4) - B/W , Copying: up to 15 ppm (A3) - B/W , Scanning: up to 40 ipm (A4) - B/W , Scanning: up to 20 ipm (A4) - colour , Printing: up to 30 ppm (A4) - B/W , Printing: up to 15 ppm (A3) - B/W
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- SSL, IPsec
- Operating System Support
- UNIX, Linux, Apple MacOS X 10.4 or later, MS Windows
- Voltage Required
- 560 Watt
- Power Consumption Standby
- 114 Watt
- Power Consumption Sleep
- 0.9 Watt
- Warm-Up Time
- 20 sec
- First Copy Out Time B/W
- 7.8 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 3000 pages
- TUV GS, ISO 9001, ISO 14001
- ENERGY STAR Certified
- Blue Angel Compliant
- Limited warranty - 2 years , France: limited warranty - 1 year
- 59 cm
- 59 cm
- 69.4 cm
- 70 kg
- Sound Emission
- 27.1 dBA (idle) / 47.1 dBA (operating)
