This multifunctional device offers all the benefits of a professional document management solution for workgroups and small offices. Cost-efficient and Eco-friendly offices will appreciate Kyocera's unique ECOSYS technology which increases operating life, reduces environmental impact, cuts printing costs and ensures reliability.
- Kyocera FS-6525MFP - multifunction printer - B/W
- Multifunction printer
- Copier Type
- Digital
- Printing Technology
- Laser (monochrome)
- Max Copying Speed
- Up to 25 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 25 ppm
- Max Printing Resolution
- Scanning
- 600 dpi
- Original Size
- 140 x 182 mm (min) - A3/Ledger (297 x 432 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 98 x 148 mm (min) - A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm) (max)
- Media Type
- Envelopes, plain paper
- Standard Media Capacity
- 600 sheets
- Max Media Capacity
- 1600 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 300 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- Office Machine Features
- Save to USB flash drive, scan to e-mail, scan to network
- Power
- AC 230 V (50/60Hz)
- 59 cm x 59 cm x 69.4 cm
- 52.2 kg
- Environmental Standards
- ENERGY STAR Qualified
- 2-year warranty (France - 1 year)
- Copier Type
- Digital
- Laser - monochrome
- Interface
- Standard Memory
- 1 GB 1 GB
- Max Supported Memory
- 2 GB 2 GB
- Supported Flash Memory
- CompactFlash
Copying
- Max Copying Speed
- Up to 25 ppm
- Grayscale Half-Tones
- 256
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Exposure Modes
- Text, photo, text and photo
- Copying Features
- 2 on 1, 4 on 1
Printing
- Up to 25 ppm
- Printer Drivers / Emulations
- PCL 6, PostScript 3, KPDL3, PDF, XPS
- First Print Out Time B/W
- 8 sec
Scanning
- Optical Resolution
- 600 dpi
- Grayscale Depth
- 8-bit
Document & Media Handling
- Min Original Size
- 140 x 182 mm
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 98 x 148 mm
- Max Media Size
- A3/Ledger
- Min Media Weight
- 45 g/m²
- Max Media Weight
- 256 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), 297 x 432 mm, 140 x 182 mm, 98 x 148 mm
- 600 sheets
- 1600 sheets
- 100 sheets
- 300 sheets
- Input tray - 500 sheets - A3 (297 x 420 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 100 sheets size: 98 x 148 mm - A3/Ledger (297 x 432 mm) weight: 45 g/m² - 256 g/m² , ADF - 50 sheets size: 140 x 182 mm - A3/Ledger (297 x 432 mm) weight: 45 g/m² - 160 g/m² , Output tray - 250 sheets , Job separator tray - 50 sheets
- Speed Details
- Printing: up to 25 ppm (A4) - B/W , Printing: up to 12 ppm (A3) - B/W , Copying: up to 25 ppm (A4) - B/W , Copying: up to 12 ppm (A3) - B/W , Scanning: up to 40 ipm (A4) - B/W , Scanning: up to 20 ipm (A4) - colour
- 1 x USB 2.0 , 1 x USB host , 1 x Gigabit LAN
- Network Protocols
- TCP/IP, IPX/SPX, AppleTalk, NetBEUI, HTTPS, IPv4, IPv6
- Kerberos, SSL, IPsec, 802.1x
- Operating System Support
- UNIX, Linux, Apple MacOS X 10.4 or later, MS Windows
- Voltage Required
- 530 Watt
- Power Consumption Standby
- 114 Watt
- Power Consumption Sleep
- 0.9 Watt
- Warm-Up Time
- 20 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 3000 pages
- TUV, ISO 9001, GS, ISO 14001
- ENERGY STAR Certified
- Limited warranty - 2 years , France: limited warranty - 1 year
- 59 cm
- 59 cm
- 69.4 cm
- 52.2 kg
- Sound Emission
- 27.1 dBA (idle) / 46.8 dBA (operating)
