Kyocera FS-1325MFP A4 Mono Laser Multifunction Printer
Quicklinx: C5YJWS00 Mfr#: 1102M73NLV
Functionality: Copier, Fax, Printer, Scanner
Output Type: Monochrome
Wireless Capability: Wired
Technology: Laser
£246.21 ex VAT
£295.45 inc VAT
Duplex printing, network connectivity and fax features allow the Kyocera FS-1325MFP to meet the demands of small offices and workgroups. With print speeds of 25 ppm in B/W and toner yields of 2100 pages this multifunctional easily scales up to handle bigger workloads. Its long life components significantly reduce running costs and environmental impact.
Kyocera FS-1325MFP - multifunction printer - B/W
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 25 ppm
Max Printing Resolution
Up to 1800 x 600 dpi
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR
Scanning
600 dpi
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
40 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper
Standard Media Capacity
250 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
100 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, LAN
AC 230 V (50/60Hz)
39 cm x 36.1 cm x 36.2 cm
10.1 kg
1-year warranty
Fax Type
Plain paper
Printing Technology
Laser - monochrome
Display
2 lines x 16 characters
USB 2.0, LAN
Standard Memory
64 MB
Copying
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Exposure Modes
Text, photo, text and photo
Copying Features
2 on 1, 4 on 1, ID Card Copy
Printing
Max Printing Speed
Up to 25 ppm
Printer Drivers / Emulations
Windows GDI driver
Automatic Duplexing
First Print Out Time B/W
7.5 sec
Scanning
Optical Resolution
600 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR
Document & Media Handling
Max Original Size
Original Type
Sheets
40 sheets
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Plain paper
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
250 sheets
1 sheet
100 sheets
Input tray - 250 sheets size: 70 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , ADF - 40 sheets - 216 x 356 mm , Output tray - 100 sheets , Bypass tray - 1 sheet size: 70 x 148 mm - 216 x 356 mm weight: 60 g/m² - 220 g/m²
Speed Details
Printing: up to 25 ppm (A4) - B/W , Scanning: up to 18 ipm (A4) - B/W
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Operating System Support
MS Windows XP, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, Windows 8
AC 230 V (50/60Hz)
355 Watt
Power Consumption Standby
8 Watt
Power Consumption Sleep
4 Watt
Warm-Up Time
28 sec
First Copy Out Time B/W
13 sec
TUV GS
Limited warranty - 1 year - carry-in
39 cm
36.1 cm
36.2 cm
10.1 kg
C5YJ Kyocera TK-1125 Black Toner Cartridge 2.1k Yield In Stock £46.73
Functionality: Fax
Functionality: Printer
Functionality: Scanner
Technology: Laser
Max Print Speed: 25ppm
Max Paper Size: A4 (210 x 297 mm)
Brand: Kyocera
