The FS-1320MFP is designed for easy operation, low noise and compact size. It focus on essential functionalities, including print, copy, scan and fax capabilities as standard, which makes them ideally suited for personal, home office and small business users.
The Kyocera NetViewer
The Kyocera NetViewer enables complete monitoring and control of all ECOSYS printers and digital Kyocera multifunction units from any Windows PC and thus provides ideal network administration. It also supports the standardized SNMP protocol. -
Status monitor and command center
The status monitor shows the current printers condition and gives direct access to the command center for the modification of settings that are not contained in the drivers.
- Kyocera FS-1320MFP - multifunction printer - B/W
- Multifunction printer
- Copier Type
- Digital
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 10000 impressions
- Recommended Monthly Volume
- 1500 pages
- Max Copying Speed
- Up to 20 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 20 ppm
- Max Printing Resolution
- Up to 1800 x 600 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Data Compression System
- MH, MR, MMR
- Scanning
- 600 x 600 dpi
- Original Size
- 140 x 210 mm (min) - 216 x 356 mm (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 40 sheets
- Media Size
- 70 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Plain paper
- Standard Media Capacity
- 250 sheets
- Output Trays Capacity
- 100 sheets
- Connection Availability
- Interface
- USB 2.0
- Office Machine Features
- Scan to e-mail, scan to folder
- Power
- AC 230 V (50/60Hz)
- 39 cm x 36.1 cm x 36.2 cm
- 9.7 kg
- Environmental Standards
- ENERGY STAR Qualified
- Copier Type
- Digital
- Fax Type
- Plain paper
- Laser - monochrome
- 10000 impressions
- 1500 pages
- Interface
- USB 2.0
- Standard Memory
- 64 MB 64 MB
Copying
- Max Copying Speed
- Up to 20 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- 2 on 1, 4 on 1
Printing
- Up to 20 ppm
- Image Enhancement Technology
- 1200 IQ
- First Print Out Time B/W
- 8.5 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- MH, MR, MMR
- Reception Memory Capacity
- Up to 150 pages
- PC Faxing
Document & Media Handling
- Min Original Size
- 140 x 210 mm
- Max Original Size
- 216 x 356 mm
- Original Type
- Sheets
- 40 sheets
- Min Media Size
- 70 x 148 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Plain paper
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
- 250 sheets
- 100 sheets
- Input tray - 250 sheets size: 140 x 210 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , ADF - 40 sheets size: 140 x 210 mm - 216 x 356 mm weight: 60 g/m² - 105 g/m² , Output tray - 100 sheets
- Speed Details
- Printing: up to 20 ppm (A4) - B/W , Copying: up to 20 ppm (A4) - B/W , Scanning: up to 18 ppm (A4) - B/W , Scanning: up to 6 ppm (A4) - colour
- 1 x USB 2.0 - 4 pin USB Type B
- Operating System Support
- MS Windows XP, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.5 or later, Windows 8
- Voltage Required
- 307 Watt
- Power Consumption Standby
- 7 Watt
- Power Consumption Sleep
- 3 Watt
- Warm-Up Time
- 28 sec
- First Copy Out Time B/W
- 14 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 700 pages
- TUV, GS
- ENERGY STAR Certified
- 39 cm
- 36.1 cm
- 36.2 cm
- 9.7 kg
- Sound Emission
- 28 dBA (idle) / 50 dBA (operating)
