Kyocera FS-1061DN Mono Laser Printer
Quicklinx: 976MWS00 Mfr#: 1102M33NLV
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: Wired
Technology: Laser
£164.68 ex VAT
£197.61 inc VAT
Compact, efficient and highly economical, the FS-1061DN is the ideal printer for your desktop with a Quiet Mode button that significantly reduces noise. The standard duplex print capability and network interface make it perfect for a compact office or small workgroup. Robust and reliable, with KYOCERA's hard-wearing components, it is a hasslefree printer you can depend on.
  • Efficient printing speed
    With a maximum printing speed of 25 pages per minute (ppm) for black and white documents, this printer ensures your work is completed quickly and efficiently.
  • High-resolution output
    Achieve sharp, clear prints with a maximum resolution of 1800 x 600 DPI, perfect for producing professional-quality documents.
  • Eco-friendly design
    ENERGY STAR certification signifies this printer's commitment to reducing environmental impact through energy efficiency.
  • Versatile media handling
    Supports a wide range of media sizes from A6 to Legal, and weights from 60 g/m2 to 220 g/m2, accommodating various printing needs.
  • Convenient automatic duplexing
    Automatic duplexing allows for easy two-sided printing, helping to save paper and create professional-looking documents.
Kyocera FS-1061DN - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
6.7 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
70 mm x 148 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 25 ppm - B/W - A4 (210 x 297 mm)
Max Resolution (B&W)
1800 x 600 dpi
Automatic Duplexing
USB 2.0, LAN
ARM 390 MHz
RAM Installed (Max)
32 MB
Media Type
Plain paper
Total Media Capacity
250 sheets
Media Handling
250-sheet input tray, 1-sheet manual tray
Monthly Duty Cycle (max)
15000 pages
Print server
Printer Features
Kyocera ECOSYS Technology
Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Windows 8
35.8 cm x 27.6 cm x 24.1 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Wired
USB 2.0, LAN
1800 x 600 dpi
Automatic Duplexing
First Print Out Time B/W
7.5 sec
Printer Features
Media Handling
ARM 390 MHz
RAM
RAM Installed (Max)
32 MB
Media Handling
Media Type
Plain paper
Media Size Class
A4/Legal
Max Media Size
70 mm x 148 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
Media Weight
60 g/m² - 220 g/m²
250 sheets
Media Feeders
1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x manual - 1 sheet - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²
Output Trays Capacity
150 sheets
Duty Cycle
15000 pages
Print server
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 1000 pages ISO/IEC 19752
TUV GS
Power supply - internal
Frequency Required
50/60 Hz
346 Watt
Power Consumption Stand by
6 Watt
Power Consumption Sleep
3 Watt
Environmental Standards
Blue Angel
ENERGY STAR
Sound Emission (Idle)
29 dBA
Sound Emission (Operating)
51.2 dBA
Sound Emission (Quiet Mode)
49.6 dBA
35.8 cm
27.6 cm
24.1 cm
6.7 kg
976M Kyocera TK-1125 Black Toner Cartridge 2.1k Yield In Stock £46.73
Type: Printer
Technology: Laser
Max Print Speed: [N/A]
Max Paper Size: A4 (210 x 297 mm)
Brand: Kyocera
