Kyocera Fax interface card. 33.6 Kbps - for Kyocera FS-6025, FS-6030, FS-6525 and FS-6530.
Efficient connectivity
The Kyocera Fax System (U) is designed with wired connectivity technology, ensuring reliable and stable connections for all your fax needs. Its plug-in module form factor makes it an easy addition to any PC setup, providing seamless integration for internal use. -
High-speed transmission
Boasting a max fax transfer rate of 33.6 Kbps, this fax interface card offers quick and efficient document transmission. This speed ensures that your communications are both timely and effective, reducing wait times and increasing productivity.
- Kyocera Fax System (U) - fax interface card
- Fax interface card
- Form Factor
- Internal
- Max Transfer Rate
- 33.6 Kbps
- Max Fax Transfer Rate
- 33.6 Kbps
- Data Compression Protocol
- MH, MMR, MR, JBIG
- Designed For
- Kyocera FS-6025MFP, FS-6025MFP/Base, FS-6025MFP/FAX, FS-6025MFP/KL3, FS-6025MFP/KL3FAX, FS-6030MFP, FS-6030MFP/FAX, FS-6030MFP/KL3, FS-6030MFP/KL3FAX, FS-6525MFP/KL3, FS-6525MFP/KL3FAX, FS-6530MFP, FS-6530MFP/KL3, FS-6530MFP/KL3FAX
- Form Factor
- Internal
Modem
- Connectivity Technology
- Wired
- Memory
- 12 MB
- Max Transfer Rate
- 33.6 Kbps
- MH, MMR, MR, JBIG
- 33.6 Kbps
- Compatible Slots
- 1 x Expansion Slot
- Designed For
