Kyocera Fax System
Kyocera Fax System
Quicklinx: B4Z5WS00 Mfr#: 1505JR3NL0
Compatibility: PC
Type: None
£248.47 ex VAT
£298.16 inc VAT
Kyocera Fax interface card. 33.6 Kbps - for Kyocera FS-6025, FS-6030, FS-6525 and FS-6530.
  • Efficient connectivity
    The Kyocera Fax System (U) is designed with wired connectivity technology, ensuring reliable and stable connections for all your fax needs. Its plug-in module form factor makes it an easy addition to any PC setup, providing seamless integration for internal use.
  • High-speed transmission
    Boasting a max fax transfer rate of 33.6 Kbps, this fax interface card offers quick and efficient document transmission. This speed ensures that your communications are both timely and effective, reducing wait times and increasing productivity.
Kyocera Fax System (U) - fax interface card
Fax interface card
Internal
Max Transfer Rate
33.6 Kbps
Max Fax Transfer Rate
33.6 Kbps
Data Compression Protocol
MH, MMR, MR, JBIG
Kyocera FS-6025MFP, FS-6025MFP/Base, FS-6025MFP/FAX, FS-6025MFP/KL3, FS-6025MFP/KL3FAX, FS-6030MFP, FS-6030MFP/FAX, FS-6030MFP/KL3, FS-6030MFP/KL3FAX, FS-6525MFP/KL3, FS-6525MFP/KL3FAX, FS-6530MFP, FS-6530MFP/KL3, FS-6530MFP/KL3FAX
Fax interface card
Internal
Modem
Wired
12 MB
Max Transfer Rate
33.6 Kbps
MH, MMR, MR, JBIG
33.6 Kbps
Compatible Slots
1 x Expansion Slot
Compatibility: PC
Type: None
Brand: Kyocera
