Kyocera ECOSYS PA5500X A4 Mono Laser Printer
Quicklinx: H46XWS00 Mfr#: 110C0W3NL0
Type: Printer
Functionality: Printer
Wireless Capability: Wired
Max Paper Size: A4 (210 x 297 mm), Legal (216 x 356 mm)
Hurry, only 2 left in stock!
£768.79 ex VAT
£922.54 inc VAT
The flexible paper handling options with up to 2,600 sheets and modern security features, combined with long-life components provides exceptional eflffciency and reliability make the ECOSYS PA5500x the ideal choice to increase overall performance of workgroups. With a print speed of up 55 pages per minute and a fast first print out, it's always ready when you need it.
  • Efficient media handling
    Designed to accommodate a variety of media sizes including A4, A5, and B5, the Kyocera ECOSYS PA5500X ensures versatile document handling capabilities. Its max media capacity of 2600 sheets and output trays capacity of 500 sheets make it ideal for high-volume printing needs.
  • High-speed performance
    With a robust printing speed of up to 55 pages per minute and automatic duplexing, this printer is engineered for efficiency and productivity. The high clock speed of 1.4 GHz by the ARM A53 processor further enhances its performance, ensuring tasks are completed swiftly.
  • Superior print quality
    Achieve professional-grade monochrome printing with a maximum resolution of 1200 x 1200 DPI. Whether printing simple text documents or detailed graphics, the Kyocera ECOSYS PA5500X delivers sharp, clear output every time.
Kyocera ECOSYS PA5500X - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
16.1 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
70 mm x 148 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 55 ppm - B/W - A4 (210 x 297 mm) , Up to 39 ppm - B/W duplex - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
ARM A53 1.4 GHz
RAM Installed (Max)
512 MB (2.5 GB)
Card Reader
Language Simulation
PCL 5E, PCL 6, PCL XL, KPDL3, IBM ProPrinter, XPS, EPSON LQ 850, TIFF, PCLm, URF, PWG, JPEG, PDF Direct, PPML
Media Type
Plain paper
Total Media Capacity
600 sheets
Media Handling
500-sheet paper cassette, 100-sheet multipurpose tray
Monthly Duty Cycle (max)
250000 pages
Recommended Monthly Volume
27500 pages
Print server
Printer Features
PDF direct print, Internet printing, E-mail printing, WSD print, secure printing IPP over TLS, local and network authentication, trusted platform module, secure boot, run time integrity check
AC 220-240 V
UNIX, Linux, Microsoft Windows, Google Chrome OS, Apple MacOS X 10.9 or later
1-year warranty
38 cm x 41 cm x 32 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Built-in Devices
LCD display
Wired
AirPrint Enabled
1200 x 1200 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
4.5 sec
Language Simulation
Fonts Included
93 x outline , 4 x calibri , 4 x cambria , 1 x bitmapped , 45 x barcode
Printer Features
Media Handling
ARM A53 1.4 GHz
RAM
RAM Installed (Max)
512 MB / 2.5 GB (max)
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card, SDHC Memory Card
Media Handling
Media Type
Plain paper
Media Size Class
A4/Legal
Max Media Size
70 mm x 148 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Folio (216 x 330 mm)
Media Weight
60 g/m² - 220 g/m²
600 sheets
Media Feeders
Multi-purpose tray: 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Paper cassette: 1 x automatic - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²
Max Media Capacity
2600 sheets
Output Trays Capacity
500 sheets
Duty Cycle
250000 pages
27500 pages
Print server
Security Protocols & Features
LDAP, TLS, IPsec, SNMP 3, SMTP
Expansion Slots
2 x expansion slot
1 x USB 2.0 , 2 x USB host , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 10000 pages ISO/IEC 19752 - Kyocera TK-3430 Starter
ISO 9001, GS, ISO 14001, ISO 7779, TÜV safety certification
Power supply
AC 220-240 V
Frequency Required
50/60 Hz
676.1 Watt
Power Consumption Sleep
0.5 Watt
Limited warranty - 1 year
10 °C
32.5 °C
15 - 80%
Sound Emission (Operating)
56 dBA
38 cm
41 cm
32 cm
16.1 kg
Width (Shipping)
54.9 cm
Depth (Shipping)
49.4 cm
Height (Shipping)
43.8 cm
Weight (Shipping)
20 kg
Type: Printer
Brand: Kyocera
Price Range Ex VAT: £750 - £1000
