The high performance of the ECOSYS PA5000x, paired with optimal data protection solutions, make this the perfect fi t for small and mid-sized workgroups. With up to 50 pages per minute in excellent 1,200 dpi resolution and fast time to fi rst print of only 5.4 seconds, this ECOSYS combines high productivity with cost savings.
Efficient printing speed
With a maximum printing speed of 50 pages per minute for monochrome documents, the Kyocera ECOSYS PA5000X ensures your work is completed quickly and efficiently, making it suitable for high-demand environments. -
High-resolution output
Achieve crisp and clear text with a maximum resolution of 1200 x 1200 DPI. This high-resolution output ensures that every print is of high quality, suitable for professional documents. -
Advanced connectivity options
Equipped with Gigabit Ethernet, USB 2.0, and wireless direct printing capabilities, this printer offers versatile connectivity options to easily integrate into your existing network and support multiple users. -
Eco-friendly design
The Kyocera ECOSYS PA5000X is designed with sustainability in mind, featuring a low power consumption sleep mode of only 0.5 watts, reducing your office's carbon footprint and operational costs. -
Robust security features
With features like secure boot, run time integrity check, and secure printing IPP over TLS, this printer ensures that your sensitive documents remain confidential, making it ideal for businesses that prioritize security.
 - Kyocera ECOSYS PA5000X - printer - B/W - laser
- Printer Type
 - Workgroup printer - laser - B/W
 - 16.1 kg
- Media Size Class
 - A4/Legal
- Max Media Size
 - Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
 - 70 mm x 148 mm
- Max Media Size (Custom)
 - 216 mm x 356 mm
- Print Speed
 - Up to 50 ppm - B/W - A4 (210 x 297 mm) , Up to 35.5 ppm - B/W duplex - A4 (210 x 297 mm)
- Max Resolution (B&W)
 - 1200 x 1200 dpi
- Automatic Duplexing
- Interface
 - USB 2.0, Gigabit LAN, USB host
- AirPrint Enabled
- Processor
 - ARM A53 1.4 GHz
- RAM Installed (Max)
 - 512 MB (2.5 GB)
- Card Reader
- Language Simulation
 - PCL 6, PCL 5E, PCL XL, KPDL3, PDF Direct, XPS, PPML, TIFF, JPEG, URF, PWG, PCLm, IBM ProPrinter, EPSON LQ 850
- Media Type
 - Plain paper
- Total Media Capacity
 - 600 sheets
- Media Handling
 - 100-sheet multipurpose tray, 500-sheet paper cassette
- Monthly Duty Cycle (max)
 - 200000 pages
- Recommended Monthly Volume
 - 25000 pages
- Networking
 - Print server
- Printer Features
 - PDF direct print, Internet printing, E-mail printing, WSD print, secure printing IPP over TLS, local and network authentication, trusted platform module, secure boot, run time integrity check
- Power
 - AC 220-240 V
- System Requirements
 - Microsoft Windows, Apple MacOS X 10.9 or later, Google Chrome OS, Linux, UNIX
 - 1-year warranty
 - 38 cm x 41 cm x 32 cm
- Printer Type
 - Workgroup printer - laser - monochrome
Printer
- Print Speed
- Built-in Devices
 - LCD display
- Connectivity Technology
 - Wired
- Interface
- AirPrint Enabled
 - 1200 x 1200 dpi
- PostScript Support
 - Standard
- First Print Out Time B/W
 - 5.4 sec
- Fonts Included
 - 93 x outline , 4 x calibri , 4 x cambria , 1 x bitmapped , 45 x barcode
- Printer Features
- Media Handling
- Processor
 - ARM A53 1.4 GHz
RAM
 - 512 MB / 2.5 GB (max)
Card Reader
 - Card reader
- Supported Flash Memory Cards
 - SD Memory Card, SDHC Memory Card
Media Handling
- Media Type
 - Plain paper
- Media Size Class
 - A4/Legal
- Max Media Size
 - 70 mm x 148 mm
 - 216 mm x 356 mm
- Media Sizes
 - ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Folio (216 x 330 mm)
- Media Weight
 - 60 g/m² - 220 g/m²
 - 600 sheets
- Media Feeders
 - Multi-purpose tray: 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Paper cassette: 1 x automatic - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²
- Max Media Capacity
 - 2600 sheets
- Output Trays Capacity
 - 500 sheets
Duty Cycle
 - 200000 pages
 - 25000 pages
- Networking
 - Print server
 - TLS, IPsec, LDAP, SNMP 3, SMTP
- Expansion Slots
 - 2 x expansion slot
- Connections
 - 1 x USB 2.0 , 2 x USB host , 1 x Gigabit LAN - RJ-45
- Consumables Included
 - 1 x toner cartridge (black) - up to 8000 pages ISO/IEC 19752 - Kyocera TK-3410 Starter
 - TÜV safety certification, ISO 9001, ISO 14001, GS, ISO 7779
- Power Device
 - Power supply
- Voltage Required
 - AC 220-240 V
- Frequency Required
 - 50/60 Hz
 - 652 Watt
- Power Consumption Sleep
 - 0.5 Watt
- OS Required
 - Limited warranty - 1 year
 - 10 °C
 - 32.5 °C
 - 15 - 80%
- Sound Emission (Operating)
 - 55 dBA
 - 38 cm
 - 41 cm
 - 32 cm
 - 16.1 kg
- Width (Shipping)
 - 54.9 cm
- Depth (Shipping)
 - 49.4 cm
- Height (Shipping)
 - 43.8 cm
- Weight (Shipping)
 - 20 kg
