The ECOSYS PA4500x is a powerful printer embedded with high-level security features. The rapid speed of up to 45 pages per minute contributes to the enhanced productivity of smaller workgroups. Thanks to long-life components and low energy consumption, it leaves a smaller environmental footprint.
                Efficient connectivityWith interfaces like Gigabit Ethernet, USB 2.0, and USB host, alongside wireless capabilities including Apple AirPrint, Kyocera Mobile Print, Mopria Print Service, and wireless direct printing, this printer ensures seamless integration into any work environment.
                High-capacity printingBoasting a maximum media capacity of 2600 sheets, automatic duplexing, and a robust duty cycle of 6000 pages, the Kyocera ECOSYS PA4500X is designed to handle high-volume printing tasks with ease.
                Superior print qualityAchieve crisp, clear printouts with a maximum resolution of 1200 x 1200 DPI. Whether printing simple text documents or detailed graphics, the output quality is consistently impressive.
                Secure and reliableFeaturing advanced security protocols such as IPsec, LDAP, SMTP, SNMP 3, and TLS, along with secure printing IPP over TLS, secure boot, and a trusted platform module, this printer ensures your documents remain confidential and protected.
                Eco-friendly designAdhering to environmental standards like ISO 14001, ISO 7779, and ISO 9001, the Kyocera ECOSYS PA4500X is built with sustainability in mind, making it an ideal choice for eco-conscious businesses.
- Kyocera ECOSYS PA4500X - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 14.6 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 70 mm x 148 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 45 ppm - B/W - A4 (210 x 297 mm) , Up to 22.5 ppm - B/W duplex - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, USB host
- AirPrint Enabled
- Processor
- ARM A53 1.4 GHz
- RAM Installed (Max)
- 512 MB (2.5 GB)
- Card Reader
- Language Simulation
- PCL 6, PCL 5E, PCL XL, KPDL3, PDF Direct, XPS, PPML, TIFF, JPEG, URF, PWG, PCLm, IBM ProPrinter, EPSON LQ 850
- Media Type
- Plain paper
- Total Media Capacity
- 600 sheets
- Media Handling
- 100-sheet multipurpose tray, 500-sheet paper cassette
- Monthly Duty Cycle (max)
- 150000 pages
- Recommended Monthly Volume
- 20000 pages
- Networking
- Print server
- Printer Features
- PDF direct print, Internet printing, E-mail printing, WSD print, secure printing IPP over TLS, local and network authentication, trusted platform module, secure boot, run time integrity check
- Power
- AC 220-240 V
- System Requirements
- Microsoft Windows, Apple MacOS X 10.9 or later, Google Chrome OS, Linux, UNIX
- 1-year warranty
- 38 cm x 41 cm x 28.5 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Built-in Devices
- LCD display
- Connectivity Technology
- Wired
- Interface
- AirPrint Enabled
- 1200 x 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 5.3 sec
- Fonts Included
- 93 x outline , 1 x bitmapped , 45 x barcode
- Printer Features
- Media Handling
- Processor
- ARM A53 1.4 GHz
RAM
- 512 MB / 2.5 GB (max)
Card Reader
- Card reader
- Supported Flash Memory Cards
- SD Memory Card, SDHC Memory Card
Media Handling
- Media Type
- Plain paper
- Media Size Class
- A4/Legal
- Max Media Size
- 70 mm x 148 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Folio (216 x 330 mm)
- Media Weight
- 60 g/m² - 220 g/m²
- 600 sheets
- Media Feeders
- Multi-purpose tray: 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Paper cassette: 1 x automatic - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²
- Max Media Capacity
- 2600 sheets
- Output Trays Capacity
- 250 sheets
Duty Cycle
- 150000 pages
- 20000 pages
- Networking
- Print server
- TLS, IPsec, LDAP, SNMP 3, SMTP
- Expansion Slots
- 2 x expansion slot
- Connections
- 1 x USB 2.0 , 2 x USB host , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 6000 pages ISO/IEC 19752 - Kyocera TK-3400
- TÜV safety certification, ISO 9001, ISO 14001, GS, ISO 7779
- Power Device
- Power supply
- Voltage Required
- AC 220-240 V
- Frequency Required
- 50/60 Hz
- 605.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- OS Required
- Limited warranty - 1 year
- 10 °C
- 32.5 °C
- 15 - 80%
- Sound Emission (Operating)
- 54 dBA
- 38 cm
- 41 cm
- 28.5 cm
- 14.6 kg
- Width (Shipping)
- 54.9 cm
- Depth (Shipping)
- 49.4 cm
- Height (Shipping)
- 42 cm
- Weight (Shipping)
- 18.5 kg
