Kyocera ECOSYS PA4000x Mono Laser Printer
Quicklinx: HW44WS00 Mfr#: 110C153NL0
Type: Printer
Functionality: Printer
Wireless Capability: Wired
Max Paper Size: A4 (210 x 297 mm), Legal (216 x 356 mm)
£176.18 ex VAT
£211.41 inc VAT
Marketing description is not available.
  • Efficient printing technology
    Utilizing laser printing technology, the Kyocera ECOSYS PA4000x delivers sharp monochrome prints with a maximum resolution of 1200 x 1200 DPI. This ensures clear text and detailed graphics, suitable for various business documents.
  • Multiple connectivity options
    Equipped with USB 2.0 and Gigabit Ethernet interfaces, the printer supports both wired and wireless connections. Mobile printing is enabled through Apple AirPrint, Microsoft Universal Print, and more, promoting flexibility in print management.
  • Versatile media handling
    With a maximum media capacity of 850 sheets and support for a wide range of media types, including envelopes and labels, the PA4000x meets diverse printing demands. It features a 100-sheet multipurpose tray and 250-sheet paper cassette for efficient workflow.
  • Enhanced security features
    The printer incorporates various security protocols, including TLS and IP filtering, to protect sensitive data during printing. Features like private print and secure printing with IPP over TLS ensure confidentiality for your documents.
  • Cost-effective operation
    Designed for efficiency, the PA4000x has a low power consumption rate of just 0.3 watts in sleep mode, along with a long-lasting toner cartridge duty cycle of 3600 pages, making it an economical choice for any office setting.
Kyocera ECOSYS PA4000x - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
14.5 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
70 mm x 148 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 40 ppm - max speed - A4 (210 x 297 mm) , Up to 20 ppm - duplex - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
ARM Cortex-A53 1 GHz
RAM Installed (Max)
512 MB
Language Simulation
PRESCRIBE, PCL 6, PCL 5E, PCL XL, KPDL3, PostScript 3, IBM ProPrinter, EPSON LQ 850, PDF Direct, XPS, TIFF
Barcodes
EAN-8, EAN-13, EAN-128, PDF417
Media Type
Plain paper, recycled paper, preprinted paper, bond paper, coloured paper, pre-punched, letterheaded paper, thick paper, transparency film, labels, card stock, envelopes
Total Media Capacity
350 sheets
Media Handling
100-sheet multipurpose tray, 250-sheet paper cassette
Monthly Duty Cycle (max)
80000 pages
Recommended Monthly Volume
2000 pages
Print server
Printer Features
PDF direct print, Internet printing, secure printing IPP over TLS, WSD print, secure boot, run time integrity check, trusted platform module, local and network authentication, E-mail printing
AC 220-240 V
Microsoft Windows, Apple MacOS X 10.9 or later, Google Chrome OS
3-year warranty
37.5 cm x 39.3 cm x 27.2 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Built-in Devices
LCD display
Wired
AirPrint Enabled
1200 x 1200 dpi
Automatic Duplexing
First Print Out Time B/W
6.4 sec
Language Simulation
Fonts Included
93 x outline , 1 x bitmapped , 45 x barcode , 4 x calibri , 4 x cambria
Barcodes
Printer Features
Media Handling
RAM
RAM Installed (Max)
512 MB
Card Reader
Supported Flash Memory Cards
SD Memory Card, SDHC Memory Card
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
70 mm x 148 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm), 105 x 148.5 mm, 216 x 356 mm, Folio (216 x 330 mm)
Media Weight
60 g/m² - 220 g/m²
350 sheets
Media Feeders
Multi-purpose tray: 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Paper cassette: 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Output tray: 1 - 250 sheets
Max Media Capacity
850 sheets
Output Trays Capacity
250 sheets
Duty Cycle
80000 pages
2000 pages
Print server
Remote Management Protocol
HTTPS
Security Protocols & Features
Private print, IPsec, TLS, SNMP 3, NTLM v2, IP filtering
USB 2.0 - USB 2.0 type B , USB host - 4 pin USB Type A , Gigabit LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 3600 pages ISO/IEC 19752 - Kyocera TK-1260 Starter
Quick Copy, password security
TUV-GS, ISO 9001, ISO 14001
Power supply
AC 220-240 V
Frequency Required
50/60 Hz
555.9 Watt
Power Consumption Stand by
6 Watt
Power Consumption Sleep
0.3 Watt
Limited warranty - 1 year , Limited hardware warranty - drum - 3 years / 100000 pages
10 °C
32.5 °C
10 - 80 % RH
Sound Emission (Idle)
29 dBA
Sound Emission (Operating)
52 dBA
Sound Emission (Quiet Mode)
48 dBA
37.5 cm
39.3 cm
27.2 cm
14.5 kg
Width (Shipping)
51.6 cm
Depth (Shipping)
50 cm
Height (Shipping)
40 cm
Weight (Shipping)
18 kg
HW44 Kyocera TK-1260 10,000 Sheet Black Toner In Stock £112.26
Type: Printer
Brand: Kyocera
