Efficient printing technology
Utilizing laser printing technology, the Kyocera ECOSYS PA4000x delivers sharp monochrome prints with a maximum resolution of 1200 x 1200 DPI. This ensures clear text and detailed graphics, suitable for various business documents. -
Multiple connectivity options
Equipped with USB 2.0 and Gigabit Ethernet interfaces, the printer supports both wired and wireless connections. Mobile printing is enabled through Apple AirPrint, Microsoft Universal Print, and more, promoting flexibility in print management. -
Versatile media handling
With a maximum media capacity of 850 sheets and support for a wide range of media types, including envelopes and labels, the PA4000x meets diverse printing demands. It features a 100-sheet multipurpose tray and 250-sheet paper cassette for efficient workflow. -
Enhanced security features
The printer incorporates various security protocols, including TLS and IP filtering, to protect sensitive data during printing. Features like private print and secure printing with IPP over TLS ensure confidentiality for your documents. -
Cost-effective operation
Designed for efficiency, the PA4000x has a low power consumption rate of just 0.3 watts in sleep mode, along with a long-lasting toner cartridge duty cycle of 3600 pages, making it an economical choice for any office setting.
- Kyocera ECOSYS PA4000x - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 14.5 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 70 mm x 148 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 40 ppm - max speed - A4 (210 x 297 mm) , Up to 20 ppm - duplex - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, USB host
- AirPrint Enabled
- Processor
- ARM Cortex-A53 1 GHz
- RAM Installed (Max)
- 512 MB
- Language Simulation
- PRESCRIBE, PCL 6, PCL 5E, PCL XL, KPDL3, PostScript 3, IBM ProPrinter, EPSON LQ 850, PDF Direct, XPS, TIFF
- Barcodes
- EAN-8, EAN-13, EAN-128, PDF417
- Media Type
- Plain paper, recycled paper, preprinted paper, bond paper, coloured paper, pre-punched, letterheaded paper, thick paper, transparency film, labels, card stock, envelopes
- Total Media Capacity
- 350 sheets
- Media Handling
- 100-sheet multipurpose tray, 250-sheet paper cassette
- Monthly Duty Cycle (max)
- 80000 pages
- Recommended Monthly Volume
- 2000 pages
- Networking
- Print server
- Printer Features
- PDF direct print, Internet printing, secure printing IPP over TLS, WSD print, secure boot, run time integrity check, trusted platform module, local and network authentication, E-mail printing
- Power
- AC 220-240 V
- System Requirements
- Microsoft Windows, Apple MacOS X 10.9 or later, Google Chrome OS
- 3-year warranty
- 37.5 cm x 39.3 cm x 27.2 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Built-in Devices
- LCD display
- Connectivity Technology
- Wired
- Interface
- AirPrint Enabled
- 1200 x 1200 dpi
- First Print Out Time B/W
- 6.4 sec
- Fonts Included
- 93 x outline , 1 x bitmapped , 45 x barcode , 4 x calibri , 4 x cambria
- Barcodes
- Printer Features
- Media Handling
- Processor
RAM
- 512 MB
Card Reader
- Supported Flash Memory Cards
- SD Memory Card, SDHC Memory Card
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 70 mm x 148 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm), 105 x 148.5 mm, 216 x 356 mm, Folio (216 x 330 mm)
- Media Weight
- 60 g/m² - 220 g/m²
- 350 sheets
- Media Feeders
- Multi-purpose tray: 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Paper cassette: 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Output tray: 1 - 250 sheets
- Max Media Capacity
- 850 sheets
- Output Trays Capacity
- 250 sheets
Duty Cycle
- 80000 pages
- 2000 pages
- Networking
- Print server
- Remote Management Protocol
- HTTPS
- Private print, IPsec, TLS, SNMP 3, NTLM v2, IP filtering
- Connections
- USB 2.0 - USB 2.0 type B , USB host - 4 pin USB Type A , Gigabit LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 3600 pages ISO/IEC 19752 - Kyocera TK-1260 Starter
- Quick Copy, password security
- TUV-GS, ISO 9001, ISO 14001
- Power Device
- Power supply
- Voltage Required
- AC 220-240 V
- Frequency Required
- 50/60 Hz
- 555.9 Watt
- Power Consumption Stand by
- 6 Watt
- Power Consumption Sleep
- 0.3 Watt
- OS Required
- Limited warranty - 1 year , Limited hardware warranty - drum - 3 years / 100000 pages
- 10 °C
- 32.5 °C
- 10 - 80 % RH
- Sound Emission (Idle)
- 29 dBA
- Sound Emission (Operating)
- 52 dBA
- Sound Emission (Quiet Mode)
- 48 dBA
- 37.5 cm
- 39.3 cm
- 27.2 cm
- 14.5 kg
- Width (Shipping)
- 51.6 cm
- Depth (Shipping)
- 50 cm
- Height (Shipping)
- 40 cm
- Weight (Shipping)
- 18 kg
Kyocera TK-1260 10,000 Sheet Black Toner | In Stock | £111.61 |
