Kyocera ECOSYS PA2600cx Colour Laser Printer
UP TO £125 CASHBACK OR 1 YEAR WARRANTY EXTENSION AVAILABLE!
Cashback
Quicklinx: J4K1WS00 Mfr#: 110C0H3NL0
17 In Stock
£300.53 ex VAT
£360.63 inc VAT
The Kyocera ECOSYS PA2600cx is designed for workgroup efficiency, providing high-quality color printing and versatile media handling. This reliable laser printer ensures a monthly duty cycle of up to 65,000 pages, making it suitable for businesses with demanding print needs. With features like a 2.7 inch TFT display and mobile printing capabilities such as Apple AirPrint and Mopria Print Service, users can easily print from various devices. Designed with operational efficiency in mind, the PA2600cx features a quick warm-up time of 29 seconds and an output speed of 26 pages per minute for both color and black and white documents. The robust connectivity options, including USB 2.0 and Gigabit Ethernet, allow for seamless integration into any office network. Additionally, its eco-friendly features promote sustainability while maintaining productivity.
  • Efficient media handling
    The Kyocera ECOSYS PA2600cx supports a total media capacity of 300 sheets with an additional 250-sheet input tray and a 50-sheet multipurpose tray, allowing users to manage diverse print jobs effortlessly.
  • Mobile printing capabilities
    This printer supports various mobile printing solutions, including Apple AirPrint, Mopria Print Service, and Kyocera Mobile Print, providing flexibility and convenience for users on-the-go.
  • Reliable printing performance
    Delivering a maximum resolution of 1200 x 1200 DPI, the PA2600cx ensures high-quality print output while maintaining a consistent printing speed of 26 pages per minute for both color and black and white documents.
  • Quick operational efficiency
    A warm-up time of 29 seconds allows this printer to be ready for use shortly after being powered on, minimizing delays and enhancing productivity in busy work environments.
  • Robust connectivity options
    Equipped with interfaces such as USB 2.0 and Gigabit Ethernet, as well as remote management protocols like HTTPS and IPP 1.0, the PA2600cx easily integrates into existing networks and supports remote management features.
Kyocera ECOSYS PA2600cx - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
21 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm)/A4 (210 x 297 mm)
Min Media Size (Custom)
70 mm x 148 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 26 ppm - B/W - A4 (210 x 297 mm) , Up to 26 ppm - colour - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 1200 dpi
USB 2.0, USB host, Gigabit LAN
AirPrint Enabled
800 MHz
RAM Installed (Max)
1 GB
Language Simulation
PRESCRIBE IIc, PCL 5C, PCL 6, PCL XL, PostScript 3, KPDL3, PDF Direct, PDF 1.7, PDF 2.0, XPS, TIFF
Barcodes
PDF417, 1D
Media Type
Plain paper
Total Media Capacity
300 sheets
Media Handling
50-sheet multipurpose tray, 250-sheet input tray
Monthly Duty Cycle (max)
65000 pages
Recommended Monthly Volume
900 pages
Print server
Printer Features
29 sec warm-up time, ThinPrint support, trusted platform module, proof and hold, job storage, quick copy, private printing, Internet printing, E-mail printing, WSD print, EcoPrint
AC 220-240 V
Apple MacOS X 10.9 or later, Google Chrome OS, Linux, Microsoft Windows
1-year warranty
41 cm x 41 cm x 32.9 cm
Printer Type
Printer
Print Speed
Built-in Devices
Wired
AirPrint Enabled
1200 x 1200 dpi
PostScript Support
Standard
First Print Out Time B/W
9.5 sec
First Print Out Time Colour
10.5 sec
Language Simulation
Fonts Included
93 x scalable , 4 x calibri , 4 x cambria , 1 x bitmapped , 46 x barcode
Barcodes
PDF417, 1D
Printer Features
Media Handling
800 MHz
RAM
RAM Installed (Max)
1 GB
Card Reader
Supported Flash Memory Cards
SD Memory Card
Media Handling
Media Type
Plain paper
Media Size Class
A4/Legal
Max Media Size
70 mm x 148 mm
216 mm x 356 mm
Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), B6 (125 x 176 mm), A6 (105 x 148 mm), ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), 70 x 148 mm
Media Weight
60 g/m² - 220 g/m²
300 sheets
Media Feeders
Multi-purpose tray: 1 x automatic - 50 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , Input tray: 1 x automatic - 250 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m²
Max Media Capacity
550 sheets
Output Trays Capacity
150 sheets
Duty Cycle
65000 pages
900 pages
Print server
Remote Management Protocol
IPP 1.0, TLS, HTTPS, Syslog
Security Protocols & Features
IPsec, SNMP 3, S/MIME, NTLM v2, Kerberos
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 1500 pages ISO/IEC 19798 - Kyocera TK-5450K , 1 x toner cartridge (yellow) - up to 1500 pages ISO/IEC 19798 - Kyocera TK-5450Y , 1 x toner cartridge (magenta) - up to 1500 pages ISO/IEC 19798 - Kyocera TK-5450M , 1 x toner cartridge (cyan) - up to 1500 pages ISO/IEC 19798 - Kyocera TK-5450C
Firmware upgradable, TPM support
ISO 7779, ISO 9296, GS, TUV, ISO 9001, ISO 14001, ISO 19798
Power supply
AC 220-240 V
Frequency Required
50/60 Hz
375 Watt
Power Consumption Stand by
33 Watt
Power Consumption Sleep
0.3 Watt
Limited warranty - 1 year
Sound Emission (Idle)
30 dBA
Sound Emission (Operating)
49 dBA
41 cm
41 cm
32.9 cm
21 kg
Width (Shipping)
59.6 cm
Depth (Shipping)
57.1 cm
Height (Shipping)
45.9 cm
Weight (Shipping)
28 kg
Brand: Kyocera
