The Kyocera ECOSYS PA2600CWX is a versatile workgroup printer designed to meet the demands of any office environment. With robust color printing capabilities and a monthly duty cycle of up to 65,000 pages, this printer is ideal for both high-volume printing and everyday tasks. Featuring comprehensive connectivity options, including Gigabit Ethernet, USB 2.0, and Wi-Fi, along with support for mobile printing through Apple AirPrint and the Kyocera Mobile Print app, the PA2600CWX enhances workflow efficiency. The built-in 2.7 inch TFT display simplifies operation, allowing users to monitor and manage print jobs effortlessly. This printer offers flexible paper handling with the capacity to support various media sizes up to Legal (216 x 356 mm). The high-quality laser printing ensures sharp text and vivid color output, making it suitable for a range of documents from simple reports to professional marketing materials. With advanced features such as secure printing, job storage, and eco-friendly settings, the Kyocera ECOSYS PA2600CWX delivers reliable performance and improved productivity while minimizing environmental impact.
High-performance printing
Delivers high-quality color and black-and-white prints with a resolution of 1200 x 1200 DPI, achieving impressive printing speeds of up to 26 pages per minute for both color and monochrome outputs. -
Efficient connectivity
Equipped with multiple interfaces including USB 2.0, Gigabit Ethernet, and wireless options, the printer allows seamless integration into diverse network environments while enabling easy mobile printing. -
Smart media handling
Comes with a 250-sheet input tray and a 50-sheet multipurpose tray, offering flexible options for various media types and sizes, from A4 to Legal, along with a total media capacity of 300 sheets. -
Secure and easy management
Includes features such as trusted platform module support, secure printing options, and a user-friendly interface for managing print jobs, ensuring confidentiality and control over print output. -
Low operational noise
Operates at a sound emission of just 30 dBA when idle and 49 dBA during operation, making it suitable for quiet office environments without disturbing day-to-day activities.
- Kyocera ECOSYS PA2600CWX - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 21 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm)/A4 (210 x 297 mm)
- Min Media Size (Custom)
- 70 mm x 148 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 26 ppm - B/W - A4 (210 x 297 mm) , Up to 26 ppm - colour - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Interface
- USB 2.0, USB host, Gigabit LAN, Wi-Fi
- AirPrint Enabled
- Processor
- ARM A53 1 GHz
- RAM Installed (Max)
- 1 GB
- Language Simulation
- PRESCRIBE IIc, PCL 5C, PCL 6, PCL XL, PostScript 3, KPDL3, PDF Direct, PDF 1.7, PDF 2.0, XPS, TIFF
- Barcodes
- PDF417, 1D
- Media Type
- Plain paper
- Total Media Capacity
- 300 sheets
- Media Handling
- 50-sheet multipurpose tray, 250-sheet input tray
- Monthly Duty Cycle (max)
- 65000 pages
- Recommended Monthly Volume
- 900 pages
- Networking
- Print server
- Printer Features
- 29 sec warm-up time, ThinPrint support, trusted platform module, proof and hold, job storage, quick copy, private printing, Internet printing, E-mail printing, WSD print, EcoPrint
- Power
- AC 220-240 V
- System Requirements
- Apple MacOS X 10.9 or later, Google Chrome OS, Linux, Microsoft Windows
- 1-year warranty
- 41 cm x 41 cm x 32.9 cm
- Printer Type
Printer
- Print Speed
- Built-in Devices
- 2.7 inch TFT display
- Connectivity Technology
- Wireless
- Interface
- AirPrint Enabled
- 1200 x 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 9.5 sec
- First Print Out Time Colour
- 10.5 sec
- Fonts Included
- 93 x scalable , 4 x calibri , 4 x cambria , 1 x bitmapped , 46 x barcode
- Barcodes
- PDF417, 1D
- Printer Features
- Media Handling
- Processor
- ARM A53 1 GHz
RAM
- 1 GB
Card Reader
- Supported Flash Memory Cards
- SD Memory Card
Media Handling
- Media Type
- Plain paper
- Media Size Class
- A4/Legal
- Max Media Size
- 70 mm x 148 mm
- 216 mm x 356 mm
- Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), B6 (125 x 176 mm), A6 (105 x 148 mm), ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), 70 x 148 mm
- Media Weight
- 60 g/m² - 220 g/m²
- 300 sheets
- Media Feeders
- Multi-purpose tray: 1 x automatic - 50 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , Input tray: 1 x automatic - 250 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m²
- Max Media Capacity
- 550 sheets
- Output Trays Capacity
- 150 sheets
Duty Cycle
- 65000 pages
- 900 pages
- Networking
- Print server
- Remote Management Protocol
- IPP 1.0, TLS, HTTPS, Syslog
- IPsec, SNMP 3, S/MIME, NTLM v2, Kerberos
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 1500 pages ISO/IEC 19798 - Kyocera TK-5450K , 1 x toner cartridge (yellow) - up to 1500 pages ISO/IEC 19798 - Kyocera TK-5450Y , 1 x toner cartridge (magenta) - up to 1500 pages ISO/IEC 19798 - Kyocera TK-5450M , 1 x toner cartridge (cyan) - up to 1500 pages ISO/IEC 19798 - Kyocera TK-5450C
- Firmware upgradable, TPM support
- ISO 7779, ISO 9296, GS, TUV, ISO 9001, ISO 14001, ISO 19798
- Power Device
- Power supply
- Voltage Required
- AC 220-240 V
- Frequency Required
- 50/60 Hz
- 375 Watt
- Power Consumption Stand by
- 33 Watt
- Power Consumption Sleep
- 0.3 Watt
- OS Required
- Limited warranty - 1 year
- Sound Emission (Idle)
- 30 dBA
- Sound Emission (Operating)
- 49 dBA
- 41 cm
- 41 cm
- 32.9 cm
- 21 kg
- Width (Shipping)
- 59.6 cm
- Depth (Shipping)
- 57.1 cm
- Height (Shipping)
- 45.9 cm
- Weight (Shipping)
- 28 kg
