Our checkout area is closed for maintenance, but should be back online soon. We apologise for any inconvenience caused
Kyocera ECOSYS P8060cdn Colour Laser Printer
Quicklinx: D99XWS00 Mfr#: 1102RR3NL0
Type: Printer
Functionality: Printer
Wireless Capability: Wired
Max Paper Size: A3 (297 x 420 mm)
£1,707.01 ex VAT
£2,048.41 inc VAT
This high-end color printer is the perfect choice for demanding workgroups and production offices. With a high print speed, the device's color technology offers outstanding and vivid results and the printer offers a big paper capacity. Its fast performance is secured by an solid state drive and HDD, enabling it to maintain its high print speeds even at maximum print resolution.Additionally, the redesigned touch panel makes accessing all features very intuitive and easy to use.
  • Efficient productivity
    With a robust printing speed of up to 60 ppm in B/W and 55 ppm in color, the Kyocera ECOSYS P8060cdn ensures your work flows smoothly and efficiently, minimizing wait times and boosting productivity.
  • Exceptional print quality
    Achieve outstanding print quality with resolutions up to 4800 x 1200 DPI for both black and white and color prints. The Kyocera ECOSYS P8060cdn delivers crisp, vivid, and professional-looking documents, making it ideal for all your business needs.
  • Advanced connectivity
    Equipped with Gigabit Ethernet, USB 2.0, and mobile printing capabilities including Apple AirPrint, this printer offers versatile connectivity options for a seamless printing experience from anywhere in the office.
  • Eco-friendly design
    Featuring Kyocera's ECOSYS technology, the P8060cdn is designed for durability and long-life use, reducing waste and operating costs. ENERGY STAR certification ensures energy efficiency, making it a smart choice for the environmentally conscious.
  • High capacity and flexibility
    Handle large print jobs with ease thanks to a maximum media capacity of 7150 sheets and support for a wide range of media sizes and weights. Automatic duplexing and a 320 GB hard drive further enhance the printer's performance and versatility.
Kyocera ECOSYS P8060cdn - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
89 kg
Media Size Class
A3
Max Media Size
A3 (297 x 420 mm)
Min Media Size (Custom)
98 mm x 148 mm
Max Media Size (Custom)
297 mm x 457 mm
Print Speed
Up to 60 ppm - B/W - A4 (210 x 297 mm) , Up to 30 ppm - B/W - A3 (297 x 420 mm) , Up to 55 ppm - colour - A4 (210 x 297 mm) , Up to 27 ppm - colour - A3 (297 x 420 mm)
Max Resolution (B&W)
4800 x 1200 dpi
Max Resolution (Colour)
4800 x 1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, USB 2.0 host
AirPrint Enabled
Freescale QorIQ T1024 1.2 GHz
RAM Installed (Max)
4 GB
Flash Memory Installed (Max)
8 GB
Hard Drive
320 GB
Language Simulation
PCL 5C, PostScript 3, PCL 6, PCL XL, KPDL3, PDF, XPS, PRESCRIBE IIc
Media Type
Envelopes, transparencies, labels, plain paper, banners, bond paper, recycled paper, thick paper, thin paper, card stock, tabs, punched paper, preprinted paper, tab dividers
Total Media Capacity
1150 sheets
Media Handling
2x 500-sheet input trays, 150-sheet multipurpose tray
Print server
Printer Features
Kyocera ECOSYS Technology, print from e-mail
UNIX, Linux, Microsoft Windows, Apple MacOS X 10.8 or later
60.2 cm x 66.5 cm x 79 cm
Printer Type
Printer
Print Speed
Built-in Devices
9 inch LCD touch screen
Wired
AirPrint Enabled
4800 x 1200 dpi
4800 x 1200 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
3.8 sec
First Print Out Time Colour
5.1 sec
Language Simulation
Fonts Included
93 x PCL , 136 x KPDL3 , 1 x bitmapped , 45 x barcode
Colour Management Features
Mopria
Printer Features
Media Handling
RAM
RAM Installed (Max)
4 GB
Flash Memory
Flash Memory
8 GB
Storage
Hard Drive
320 GB
Media Handling
Media Type
Media Size Class
A3
Max Media Size
A3 (297 x 420 mm)
98 mm x 148 mm
297 mm x 457 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), ARCH B (304.8 x 457.2 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm), SRA3 (320 x 450 mm), Statement (139.7 x 215.9 mm), 197 x 273 mm, 216 x 340 mm, JIS B6 (128 x 182 mm), 273 x 394 mm
Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm), US No 6 (92 x 165 mm), International C4 (229 x 324 mm), Japanese postcard (100 x 148 mm), Japanese Postcard Double (148 x 200 mm), 114 x 162 mm, Youkei 4 (105 x 235 mm)
Media Weight
52 g/m² - 300 g/m²
1150 sheets
Media Feeders
1 x automatic - 150 sheets - A3 (297 x 420 mm) weight: 52 g/m² - 300 g/m² , 1 x automatic - A4 (210 x 297 mm) weight: 52 g/m² - 300 g/m² , 1 x automatic - 500 sheets - SRA3 (320 x 450 mm) weight: 52 g/m² - 300 g/m²
Max Media Capacity
7150 sheets
Output Trays Capacity
500 sheets
Print server
Remote Management Protocol
SNMP 3, IPP
Security Protocols & Features
SSL, IPsec
Expansion Slots
1 x expansion slot
4 x USB 2.0 , 1 x USB 2.0 host , 1 x Gigabit LAN - RJ-45
Waste ink tank
Consumables Included
1 x toner cartridge (black) - up to 15000 pages , 1 x toner cartridge (cyan) - up to 10000 pages , 1 x toner cartridge (magenta) - up to 10000 pages , 1 x toner cartridge (yellow) - up to 10000 pages , 1 x waste toner collector - up to 40000 pages , Staple
TUV GS, ISO 9001, ISO 14001, ISO 7779, ISO 9296
Power supply - internal
Frequency Required
50/60 Hz
960 Watt
Power Consumption Stand by
60 Watt
Power Consumption Sleep
1 Watt
Environmental Standards
ENERGY STAR
10 °C
32.5 °C
10 - 80%
Sound Emission (Idle)
19 dBA
Sound Emission (Operating)
55.5 dBA
60.2 cm
66.5 cm
79 cm
89 kg
Type: Printer
Brand: Kyocera
Price Range Ex VAT: £1500+
