This high-end color printer is the perfect choice for demanding workgroups and production offices. With a high print speed, the device's color technology offers outstanding and vivid results and the printer offers a big paper capacity. Its fast performance is secured by an solid state drive and HDD, enabling it to maintain its high print speeds even at maximum print resolution.Additionally, the redesigned touch panel makes accessing all features very intuitive and easy to use.
Efficient productivity
With a robust printing speed of up to 60 ppm in B/W and 55 ppm in color, the Kyocera ECOSYS P8060cdn ensures your work flows smoothly and efficiently, minimizing wait times and boosting productivity. -
Exceptional print quality
Achieve outstanding print quality with resolutions up to 4800 x 1200 DPI for both black and white and color prints. The Kyocera ECOSYS P8060cdn delivers crisp, vivid, and professional-looking documents, making it ideal for all your business needs. -
Advanced connectivity
Equipped with Gigabit Ethernet, USB 2.0, and mobile printing capabilities including Apple AirPrint, this printer offers versatile connectivity options for a seamless printing experience from anywhere in the office. -
Eco-friendly design
Featuring Kyocera's ECOSYS technology, the P8060cdn is designed for durability and long-life use, reducing waste and operating costs. ENERGY STAR certification ensures energy efficiency, making it a smart choice for the environmentally conscious. -
High capacity and flexibility
Handle large print jobs with ease thanks to a maximum media capacity of 7150 sheets and support for a wide range of media sizes and weights. Automatic duplexing and a 320 GB hard drive further enhance the printer's performance and versatility.
- Kyocera ECOSYS P8060cdn - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 89 kg
- Media Size Class
- A3
- Max Media Size
- A3 (297 x 420 mm)
- Min Media Size (Custom)
- 98 mm x 148 mm
- Max Media Size (Custom)
- 297 mm x 457 mm
- Print Speed
- Up to 60 ppm - B/W - A4 (210 x 297 mm) , Up to 30 ppm - B/W - A3 (297 x 420 mm) , Up to 55 ppm - colour - A4 (210 x 297 mm) , Up to 27 ppm - colour - A3 (297 x 420 mm)
- Max Resolution (B&W)
- 4800 x 1200 dpi
- Max Resolution (Colour)
- 4800 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, USB 2.0 host
- AirPrint Enabled
- Processor
- Freescale QorIQ T1024 1.2 GHz
- RAM Installed (Max)
- 4 GB
- Flash Memory Installed (Max)
- 8 GB
- Hard Drive
- 320 GB
- Language Simulation
- PCL 5C, PostScript 3, PCL 6, PCL XL, KPDL3, PDF, XPS, PRESCRIBE IIc
- Media Type
- Envelopes, transparencies, labels, plain paper, banners, bond paper, recycled paper, thick paper, thin paper, card stock, tabs, punched paper, preprinted paper, tab dividers
- Total Media Capacity
- 1150 sheets
- Media Handling
- 2x 500-sheet input trays, 150-sheet multipurpose tray
- Networking
- Print server
- Printer Features
- Kyocera ECOSYS Technology, print from e-mail
- System Requirements
- UNIX, Linux, Microsoft Windows, Apple MacOS X 10.8 or later
- 60.2 cm x 66.5 cm x 79 cm
- Printer Type
Printer
- Print Speed
- Built-in Devices
- 9 inch LCD touch screen
- Connectivity Technology
- Wired
- Interface
- AirPrint Enabled
- 4800 x 1200 dpi
- 4800 x 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 3.8 sec
- First Print Out Time Colour
- 5.1 sec
- Fonts Included
- 93 x PCL , 136 x KPDL3 , 1 x bitmapped , 45 x barcode
- Colour Management Features
- Mopria
- Printer Features
- Media Handling
- Processor
RAM
- 4 GB
Flash Memory
- Flash Memory
- 8 GB
Storage
- Hard Drive
- 320 GB
Media Handling
- Media Type
- Media Size Class
- A3
- Max Media Size
- A3 (297 x 420 mm)
- 98 mm x 148 mm
- 297 mm x 457 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), ARCH B (304.8 x 457.2 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm), SRA3 (320 x 450 mm), Statement (139.7 x 215.9 mm), 197 x 273 mm, 216 x 340 mm, JIS B6 (128 x 182 mm), 273 x 394 mm
- Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm), US No 6 (92 x 165 mm), International C4 (229 x 324 mm), Japanese postcard (100 x 148 mm), Japanese Postcard Double (148 x 200 mm), 114 x 162 mm, Youkei 4 (105 x 235 mm)
- Media Weight
- 52 g/m² - 300 g/m²
- 1150 sheets
- Media Feeders
- 1 x automatic - 150 sheets - A3 (297 x 420 mm) weight: 52 g/m² - 300 g/m² , 1 x automatic - A4 (210 x 297 mm) weight: 52 g/m² - 300 g/m² , 1 x automatic - 500 sheets - SRA3 (320 x 450 mm) weight: 52 g/m² - 300 g/m²
- Max Media Capacity
- 7150 sheets
- Output Trays Capacity
- 500 sheets
- Networking
- Print server
- Remote Management Protocol
- SNMP 3, IPP
- SSL, IPsec
- Expansion Slots
- 1 x expansion slot
- Connections
- 4 x USB 2.0 , 1 x USB 2.0 host , 1 x Gigabit LAN - RJ-45
- Included Accessories
- Waste ink tank
- Consumables Included
- 1 x toner cartridge (black) - up to 15000 pages , 1 x toner cartridge (cyan) - up to 10000 pages , 1 x toner cartridge (magenta) - up to 10000 pages , 1 x toner cartridge (yellow) - up to 10000 pages , 1 x waste toner collector - up to 40000 pages , Staple
- TUV GS, ISO 9001, ISO 14001, ISO 7779, ISO 9296
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 960 Watt
- Power Consumption Stand by
- 60 Watt
- Power Consumption Sleep
- 1 Watt
- OS Required
Environmental Standards
- ENERGY STAR
- 10 °C
- 32.5 °C
- 10 - 80%
- Sound Emission (Idle)
- 19 dBA
- Sound Emission (Operating)
- 55.5 dBA
- 60.2 cm
- 66.5 cm
- 79 cm
- 89 kg
