Kyocera ECOSYS P6235cdn Colour Laser Printer
Quicklinx: DK30WS00 Mfr#: 1102TW3NL1
Type: Printer
Functionality: Printer
Wireless Capability: Wired
Max Paper Size: Legal (216 x 356 mm), A4 (210 x 297 mm)
£546.12 ex VAT
£655.34 inc VAT
This easy to use colour printer incorporates KYOCERA’s renowned long-life components which help to reduce waste and ensure exceptional levels of reliability. With up to five paper sources the printer allows for different media sizes and weights up to 220g/m2. This is the ideal colour printer for every situation; taking running costs to an exceptional level whilst further increasing your productivity.
  • Efficient productivity
    With first print out times as fast as 6.5 seconds for black and white and 7.5 seconds for color, the Kyocera ECOSYS P6235cdn ensures your work flows smoothly and efficiently, minimizing wait times and boosting productivity.
  • High-resolution printing
    Achieve exceptional clarity and detail in every document with a maximum resolution of 1200 x 1200 DPI for both black and white and color prints. This high resolution ensures that every printout, from simple text documents to complex graphics, is sharp and professional.
  • Advanced connectivity
    Equipped with Gigabit Ethernet, USB 2.0, and USB host interfaces along with Apple AirPrint compatibility, this printer offers versatile connectivity options for a seamless printing experience from various devices and networks.
  • Eco-friendly operation
    The Kyocera ECOSYS P6235cdn is ENERGY STAR certified, reflecting its compliance with stringent energy efficiency standards. Coupled with Kyocera's ECOSYS technology, it promotes sustainable use by minimizing waste and operating costs.
Kyocera ECOSYS P6235cdn - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
29.5 kg
Media Size Class
A4/Legal
Max Media Size
Min Media Size (Custom)
70 mm x 148 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 35 ppm - B/W - A4 (210 x 297 mm) , Up to 35 ppm - colour - A4 (210 x 297 mm) , Up to 32 ppm - duplex - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Max Resolution (Colour)
1200 x 1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
ARM Cortex-A9 1.2 GHz
RAM Installed (Max)
1 GB (3 GB)
Card Reader
Language Simulation
PCL 5C, PostScript 3, PCL 6, PCL XL, KPDL3, XPS, PRESCRIBE IIc, PDF Direct
Media Type
Plain paper
Total Media Capacity
600 sheets
Media Handling
100-sheet multipurpose tray, 500-sheet input tray
Print server
Printer Features
Kyocera ECOSYS Technology
39 cm x 53.2 cm x 46.95 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
AirPrint Enabled
1200 x 1200 dpi
1200 x 1200 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
6.5 sec
First Print Out Time Colour
7.5 sec
Language Simulation
Colour Management Features
Mopria
Printer Features
Media Handling
RAM
RAM Installed (Max)
1 GB / 3 GB (max)
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card, SDHC Memory Card
Media Handling
Media Type
Plain paper
Media Size Class
A4/Legal
Max Media Size
70 mm x 148 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), B6 (125 x 176 mm)
Media Weight
60 g/m² - 220 g/m²
600 sheets
Media Feeders
1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
Max Media Capacity
2100 sheets
Output Trays Capacity
500 sheets
Print server
Remote Management Protocol
SNMP 3
Security Protocols & Features
SSL, IPsec
Expansion Slots
1 x expansion slot
1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 6000 pages , 1 x toner cartridge (cyan) - up to 5000 pages , 1 x toner cartridge (magenta) - up to 5000 pages , 1 x toner cartridge (yellow) - up to 5000 pages
TUV, ISO 9001, GS, ISO 14001, ISO 7779, ISO 9296
Power supply - internal
Frequency Required
50/60 Hz
523 Watt
Power Consumption Stand by
74 Watt
Power Consumption Sleep
0.6 Watt
Environmental Standards
ENERGY STAR
Sound Emission (Idle)
30 dBA
Sound Emission (Operating)
52 dBA
39 cm
53.2 cm
46.95 cm
29.5 kg
Type: Printer
Max Paper Size: A4 (210 x 297 mm)
Brand: Kyocera
Price Range Ex VAT: £500 - £750
