This easy to use colour printer incorporates KYOCERA’s renowned long-life components which help to reduce waste and ensure exceptional levels of reliability. With up to five paper sources the printer allows for different media sizes and weights up to 220g/m2. This is the ideal colour printer for every situation; taking running costs to an exceptional level whilst further increasing your productivity.
- Kyocera ECOSYS P6235cdn - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 29.5 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 70 mm x 148 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 35 ppm - B/W - A4 (210 x 297 mm) , Up to 35 ppm - colour - A4 (210 x 297 mm) , Up to 32 ppm - duplex - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Max Resolution (Colour)
- 1200 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, USB host
- AirPrint Enabled
- Processor
- ARM Cortex-A9 1.2 GHz
- RAM Installed (Max)
- 1 GB (3 GB)
- Card Reader
- Language Simulation
- PCL 5C, PostScript 3, PCL 6, PCL XL, KPDL3, XPS, PRESCRIBE IIc, PDF Direct
- Media Type
- Plain paper
- Total Media Capacity
- 600 sheets
- Media Handling
- 100-sheet multipurpose tray, 500-sheet input tray
- Networking
- Print server
- Printer Features
- Kyocera ECOSYS Technology
- 39 cm x 53.2 cm x 46.95 cm
- Printer Type
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- AirPrint Enabled
- 1200 x 1200 dpi
- 1200 x 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 6.5 sec
- First Print Out Time Colour
- 7.5 sec
- Colour Management Features
- Mopria
- Printer Features
- Media Handling
- Processor
RAM
- 1 GB / 3 GB (max)
Card Reader
- Card reader
- Supported Flash Memory Cards
- SD Memory Card, SDHC Memory Card
Media Handling
- Media Type
- Plain paper
- Media Size Class
- A4/Legal
- Max Media Size
- 70 mm x 148 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), B6 (125 x 176 mm)
- Media Weight
- 60 g/m² - 220 g/m²
- 600 sheets
- Media Feeders
- 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
- Max Media Capacity
- 2100 sheets
- Output Trays Capacity
- 500 sheets
- Networking
- Print server
- Remote Management Protocol
- SNMP 3
- SSL, IPsec
- Expansion Slots
- 1 x expansion slot
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 6000 pages , 1 x toner cartridge (cyan) - up to 5000 pages , 1 x toner cartridge (magenta) - up to 5000 pages , 1 x toner cartridge (yellow) - up to 5000 pages
- TUV, ISO 9001, GS, ISO 14001, ISO 7779, ISO 9296
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 523 Watt
- Power Consumption Stand by
- 74 Watt
- Power Consumption Sleep
- 0.6 Watt
Environmental Standards
- ENERGY STAR
- Sound Emission (Idle)
- 30 dBA
- Sound Emission (Operating)
- 52 dBA
- 39 cm
- 53.2 cm
- 46.95 cm
- 29.5 kg
Kyocera TK-5280K Black Toner | In Stock | £132.29 |
Kyocera TK-5280C Cyan Toner | In Stock | £168.97 |
Kyocera TK-5280M Magenta Toner | In Stock | £168.97 |
