Efficient connectivity
With interfaces for Gigabit Ethernet, USB 2.0, and USB host, alongside AirPrint Enabled for seamless mobile printing, this printer offers versatile connectivity options for any office environment. -
High-quality printing
Achieve professional color and B/W printing with a maximum resolution of 1200 x 1200 DPI, ensuring crisp, clear documents every time. -
Eco-friendly design
Certified by ENERGY STAR and compliant with ISO 14001, ISO 7779, ISO 9001, and ISO 9296 standards, this printer is designed with sustainability in mind, reducing environmental impact while maintaining efficiency. -
Robust media handling
Supports a wide range of media sizes from A6 to Legal and weights from 60 g/m2 to 220 g/m2, equipped with a 100-sheet multipurpose tray and a 500-sheet input tray for flexible paper handling. -
Advanced security
Featuring IPsec and SSL security protocols, along with SNMP 3 remote management protocol, this printer ensures secure data transmission and efficient device management.
- Kyocera ECOSYS P6230cdn - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 28.3 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 70 mm x 148 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 30 ppm - B/W - A4 (210 x 297 mm) , Up to 30 ppm - colour - A4 (210 x 297 mm) , Up to 15 ppm - duplex - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Max Resolution (Colour)
- 1200 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, USB host
- AirPrint Enabled
- Processor
- ARM Cortex-A9 1.2 GHz
- RAM Installed (Max)
- 1 GB (1 GB)
- Card Reader
- Language Simulation
- PCL 5C, PostScript 3, PCL 6, PCL XL, KPDL3, XPS, PRESCRIBE IIc, PDF Direct
- Media Type
- Plain paper
- Total Media Capacity
- 600 sheets
- Media Handling
- 100-sheet multipurpose tray, 500-sheet input tray
- Networking
- Print server
- Printer Features
- Kyocera ECOSYS Technology
- 39 cm x 53.2 cm x 40.95 cm
- Printer Type
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- AirPrint Enabled
- 1200 x 1200 dpi
- 1200 x 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 6 sec
- First Print Out Time Colour
- 7 sec
- Colour Management Features
- Mopria
- Printer Features
- Media Handling
- Processor
RAM
- 1 GB / 1 GB (max)
Card Reader
- Card reader
- Supported Flash Memory Cards
- SD Memory Card, SDHC Memory Card
Media Handling
- Media Type
- Plain paper
- Media Size Class
- A4/Legal
- Max Media Size
- 70 mm x 148 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), B6 (125 x 176 mm)
- Media Weight
- 60 g/m² - 220 g/m²
- 600 sheets
- Media Feeders
- 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
- Max Media Capacity
- 2100 sheets
- Output Trays Capacity
- 250 sheets
- Networking
- Print server
- Remote Management Protocol
- SNMP 3
- SSL, IPsec
- Expansion Slots
- 1 x expansion slot
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 3500 pages , 1 x toner cartridge (cyan) - up to 2500 pages , 1 x toner cartridge (magenta) - up to 2500 pages , 1 x toner cartridge (yellow) - up to 2500 pages
- TUV, ISO 9001, GS, ISO 14001, ISO 7779, ISO 9296
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 466 Watt
- Power Consumption Stand by
- 65 Watt
- Power Consumption Sleep
- 0.6 Watt
Environmental Standards
- ENERGY STAR
- Sound Emission (Idle)
- 30 dBA
- Sound Emission (Operating)
- 49.5 dBA
- 39 cm
- 53.2 cm
- 40.95 cm
- 28.3 kg
Kyocera Black toner Cartridge for P6230CDN | In Stock | £90.74 |
