Providing small teams and demanding users with high-quality color prints. The ECOSYS P6021cdn is a compact device with low noise output, which makes it the ideal business companion for any office. It has an integrated duplex unit as standard for effortless double sided printing. It combined with improved energy efficiency: these features help you reduce the impact of your printing activities on the environment. Its long life components reduce waste and make this printer the reliable business companion of choice!
ECOSYS
ECOSYS stands for ECOlogy, ECOnomy and SYStem printing. With their long-life components, ECOSYS devices are designed to maximize durability and minimize the total cost of ownership with regard to maintenance, administration and consumables. The cartridge-free system means that the toner is the only consumable and hardly ever needs to be replaced. The modular design concept allows you to add workflow-enhancing functions as required and the integrated system soft ware provides long-term cross-network compatibility. -
Prescribe IIc
With the Kyocera page design and control language Prescribe IIc, even complex graphics, logos and forms (multipart forms) can be created independently on the system and saved and updated in the printer. Consequently, an integration of graphics into print files is no longer necessary. The printer accesses them as required and thereby reduces network traffic. -
Kyocera NetViewer
Koycera NetViewer enables the complete monitoring and control of all ECOSYS printers and digital Kyocera multifunctional from any Windows. PC and thus gives you the means to streamline your network administration. It also supports standardized SNMP. -
Command center RX
The Command Cener RX enables to control and manage various settings by accessing the device via a common web browser. It automatically updates screens, customizes user screens, and displays department and restriction settings. -
USB interface for USB flash memory device
Documents can be printed directly from a USB flash memory device via the USB host interface. You can select documents stored as PDF, XPS, TIFF or JPEG directly on the printer's control panel. No computer is required. -
Application-based profiles
The KX printer driver can create a direct link between dedicated applications and predefined or customized print profiles. You can set that all documents from a user or an application be printed in black and white with activated duplex mode as standard, thus leading to a reduced toner and paper consumption.
- Kyocera ECOSYS P6021cdn - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 29.3 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 70 mm x 148 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 26 ppm - B/W - A4 (210 x 297 mm) , Up to 26 ppm - colour - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 9600 x 600 dpi
- Max Resolution (Colour)
- 9600 x 600 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, USB host
- AirPrint Enabled
- Processor
- PowerPC 465S 667 MHz
- RAM Installed (Max)
- 512 MB (1.5 GB)
- Card Reader
- Language Simulation
- PCL 5C, PCL 6, PCL XL, KPDL3, PRESCRIBE IIe, XPS, PDF 1.7
- Barcodes
- UCC/EAN-128, EAN/JAN-8, EAN/JAN-13, PDF417
- Media Type
- Plain paper
- Total Media Capacity
- 300 sheets
- Media Handling
- 250-sheet input tray, 50-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 50000 pages
- Recommended Monthly Volume
- 1000 - 1667 pages
- Networking
- Print server
- Printer Features
- Kyocera ECOSYS Technology
- System Requirements
- UNIX, Linux, Microsoft Windows, Apple MacOS X 10.4 or later
- Environmental Standards
- EPEAT Silver
- 39 cm x 52.3 cm x 37 cm
- Printer Type
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- AirPrint Enabled
- 9600 x 600 dpi
- 9600 x 600 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 10.5 sec
- First Print Out Time Colour
- 12 sec
- Fonts Included
- 93 x scalable , 1 x bitmapped , 45 x barcode
- Barcodes
- Printer Features
- Media Handling
- Processor
RAM
- 512 MB / 1.5 GB (max)
Card Reader
- Card reader
- Supported Flash Memory Cards
- SD Memory Card, SDHC Memory Card
Media Handling
- Media Type
- Plain paper
- Media Size Class
- A4/Legal
- Max Media Size
- 70 mm x 148 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
- Media Weight
- 60 g/m² - 220 g/m²
- 300 sheets
- Media Feeders
- 1 x automatic - 50 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 500 sheets - 216 x 297 mm weight: 60 g/m² - 163 g/m²
- Max Media Capacity
- 1300 sheets
- Output Trays Capacity
- 250 sheets
Duty Cycle
- 50000 pages
- 1000 - 1667 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP 3, HTTPS, IPPS
- SSL, IPsec
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 1200 pages , 1 x toner cartridge (cyan) - up to 1200 pages , 1 x toner cartridge (magenta) - up to 1200 pages , 1 x toner cartridge (yellow) - up to 1200 pages
- TUV, ISO 9001, GS, ISO 14001, ISO 7779
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 353 Watt
- Power Consumption Stand by
- 61 Watt
- Power Consumption Sleep
- 4 Watt
- OS Required
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR
- Sound Emission (Operating)
- 48.2 dBA
- 39 cm
- 52.3 cm
- 37 cm
- 29.3 kg
