Speed up your office with this ECOSYS P5026cdn A4 color printing device. The high-performance print controller, with its 800 MHz CPU, achieves brilliant color printout results in no time. Moreover, it comes up with a short warm-up phase and reduces the time-till-first-page printing to 9.5/10.5 seconds for b/w and color. For even more productivity, the device provides USB and LAN and offers mobile printing support for professional and easy output of your documents - ideal for optimized and rapid office tasks.
- Up to 26ppm Colour Print
- Up to 26ppm Mono Print
- Up to 11 Seconds First page
- USB, Network
- Automatic Double Sided Printing
- 1200 x 1200 dpi Print
- PCL5/6 & Postscript 3
- 50 Sheet Multipurpose tray
- 800MHz Processor
- 512MB (512MB) RAM
- Windows & Mac Compatible
Toner Change:
Unboxing:
Efficient printing speeds
With the ability to print up to 26 pages per minute, both in black and white and color, the Kyocera ECOSYS P5026cdn ensures your work flows smoothly and efficiently, minimizing wait times and boosting productivity. -
High-resolution output
Achieve exceptional clarity and detail in every document with a maximum resolution of 9600 x 600 DPI. Whether printing text, graphics, or images, the Kyocera ECOSYS P5026cdn delivers sharp, vibrant results every time. -
Eco-friendly design
Designed with the environment in mind, the Kyocera ECOSYS P5026cdn features a Toner Save mode to reduce toner use and complies with ISO 14001 and ISO 9001 standards, making it a responsible choice for your office. -
Advanced connectivity options
Offering a range of connectivity options including Gigabit Ethernet, USB 2.0, and USB host, the Kyocera ECOSYS P5026cdn provides flexible and easy integration into your existing network, ensuring seamless operation and file sharing. -
Automatic duplexing
Save on paper and contribute to environmental conservation with the automatic duplexing feature. The Kyocera ECOSYS P5026cdn allows for easy two-sided printing, further enhancing its efficiency and eco-friendliness.
- Kyocera ECOSYS P5026cdn - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 21 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 70 mm x 148 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 26 ppm - B/W - A4 (210 x 297 mm) , Up to 26 ppm - colour - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 9600 x 600 dpi
- Max Resolution (Colour)
- 9600 x 600 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, USB host
- Processor
- 800 MHz
- RAM Installed (Max)
- 512 MB (512 MB)
- Card Reader
- Language Simulation
- PCL 5C, PostScript 3, PCL 6, PCL XL, KPDL3, PDF, XPS
- Barcodes
- PDF417, EAN-128, EAN-8, EAN-13
- Media Type
- Plain paper
- Total Media Capacity
- 300 sheets
- Media Handling
- 50-sheet multipurpose tray, 250-sheet paper cassette
- Networking
- Print server
- Printer Features
- Toner Save mode support
- System Requirements
- UNIX, Linux, Microsoft Windows, Apple MacOS X 10.8 or later
- 41 cm x 41 cm x 32.9 cm
- Printer Type
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- 9600 x 600 dpi
- 9600 x 600 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 9.5 sec
- First Print Out Time Colour
- 10.5 sec
- Fonts Included
- 93 x scalable , 1 x bitmapped , 45 x barcode
- Barcodes
- Printer Features
- Media Handling
- Processor
- 800 MHz
RAM
- 512 MB / 512 MB (max)
Card Reader
- Card reader
- Supported Flash Memory Cards
- SD Memory Card, SDHC Memory Card
Media Handling
- Media Type
- Plain paper
- Media Size Class
- A4/Legal
- Max Media Size
- 70 mm x 148 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
- Media Thickness Range
- Up to 0.11 mm
- Media Weight
- 60 g/m² - 220 g/m²
- 300 sheets
- Media Feeders
- 1 x automatic - 50 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
- Max Media Capacity
- 550 sheets
- Output Trays Capacity
- 150 sheets
- Networking
- Print server
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 1200 pages ISO/IEC 19752 , 1 x toner cartridge (cyan) - up to 1200 pages ISO/IEC 19798 , 1 x toner cartridge (magenta) - up to 1200 pages ISO/IEC 19798 , 1 x toner cartridge (yellow) - up to 1200 pages ISO/IEC 19798
- ISO 9001, ISO 14001, AS/NZS 3260
- Power Device
- Power supply - internal
- Frequency Required
- 50 Hz
- 375 Watt
- Power Consumption Stand by
- 33 Watt
- Power Consumption Sleep
- 0.9 Watt
- OS Required
Environmental Standards
- ENERGY STAR
- Sound Emission (Operating)
- 49 dBA
- 41 cm
- 41 cm
- 32.9 cm
- 21 kg
Ink (6)
Kyocera TK 5240K - black - original - toner cartridge | In Stock | £49.31 |
Kyocera TK 5240C - cyan - original - toner cartridge | In Stock | £73.32 |
Kyocera Black Toner Cassette 4K | In Stock | £49.31 |
Kyocera Cyan Toner Cassette 3K | In Stock | £73.32 |
Kyocera KYO Magenta Toner Cassette 3K | In Stock | £73.32 |
Kyocera KYO Yellow Toner Cassette 3K | In Stock | £73.32 |
Other bundles (1)
Kyocera 3Yr Group B Onsite Next Day Warranty | In Stock | £49.70 |
