Kyocera ECOSYS P5026cdn A4 Colour Laser Printer
Quicklinx: CHK6WS00 Mfr#: 1102RC3NL0
Type: Printer
Functionality: Printer
Output Type: Colour
Wireless Capability: Wired
Technology: Laser
£307.20 ex VAT
£368.64 inc VAT
Speed up your office with this ECOSYS P5026cdn A4 color printing device. The high-performance print controller, with its 800 MHz CPU, achieves brilliant color printout results in no time. Moreover, it comes up with a short warm-up phase and reduces the time-till-first-page printing to 9.5/10.5 seconds for b/w and color. For even more productivity, the device provides USB and LAN and offers mobile printing support for professional and easy output of your documents - ideal for optimized and rapid office tasks.
  • Up to 26ppm Colour Print
  • Up to 26ppm Mono Print
  • Up to 11 Seconds First page
  • USB, Network
  • Automatic Double Sided Printing
  • 1200 x 1200 dpi Print
  • PCL5/6 & Postscript 3
  • 50 Sheet Multipurpose tray
  • 800MHz Processor
  • 512MB (512MB) RAM
  • Windows & Mac Compatible
Toner Change:
Unboxing:
  • Efficient printing speeds
    With the ability to print up to 26 pages per minute, both in black and white and color, the Kyocera ECOSYS P5026cdn ensures your work flows smoothly and efficiently, minimizing wait times and boosting productivity.
  • High-resolution output
    Achieve exceptional clarity and detail in every document with a maximum resolution of 9600 x 600 DPI. Whether printing text, graphics, or images, the Kyocera ECOSYS P5026cdn delivers sharp, vibrant results every time.
  • Eco-friendly design
    Designed with the environment in mind, the Kyocera ECOSYS P5026cdn features a Toner Save mode to reduce toner use and complies with ISO 14001 and ISO 9001 standards, making it a responsible choice for your office.
  • Advanced connectivity options
    Offering a range of connectivity options including Gigabit Ethernet, USB 2.0, and USB host, the Kyocera ECOSYS P5026cdn provides flexible and easy integration into your existing network, ensuring seamless operation and file sharing.
  • Automatic duplexing
    Save on paper and contribute to environmental conservation with the automatic duplexing feature. The Kyocera ECOSYS P5026cdn allows for easy two-sided printing, further enhancing its efficiency and eco-friendliness.
Kyocera ECOSYS P5026cdn - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
21 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
70 mm x 148 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 26 ppm - B/W - A4 (210 x 297 mm) , Up to 26 ppm - colour - A4 (210 x 297 mm)
Max Resolution (B&W)
9600 x 600 dpi
Max Resolution (Colour)
9600 x 600 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, USB host
800 MHz
RAM Installed (Max)
512 MB (512 MB)
Card Reader
Language Simulation
PCL 5C, PostScript 3, PCL 6, PCL XL, KPDL3, PDF, XPS
Barcodes
PDF417, EAN-128, EAN-8, EAN-13
Media Type
Plain paper
Total Media Capacity
300 sheets
Media Handling
50-sheet multipurpose tray, 250-sheet paper cassette
Print server
Printer Features
Toner Save mode support
UNIX, Linux, Microsoft Windows, Apple MacOS X 10.8 or later
41 cm x 41 cm x 32.9 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
9600 x 600 dpi
9600 x 600 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
9.5 sec
First Print Out Time Colour
10.5 sec
Language Simulation
Fonts Included
93 x scalable , 1 x bitmapped , 45 x barcode
Barcodes
Printer Features
Media Handling
800 MHz
RAM
RAM Installed (Max)
512 MB / 512 MB (max)
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card, SDHC Memory Card
Media Handling
Media Type
Plain paper
Media Size Class
A4/Legal
Max Media Size
70 mm x 148 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
Media Thickness Range
Up to 0.11 mm
Media Weight
60 g/m² - 220 g/m²
300 sheets
Media Feeders
1 x automatic - 50 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
Max Media Capacity
550 sheets
Output Trays Capacity
150 sheets
Print server
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 1200 pages ISO/IEC 19752 , 1 x toner cartridge (cyan) - up to 1200 pages ISO/IEC 19798 , 1 x toner cartridge (magenta) - up to 1200 pages ISO/IEC 19798 , 1 x toner cartridge (yellow) - up to 1200 pages ISO/IEC 19798
ISO 9001, ISO 14001, AS/NZS 3260
Power supply - internal
Frequency Required
50 Hz
375 watt
Power Consumption Stand by
33 watt
Power Consumption Sleep
0.9 watt
Environmental Standards
ENERGY STAR
Sound Emission (Operating)
49 dBA
41 cm
41 cm
32.9 cm
21 kg
Type: Printer
Output Type: Colour
Technology: Laser
Max Print Speed: 26ppm
Max Paper Size: A4 (210 x 297 mm)
Brand: Kyocera
