Kyocera ECOSYS P5021cdw A4 Colour Laser Printer
Quicklinx: CHK5WS00 Mfr#: 1102RD3NL0
The ECOSYS P5021cdw entry-level A4 color printer offers more than you could ask for. Despite its compact design, this economical color device includes plenty of valuable functions and achieves professional results with a resolution of 1,200 dpi. Features such as the duplex unit for double-sided printing or the direct printing functions (via Wi-Fi and USB host) keep your work running seamlessly. This reliable device is the perfect solution for small offices that set high standards.
  • Up to 21 pages per minute in A4 in colour and b/w
  • 1,200 dpi printing quality
  • Wi-Fi and Wi-Fi Direct as standard
  • Mobile printing support including AirPrint, Mopria, KYOCERA Mobile Print
  • Compact design with low-noise printing
  • Direct printing from USB flash memory
  • Standard duplex unit for double-sided printing
  • Exceptionally low printing costs in its class
Why choose KYOCERA?
  • Efficient connectivity
    With both wired and wireless connectivity options, including Gigabit Ethernet, USB 2.0, and USB host, the Kyocera ECOSYS P5021cdw ensures seamless integration into any office environment, facilitating easy sharing among multiple users.
  • High-quality printing
    Boasting a maximum resolution of 9600 x 600 DPI for both black and white and color prints, this printer delivers sharp, vivid outputs, making it perfect for producing professional documents and marketing materials.
  • Eco-friendly design
    Certified by ENERGY STAR for its energy efficiency, the Kyocera ECOSYS P5021cdw features a Toner Save mode support, reducing toner use and helping businesses save on consumables while minimizing environmental impact.
  • Advanced media handling
    Capable of handling a wide range of media sizes and types, from A4 and Legal to plain paper, and with a total media capacity of 300 sheets, this printer meets diverse printing needs, from standard documents to special marketing materials.
  • Fast printing speeds
    With a maximum printing speed of 21 ppm for both black and white and color, and automatic duplexing, the Kyocera ECOSYS P5021cdw enhances productivity, ensuring efficient print jobs and quick turnaround times.
Kyocera ECOSYS P5021cdw - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
21 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
70 mm x 148 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 21 ppm - B/W - A4 (210 x 297 mm) , Up to 21 ppm - colour - A4 (210 x 297 mm)
Max Resolution (B&W)
9600 x 600 dpi
Max Resolution (Colour)
9600 x 600 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, USB host, Wi-Fi
800 MHz
RAM Installed (Max)
512 MB (512 MB)
Card Reader
Language Simulation
PCL 5C, PostScript 3, PCL 6, PCL XL, KPDL3, PDF, XPS
Barcodes
PDF417, EAN-128, EAN-8, EAN-13
Media Type
Plain paper
Total Media Capacity
300 sheets
Media Handling
50-sheet multipurpose tray, 250-sheet paper cassette
Print server
Printer Features
UNIX, Linux, Microsoft Windows, Apple MacOS X 10.8 or later
41 cm x 41 cm x 32.9 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wireless
9600 x 600 dpi
9600 x 600 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
11 sec
First Print Out Time Colour
12.5 sec
Language Simulation
Fonts Included
93 x scalable , 1 x bitmapped , 45 x barcode
Barcodes
Printer Features
Media Handling
800 MHz
RAM
RAM Installed (Max)
512 MB / 512 MB (max)
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card, SDHC Memory Card
Media Handling
Media Type
Plain paper
Media Size Class
A4/Legal
Max Media Size
70 mm x 148 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
Media Thickness Range
Up to 0.11 mm
Media Weight
60 g/m² - 220 g/m²
300 sheets
Media Feeders
1 x automatic - 50 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
Max Media Capacity
550 sheets
Output Trays Capacity
150 sheets
Print server
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 1200 pages ISO/IEC 19752 , 1 x toner cartridge (cyan) - up to 1200 pages ISO/IEC 19798 , 1 x toner cartridge (magenta) - up to 1200 pages ISO/IEC 19798 , 1 x toner cartridge (yellow) - up to 1200 pages ISO/IEC 19798
ISO 9001, ISO 14001, AS/NZS 3260
Power supply - internal
345 watt
Power Consumption Stand by
33 watt
Power Consumption Sleep
0.9 watt
Environmental Standards
ENERGY STAR
Limited warranty - 2 years - on-site
Sound Emission (Operating)
48 dBA
41 cm
41 cm
32.9 cm
21 kg
CHK5 Kyocera TK-5230C Cyan Toner Cassette In Stock £74.77
CHK5 Kyocera TK-5230Y Yellow Toner In Stock £74.77
CHK5 Kyocera Black Toner Cassette 2.6K In Stock £50.81
CHK5 Kyocera Cyan Toner Cassette 2.2K In Stock £74.77
CHK5 Kyocera Magenta Toner Cassette 2.2K In Stock £74.77
CHK5 Kyocera Yellow Toner Cassette 2.2K In Stock £74.77
CHK5 Kyocera TK 5220K Black Original Toner Cartridge In Stock £39.89
CHK5 Kyocera TK 5220M Magenta Original Toner Cartridge In Stock £53.86
CHK5 Kyocera TK 5220Y Yellow Original Toner Cartridge In Stock £51.29
