The ECOSYS P5021CDN entry-level A4 color printer offers more than you could ask for. Despite its compact design, this economical color device includes plenty of valuable functions and achieves professional results with a resolution of 1200 dpi. Features such as the duplex unit for double-sided printing or the direct printing functions (via USB host) keep your work running seamlessly. This reliable device is the perfect solution for small offices that set high standards.
- Up to 21 A4 pages per minute in colour and black and white
- Up to 9,600 dpi printing quality with multibit technology
- Standard duplex printing
- Mobile printing support including AirPrint
- Up to 4 paper feeders for flexible media support
- Direct printing from USB flash memory
- Low-noise printing, no noise in sleep mode
Providing small teams and demanding users with high-quality colour prints. The ECOSYS P6021cdn is a compact device with low noise output, which makes it the ideal business companion for any offi ce. It has an integrated duplex unit as standard for eff ortless double sided printing. Combined with improved energy efficiency: these features help you reduce the impact of your printing activities on the environment. Its long life components reduce waste and make this printer the reliable business companion of choice!
Toner Change:
Unboxing:
Efficient printing speeds
With the ability to print up to 21 pages per minute, both in black and white and color, the Kyocera ECOSYS P5021cdn ensures your documents are ready when you need them. -
High-resolution output
Achieve exceptional clarity with a maximum resolution of 9600 x 600 DPI, making your printed documents stand out with superior detail and vivid colors. -
Eco-friendly design
ENERGY STAR certified, the Kyocera ECOSYS P5021cdn is designed for efficiency, featuring a sleep mode power consumption of just 0.9 watts, reducing your environmental footprint while saving on energy costs. -
Advanced connectivity
Equipped with Gigabit LAN, USB 2.0, and USB host interfaces, this printer offers versatile connectivity options for seamless integration into your existing network. -
Automatic duplexing
Save on paper and contribute to environmental sustainability with the automatic duplexing feature, allowing for easy two-sided printing without manual intervention.
- Kyocera ECOSYS P5021cdn - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 21 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 70 mm x 148 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 21 ppm - B/W - A4 (210 x 297 mm) , Up to 21 ppm - colour - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 9600 x 600 dpi
- Max Resolution (Colour)
- 9600 x 600 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, USB host
- Processor
- 800 MHz
- RAM Installed (Max)
- 512 MB (512 MB)
- Card Reader
- Language Simulation
- PCL 5C, PostScript 3, PCL 6, PCL XL, KPDL3, PDF, XPS
- Barcodes
- PDF417, EAN-128, EAN-8, EAN-13
- Media Type
- Plain paper
- Total Media Capacity
- 300 sheets
- Media Handling
- 50-sheet multipurpose tray, 250-sheet paper cassette
- Networking
- Print server
- Printer Features
- Toner Save mode support
- System Requirements
- UNIX, Linux, Microsoft Windows, Apple MacOS X 10.8 or later
- 41 cm x 41 cm x 32.9 cm
- Printer Type
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- 9600 x 600 dpi
- 9600 x 600 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 11 sec
- First Print Out Time Colour
- 12.5 sec
- Fonts Included
- 93 x scalable , 1 x bitmapped , 45 x barcode
- Barcodes
- Printer Features
- Media Handling
- Processor
- 800 MHz
RAM
- 512 MB / 512 MB (max)
Card Reader
- Card reader
- Supported Flash Memory Cards
- SD Memory Card, SDHC Memory Card
Media Handling
- Media Type
- Plain paper
- Media Size Class
- A4/Legal
- Max Media Size
- 70 mm x 148 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
- Media Thickness Range
- Up to 0.11 mm
- Media Weight
- 60 g/m² - 220 g/m²
- 300 sheets
- Media Feeders
- 1 x automatic - 50 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
- Max Media Capacity
- 550 sheets
- Output Trays Capacity
- 150 sheets
- Networking
- Print server
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 1200 pages ISO/IEC 19752 , 1 x toner cartridge (cyan) - up to 1200 pages ISO/IEC 19798 , 1 x toner cartridge (magenta) - up to 1200 pages ISO/IEC 19798 , 1 x toner cartridge (yellow) - up to 1200 pages ISO/IEC 19798
- ISO 9001, ISO 14001, AS/NZS 3260
- Power Device
- Power supply - internal
- Frequency Required
- 50 Hz
- 345 watt
- Power Consumption Stand by
- 33 watt
- Power Consumption Sleep
- 0.9 watt
- OS Required
Environmental Standards
- ENERGY STAR
- Sound Emission (Operating)
- 48 dBA
- 41 cm
- 41 cm
- 32.9 cm
- 21 kg
Kyocera TK-5230C Cyan Toner Cassette | In Stock | £75.70 |
Kyocera TK-5230Y Yellow Toner | In Stock | £75.70 |
Kyocera Black Toner Cassette 2.6K | In Stock | £51.44 |
Kyocera Cyan Toner Cassette 2.2K | In Stock | £75.70 |
Kyocera Magenta Toner Cassette 2.2K | In Stock | £75.70 |
Kyocera Yellow Toner Cassette 2.2K | In Stock | £75.70 |
Kyocera TK 5220K Black Original Toner Cartridge | In Stock | £40.39 |
Kyocera TK 5220M Magenta Original Toner Cartridge | In Stock | £54.52 |
Kyocera TK 5220Y Yellow Original Toner Cartridge | In Stock | £51.92 |
