When the going gets tough, you need a printer that exceeds all expectations to help you meet your deadline. The ECOSYS P3055dn does exactly that. With a print speed of up to 55 pages per minute, a fast time to first print and a superior 1,200 dpi resolution, it satisfies even the most demanding of workgroups. The device has enhanced security features and flexible paper handling options with a maximum paper capacity of 2,600 sheets. And its long life components mean incredibly low running costs and impact on the environment.
Efficient productivity
With a first print out time of just 4.5 seconds and a high-speed processor clocked at 1.2 GHz, the Kyocera ECOSYS P3155dn ensures your work flows smoothly and efficiently, minimizing wait times and boosting productivity. -
High-quality printing
Achieve crisp, clear, and detailed monochrome prints with a maximum resolution of 1200 x 1200 DPI. Whether it's reports, documents, or banners, the quality of output is consistently impressive. -
Versatile media handling
From A6 to Legal sizes, and from plain to banner paper, the Kyocera ECOSYS P3155dn handles a wide range of media types and sizes through its 600-sheet total media capacity, including a 100-sheet multipurpose tray and a 500-sheet input tray, accommodating various printing needs. -
Eco-friendly design
ENERGY STAR certified and compliant with multiple environmental standards including ISO 14001 and RoHS, this printer not only meets your printing needs but also ensures environmental sustainability. -
Advanced connectivity
Featuring Gigabit Ethernet, USB 2.0, and USB host interfaces along with support for Apple AirPrint, Google Cloud Print, and Mopria Print Service, the Kyocera ECOSYS P3155dn offers flexible connectivity options for seamless integration into any modern workspace.
- Kyocera ECOSYS P3155dn - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 16 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm)/A4 (210 x 297 mm)
- Min Media Size (Custom)
- 70 mm x 140 mm
- Max Media Size (Custom)
- 216 mm x 915 mm
- Print Speed
- Up to 55 ppm - B/W - A4 (210 x 297 mm) , Up to 39 ppm - B/W duplex - A4 (210 x 297 mm) , Up to 82 ppm - B/W - A5 (148 x 210 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, USB host
- AirPrint Enabled
- Processor
- ARM Cortex-A9 1.2 GHz
- RAM Installed (Max)
- 512 MB (2560 MB)
- Language Simulation
- PCL 5C, PostScript 3, IBM X24E, PCL 6, PCL XL, KPDL3, XPS, EPSON LQ 850, TIFF, JPEG, PDF Direct
- Media Type
- Plain paper, banner paper
- Total Media Capacity
- 600 sheets
- Media Handling
- 100-sheet multipurpose tray, 500-sheet input tray
- Networking
- Print server
- Printer Features
- Kyocera ECOSYS Technology, Mopria certified
- 38 cm x 41 cm x 32 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Built-in Devices
- 5-line backlit LCD display
- Connectivity Technology
- Wired
- Interface
- AirPrint Enabled
- 1200 x 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 4.5 sec
- Fonts Included
- 93 x outline , 1 x bitmapped , 45 x barcode
- Printer Features
- Media Handling
- Processor
RAM
- 512 MB / 2560 MB (max)
Card Reader
- Supported Flash Memory Cards
- SDHC Memory Card
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 70 mm x 140 mm
- 216 mm x 915 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
- Media Weight
- 60 g/m² - 220 g/m²
- 600 sheets
- Media Feeders
- Multi-purpose tray: 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Paper cassette: 1 x automatic - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m²
- Max Media Capacity
- 2600 sheets
- Output Trays Capacity
- 500 sheets
- Networking
- Print server
- Remote Management Protocol
- SNMP 3, IPP
- SSL, IPsec
- Expansion Slots
- 1 x expansion slot
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 10000 pages ISO/IEC 19752
- TUV GS, ISO 9001, ISO 14001, RoHS, ISO 7779
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 675 Watt
- Power Consumption Stand by
- 11 Watt
- Power Consumption Sleep
- 0.5 Watt
Environmental Standards
- ENERGY STAR
- Sound Emission (Operating)
- 55.8 dBA
- Sound Emission (Quiet Mode)
- 51.1 dBA
- 38 cm
- 41 cm
- 32 cm
- 16 kg
Kyocera TK 3190 Black Toner Kit for ECOSYS P3055dn, | In Stock | £101.29 |
