Kyocera ECOSYS P3145dn Mono Laser Printer
Quicklinx: F9SPWS00 Mfr#: 1102TT3NL0
The P31xx ´series are very compact making then easy to accommodate on the desktop and with Gigabit networking as standard they are perfect for large and busy workgroups. Kyocera's long life image drum technology combined with large starter toners and high capacity replacement toners mean the P31xx series leads the way with very low running costs.
  • Efficient productivity
    With a robust monthly duty cycle of up to 150,000 pages, the Kyocera ECOSYS P3145dn is engineered for reliability and efficiency, suitable for high-demand environments.
  • Eco-friendly design
    Leveraging Kyocera ECOSYS Technology, this printer offers long-life components that reduce waste and provide an eco-friendly printing solution, aligning with your green initiatives.
  • Advanced connectivity
    Supporting AirPrint, Google Cloud Print, and Mopria Print Service, the Kyocera ECOSYS P3145dn offers seamless integration into your existing mobile and cloud workflows, ensuring flexibility in how and where you print.
  • High-quality printing
    Achieve sharp, clear prints with a maximum resolution of 1200 x 1200 DPI, ensuring your documents look professional with exceptional detail and clarity.
  • Secure and manageable
    Featuring advanced security protocols including IPsec and SSL, along with SNMP 3 for efficient remote management, the Kyocera ECOSYS P3145dn safeguards your data and simplifies printer administration.
Kyocera ECOSYS P3145dn - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
15.5 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm)/A4 (210 x 297 mm)
Min Media Size (Custom)
70 mm x 148 mm
Max Media Size (Custom)
216 mm x 915 mm
Print Speed
Up to 45 ppm - B/W - A4 (210 x 297 mm) , Up to 22.5 ppm - B/W duplex - A4 (210 x 297 mm) , Up to 62 ppm - B/W - A5 (148 x 210 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
ARM Cortex-A9 1.2 GHz
RAM Installed (Max)
512 MB (2560 MB)
Language Simulation
PCL 5C, PostScript 3, PCL 6, PCL XL, KPDL3, XPS, IBM ProPrinter XL24e, EPSON LQ 850, TIFF, JPEG, PDF Direct
Media Type
Plain paper
Total Media Capacity
600 sheets
Media Handling
100-sheet multipurpose tray, 500-sheet input tray
Monthly Duty Cycle (max)
150000 pages
Recommended Monthly Volume
20000 pages
Print server
Printer Features
UNIX, Linux, Microsoft Windows, Apple MacOS X 10.9 or later
38.8 cm x 41 cm x 30.8 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Built-in Devices
Status LCD
Wired
AirPrint Enabled
1200 x 1200 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
5.3 sec
Language Simulation
Fonts Included
93 x outline , 1 x bitmapped , 45 x barcode
Printer Features
Media Handling
RAM
RAM Installed (Max)
512 MB / 2560 MB (max)
Card Reader
Supported Flash Memory Cards
SDHC Memory Card
Media Handling
Media Type
Plain paper
Media Size Class
A4/Legal
Max Media Size
70 mm x 148 mm
216 mm x 915 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm)
Media Weight
60 g/m² - 220 g/m²
600 sheets
Media Feeders
1 x automatic - 100 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 500 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 120 g/m²
Max Media Capacity
2600 sheets
Output Trays Capacity
250 sheets
Duty Cycle
150000 pages
20000 pages
Print server
Remote Management Protocol
SNMP 3, IPP
Security Protocols & Features
SSL, IPsec
Expansion Slots
1 x expansion slot
1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 6000 pages ISO/IEC 19752
TUV GS, ISO 9001, ISO 14001
Power supply - internal
Frequency Required
50 Hz
594 Watt
Power Consumption Stand by
10 Watt
Power Consumption Sleep
0.5 Watt
Environmental Standards
ENERGY STAR
Sound Emission (Operating)
53.7 dBA
38.8 cm
41 cm
30.8 cm
15.5 kg
F9SP Kyocera TK 3160 Black Toner Kit for ECOSYS P3045dn In Stock £76.88
