Kyocera ECOSYS P3050dn A4 Mono Laser Printer
Quicklinx: CKF1WS00 Mfr#: 1102T83NL0
With up to 50 pages per minute print speed, fast first print times, a powerful controller, mobile print support and low running costs, the ECOSYS P3050dn will be a welcome addition to any team. It also boasts enhanced security features with card authentication, private print and hard disk protection. And as you would expect of a KYOCERA printer, the long-life components and lower energy consumption ensure this device leaves a small environmental footprint.
  • Up to 50 pages per minute A4 and A5
  • Time to first print: only 6.2 seconds
  • Standard Gigabit LAN, Wi-Fi option with Wi-Fi Direct available
  • Powerful 1.2 GHz CPU and 512 MB controller
  • Mobile Printing support for AirPrint, Mopria, KYOCERA Mobile Print
  • Double-sided and N-up printing for less paper consumption
  • 500 sheet paper output capacity for continuous printing
  • Optimal document distribution and workflow with optional Print&FollowTM*
  • Environmentally friendly: long-life components, low energy consumption
  • Exceptionally-low printing costs in its class
Finding the Serial Number:
Toner Change:
Unboxing:
  • Efficient productivity
    With a first print out time of just 6.2 seconds and a monthly duty cycle range exceeding 100,000 pages, this printer is designed to handle high-volume printing with ease, ensuring your office's productivity remains high.
  • Advanced connectivity
    Equipped with Gigabit Ethernet, USB 2.0, and USB host interfaces alongside Mopria Print Service for mobile printing capabilities, this printer offers versatile connectivity options to easily integrate into any modern office environment.
  • Robust media handling
    Supporting a wide range of media sizes up to Legal (216 x 356 mm) and weights between 60 g/m2 and 220 g/m2, this printer is capable of handling diverse printing needs, from standard documents to more demanding printing tasks.
  • High-capacity printing
    With a maximum media capacity of 2600 sheets and automatic duplexing feature, the Kyocera ECOSYS P3050DN is built to deliver large print jobs efficiently, reducing the need for frequent paper refills and supporting eco-friendly office practices.
  • Secure and reliable
    Featuring advanced security protocols including IPsec and SSL, along with HTTPS and SNMP 3 for remote management, this printer ensures your documents remain secure throughout the printing process, making it a trustworthy choice for sensitive information.
Kyocera ECOSYS P3050DN - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
15.5 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm)/A4 (210 x 297 mm)
Min Media Size (Custom)
70 mm x 148 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 50 ppm - B/W - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, USB host
1.2 GHz
RAM Installed (Max)
512 MB (2.5 GB)
Language Simulation
PCL 5C, PostScript 3, IBM X24E, PCL 6, PCL XL, KPDL3, PRESCRIBE IIe, XPS, EPSON LQ 850, PDF 1.7
Barcodes
UCC/EAN-128, EAN/JAN-8, EAN/JAN-13, PDF417
Media Type
Plain paper
Total Media Capacity
600 sheets
Media Handling
100-sheet multipurpose tray, 500-sheet input tray
Monthly Duty Cycle (max)
200000 pages
Print server
Printer Features
Kyocera ECOSYS Technology
UNIX, Linux, Microsoft Windows, Apple MacOS X 10.8 or later
1-year warranty (Germany - 2 years)
39.6 cm x 42.1 cm x 34.2 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Built-in Devices
Status LCD
Wired
1200 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
6.2 sec
Language Simulation
Fonts Included
93 x scalable , 1 x bitmapped , 45 x barcode
Barcodes
Printer Features
Media Handling
1.2 GHz
RAM
RAM Installed (Max)
512 MB / 2.5 GB (max)
Card Reader
Supported Flash Memory Cards
SDHC Memory Card
Media Handling
Media Type
Plain paper
Media Size Class
A4/Legal
Max Media Size
70 mm x 148 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
Media Weight
60 g/m² - 220 g/m²
600 sheets
Media Feeders
1 x automatic - 100 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 500 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 120 g/m²
Max Media Capacity
2600 sheets
Output Trays Capacity
500 sheets
Duty Cycle
200000 pages
Print server
Remote Management Protocol
SNMP 3, HTTPS, IPPS
Security Protocols & Features
Secure Print, SSL, IPsec
Expansion Slots
1 x expansion slot
1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 8000 pages ISO/IEC 19752
TUV GS, ISO 9001, ISO 14001, ISO 7779, ISO 9296
Power supply - internal
Frequency Required
50 Hz
636 Watt
Power Consumption Stand by
11 Watt
Power Consumption Sleep
0.9 Watt
Software Included
Google Cloud Print
Environmental Standards
ENERGY STAR
Limited warranty - 1 year , Limited warranty - drum - 3 years or 500,000 pages
Regional Warranty Exceptions
Germany - 2 years
Sound Emission (Idle)
26.9 dBA
Sound Emission (Operating)
53.2 dBA
Sound Emission (Quiet Mode)
50.8 dBA
39.6 cm
42.1 cm
34.2 cm
15.5 kg
CKF1 Kyocera TK 3160 Black Toner Kit for ECOSYS P3045dn In Stock £76.72
