A productive solution for workgroups that require a wide variety of output sizes from A6 up to A3. This fast and compact printer offers an expandable paper capacity of up to 6 paper trays for flexible paper handling. Plus this team-player knows exactly how to impress with comprehensive security features and ECOSYS long-life technology that gives you exceptionally low cost per page and less waste.
USB host interface
Documents can be printed directly from a USB flash memory via the USB host interface. The documents stored as PDF, XPS, TIFF or JPEG are selected directly via the printer's control panel. No computer is required. -
Application-based profiles
The printer driver can create a direct link between dedicated applications and predefined or customized print profiles. You can set that all documents from a user or an application be printed with activated duplex mode as standard, thus leading to a reduced paper consumption.
- Kyocera ECOSYS P2235dw - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 14 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 70 mm x 148 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 35 ppm - B/W - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, USB host, Wi-Fi
- Processor
- 800 MHz
- RAM Installed (Max)
- 256 MB (256 MB)
- Language Simulation
- PCL 5E, PostScript 3, PCL 6, PCL XL, KPDL3, PDF, PRESCRIBE IIe, XPS
- Barcodes
- PDF417
- Media Type
- Plain paper
- Total Media Capacity
- 350 sheets
- Media Handling
- 100-sheet multipurpose tray, 250-sheet input tray
- Networking
- Print server
- Printer Features
- Kyocera ECOSYS Technology
- System Requirements
- UNIX, Linux, Microsoft Windows, Apple MacOS X 10.5 or later
- 37.5 cm x 39.3 cm x 27.2 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wireless
- Interface
- 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 6.8 sec
- Fonts Included
- 93 x scalable , 45 x barcode
- Barcodes
- PDF417
- Printer Features
- Media Handling
- Processor
- 800 MHz
RAM
- 256 MB / 256 MB (max)
Card Reader
- Supported Flash Memory Cards
- SD Memory Card, SDHC Memory Card
Media Handling
- Media Type
- Plain paper
- Media Size Class
- A4/Legal
- Max Media Size
- 70 mm x 148 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), Oficio (216 x 343 mm)
- Media Weight
- 60 g/m² - 220 g/m²
- 350 sheets
- Media Feeders
- 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 250 sheets - 216 x 297 mm weight: 60 g/m² - 120 g/m²
- Max Media Capacity
- 850 sheets
- Output Trays Capacity
- 250 sheets
- Networking
- Print server
- Remote Management Protocol
- SNMP 3, HTTPS, IPPS
- SSL, IPsec
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- TUV, ISO 9001, GS, ISO 14001, ISO 7779
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 620 watt
- Power Consumption Stand by
- 8 watt
- Power Consumption Sleep
- 0.8 watt
- OS Required
Environmental Standards
- ENERGY STAR
- Sound Emission (Operating)
- 47.9 dBA
- 37.5 cm
- 39.3 cm
- 27.2 cm
- 14 kg
