A productive solution for workgroups that require a wide variety of output sizes from A6 up to A3. This fast and compact printer offers an expandable paper capacity of up to 6 paper trays for flexible paper handling. Plus this team-player knows exactly how to impress with comprehensive security features and ECOSYS long-life technology that gives you exceptionally low cost per page and less waste.
Efficient printing speed
With an output of up to 40 pages per minute, the Kyocera ECOSYS P2040dn ensures your work flows smoothly and efficiently, minimizing wait times and boosting productivity. -
Advanced connectivity options
Equipped with Gigabit Ethernet, USB 2.0, and USB host interfaces, this printer offers versatile connectivity options to easily integrate into any modern work environment, supporting a variety of devices and networks. -
Eco-friendly design
Adhering to ISO 14001, ISO 7779, and ISO 9001 standards, the Kyocera ECOSYS P2040dn is designed with sustainability in mind, ensuring reduced environmental impact while maintaining high performance. -
High-quality monochrome output
Leveraging laser printing technology, the P2040dn delivers high-resolution monochrome prints up to 1200 DPI, ensuring clear, crisp documents every time. -
Convenient media handling
Supporting a wide range of media sizes and types, including A4, Legal, and plain paper, and featuring a 350-sheet total media capacity, this printer is equipped to handle diverse printing needs with ease.
- Kyocera ECOSYS P2040dn - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 14 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 70 mm x 148 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 40 ppm - B/W - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, USB host
- Processor
- 800 MHz
- RAM Installed (Max)
- 256 MB (256 MB)
- Language Simulation
- PCL 5E, PostScript 3, PCL 6, PCL XL, KPDL3, PRESCRIBE IIe, XPS
- Barcodes
- UCC/EAN-128, EAN/JAN-8, EAN/JAN-13, PDF417
- Media Type
- Plain paper
- Total Media Capacity
- 350 sheets
- Media Handling
- 100-sheet multipurpose tray, 250-sheet input tray
- Networking
- Print server
- Printer Features
- Kyocera ECOSYS Technology
- System Requirements
- UNIX, Linux, Microsoft Windows, Apple MacOS X 10.5 or later
- 37.5 cm x 39.3 cm x 27.2 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 6.4 sec
- Fonts Included
- 80 x scalable , 1 x bitmapped , 45 x barcode
- Barcodes
- Printer Features
- Media Handling
- Processor
- 800 MHz
RAM
- 256 MB / 256 MB (max)
Card Reader
- Supported Flash Memory Cards
- SD Memory Card, SDHC Memory Card
Media Handling
- Media Type
- Plain paper
- Media Size Class
- A4/Legal
- Max Media Size
- 70 mm x 148 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), Oficio (216 x 343 mm)
- Media Weight
- 60 g/m² - 220 g/m²
- 350 sheets
- Media Feeders
- 1 x automatic - 50 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 250 sheets - 216 x 297 mm weight: 60 g/m² - 120 g/m²
- Max Media Capacity
- 850 sheets
- Output Trays Capacity
- 250 sheets
- Networking
- Print server
- Expansion Slots
- 1 x expansion slot
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
- TUV, ISO 9001, GS, ISO 14001, ISO 7779
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 620 Watt
- Power Consumption Stand by
- 8 Watt
- Power Consumption Sleep
- 0.8 Watt
- OS Required
Environmental Standards
- ENERGY STAR
- Sound Emission (Operating)
- 48.8 dBA
- 37.5 cm
- 39.3 cm
- 27.2 cm
- 14 kg
Ink (2)
Kyocera TK-1160 Black Toner - 7K | In Stock | £82.99 |
Kyocera KYO Black Toner Cassette 7.2K | In Stock | £82.94 |
Other bundles (2)
Kyocera 3Yr Group B Onsite Next Day Warranty | In Stock | £49.84 |
Kyocera PF-1100 250 Sheet Paper Feeder | In Stock | £169.97 |
