Kyocera ECOSYS MA4500fx Mono Laser Multifunction Printer
Quicklinx: H6W1WS00 Mfr#: 110C123NL0
Functionality: Copier, Scanner, Printer, Fax
Wireless Capability: Wired
Max Paper Size: Legal (216 x 356 mm)/A4 (210 x 297 mm)
Hurry, only 1 left in stock!
£1,178.72 ex VAT
£1,414.46 inc VAT
Marketing description is not available.
  • Efficient document handling
    With a RADF document feeder capable of holding up to 75 sheets and a maximum media capacity of 2600 sheets, this multifunction device ensures your office can handle large print and copy jobs with ease. Automatic duplexing across printing, copying, and scanning functions not only saves time but also reduces paper consumption.
  • High-quality printing and copying
    Achieve crisp, clear text and images with a maximum printing and copying resolution of 1200 x 1200 DPI and 600 x 600 DPI, respectively. The first print out time of just 5.3 seconds and a copying speed of up to 45 ppm means your documents are ready when you need them.
  • Advanced connectivity options
    Stay connected and productive with a variety of connectivity options including Gigabit Ethernet, USB 2.0, and USB host. Mobile printing capabilities through Apple AirPrint, Kyocera Mobile Print, Microsoft Mobile Print, and Mopria Print Service offer the flexibility to print from anywhere.
  • Reliable performance
    Designed to handle a recommended monthly volume of 3000 pages and equipped with a robust duty cycle of 6000 pages, this device is built to meet the demands of busy office environments. The inclusion of a 1 GB RAM ensures smooth processing of complex print jobs.
  • Eco-friendly design
    The Kyocera ECOSYS MA4500FX is designed with eco-friendly features, including low power consumption in sleep mode of just 0.6 W, contributing to energy savings and reducing your office's carbon footprint.
Kyocera ECOSYS MA4500FX - multifunction printer - B/W
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
150000 pages
Recommended Monthly Volume
3000 pages
Max Copying Speed
Up to 45 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 45 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
JBIG, MH, MMR, MR
Fax Resolutions
200 x 100 dpi, 200 x 200 dpi, 200 x 400 dpi, 400 x 400 dpi
Scanning
600 x 600 dpi
Original Size
A6 (105 x 148 mm) (min) - Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
Original Type
Sheets
Document Feeder Capacity
75 sheets
Media Size
70 x 140 mm (min) - Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
Media Type
Plain paper
Standard Media Capacity
675 sheets
Max Media Capacity
2600 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
250 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, USB host, Gigabit LAN
AirPrint Enabled
Office Machine Features
Scan to e-mail, scan to FTP, scan to SMB, scan to USB host
AC 230 V (50/60Hz)
47.5 cm x 47.6 cm x 57.5 cm
22.3 kg
1-year warranty
Printer Fonts
Outline x 93 , Bitmapped x 1 , Barcode x 45 , Calibri x 4 , Cambria x 4
Fax Type
Plain paper
Printing Technology
Laser - monochrome
150000 pages
3000 pages
Display
5 lines x 21 characters
Display Colour Support
Monochrome
AirPrint Enabled
Standard Memory
1 GB
Max Supported Memory
3 GB
Supported Flash Memory
SD Memory Card
Copying
Max Copying Speed
Up to 45 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Exposure Modes
Text, photo, text and photo, map
Automatic Duplexing
Copying Features
Electronic sorting, ID Card Copy, 2 on 1, 4 on 1, auto cassette change, blank page skipping
Printing
Max Printing Speed
Up to 45 ppm
Printer Drivers / Emulations
PRESCRIBE, PCL 6, PCL 5c, PCL 6 (XL), PostScript 3, KPDL3, PDF, XPS, TIFF, JPEG, URF, PWG, PCLm, IBM Proprinter, EPSON LQ-850
Automatic Duplexing
First Print Out Time B/W
5.3 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Grayscale Depth
8-bit
Scanning Resolution Details
300 x 300 dpi , 200 x 200 dpi , 600 x 600 dpi , 400 x 400 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
JBIG, MH, MMR, MR
Fax Resolutions
Reception Memory Capacity
Up to 256 pages
Fax Machine Features
Duplex Fax, poll receive
Document & Media Handling
Min Original Size
A6 (105 x 148 mm)
Max Original Size
Supported Original Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm)
Original Type
Sheets
75 sheets
Min Media Size
70 x 140 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Plain paper
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), B6 (125 x 176 mm), A6 (105 x 148 mm), ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Folio (203 x 330 mm), 70 x 140 mm
675 sheets
Max Media Capacity
2600 sheets
100 sheets
250 sheets
Multi-purpose tray - 100 sheets size: 70 x 140 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , Paper cassette - 500 sheets size: 140 x 210 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 120 g/m² , RADF - 75 sheets size: 105 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 120 g/m² , Output tray - 250 sheets size: 70 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) , ADF size: 140 x 210 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 120 g/m²
Speed Details
Printing: up to 45 ppm (A4) - B/W , Printing: up to 22.5 ppm (A4) - B/W duplex , Copying: up to 45 ppm (A4) - B/W , Copying: up to 22.5 ppm (A4) - B/W duplex , Scanning: up to 60 ipm (A4) - B/W (300 dpi) , Scanning: up to 40 ipm (A4) - colour (300 dpi) , Scanning: up to 26 ipm (A4) - B/W duplex (300 dpi) , Scanning: up to 17 ipm (A4) - colour duplex (300 dpi)
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Operating System Support
Apple Mac OS X 10.9 or later, Chrome OS, Linux, MS Windows
AC 230 V (50/60Hz)
594.1 Watt
Power Consumption Sleep
0.6 Watt
Warm-Up Time
16 sec
First Copy Out Time B/W
6 sec
Consumables Included
1 x toner cartridge (black) - up to 6000 pages - Kyocera TK-3400
TUV, GS, ISO 7779, ISO 9296
Limited warranty - 1 year
47.5 cm
47.6 cm
57.5 cm
22.3 kg
Shipping Width
60.7 cm
Shipping Depth
57 cm
Shipping Height
69.5 cm
Shipping Weight
30 kg
Sound Emission
30 dBA (idle) / 54 dBA (operating)
Functionality: Scanner
Functionality: Printer
Functionality: Fax
Brand: Kyocera
Price Range Ex VAT: £1000 - £1500
