Efficient document handling
With a RADF document feeder capable of holding up to 75 sheets and a maximum media capacity of 2600 sheets, this multifunction device ensures your office can handle large print and copy jobs with ease. Automatic duplexing across printing, copying, and scanning functions not only saves time but also reduces paper consumption. -
High-quality printing and copying
Achieve crisp, clear text and images with a maximum printing and copying resolution of 1200 x 1200 DPI and 600 x 600 DPI, respectively. The first print out time of just 5.3 seconds and a copying speed of up to 45 ppm means your documents are ready when you need them. -
Advanced connectivity options
Stay connected and productive with a variety of connectivity options including Gigabit Ethernet, USB 2.0, and USB host. Mobile printing capabilities through Apple AirPrint, Kyocera Mobile Print, Microsoft Mobile Print, and Mopria Print Service offer the flexibility to print from anywhere. -
Reliable performance
Designed to handle a recommended monthly volume of 3000 pages and equipped with a robust duty cycle of 6000 pages, this device is built to meet the demands of busy office environments. The inclusion of a 1 GB RAM ensures smooth processing of complex print jobs. -
Eco-friendly design
The Kyocera ECOSYS MA4500FX is designed with eco-friendly features, including low power consumption in sleep mode of just 0.6 W, contributing to energy savings and reducing your office's carbon footprint.
- Kyocera ECOSYS MA4500FX - multifunction printer - B/W
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 150000 pages
- Recommended Monthly Volume
- 3000 pages
- Max Copying Speed
- Up to 45 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 45 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Data Compression System
- JBIG, MH, MMR, MR
- Fax Resolutions
- 200 x 100 dpi, 200 x 200 dpi, 200 x 400 dpi, 400 x 400 dpi
- Scanning
- 600 x 600 dpi
- Original Size
- A6 (105 x 148 mm) (min) - Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 75 sheets
- Media Size
- 70 x 140 mm (min) - Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
- Media Type
- Plain paper
- Standard Media Capacity
- 675 sheets
- Max Media Capacity
- 2600 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 250 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, USB host, Gigabit LAN
- AirPrint Enabled
- Office Machine Features
- Scan to e-mail, scan to FTP, scan to SMB, scan to USB host
- Power
- AC 230 V (50/60Hz)
- 47.5 cm x 47.6 cm x 57.5 cm
- 22.3 kg
- 1-year warranty
- Printer Fonts
- Outline x 93 , Bitmapped x 1 , Barcode x 45 , Calibri x 4 , Cambria x 4
- Fax Type
- Plain paper
- Laser - monochrome
- 150000 pages
- 3000 pages
- Display
- 5 lines x 21 characters
- Display Colour Support
- Monochrome
- Interface
- AirPrint Enabled
- Standard Memory
- 1 GB
- Max Supported Memory
- 3 GB
- Supported Flash Memory
- SD Memory Card
Copying
- Max Copying Speed
- Up to 45 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Exposure Modes
- Text, photo, text and photo, map
- Copying Features
- Electronic sorting, ID Card Copy, 2 on 1, 4 on 1, auto cassette change, blank page skipping
Printing
- Up to 45 ppm
- Printer Drivers / Emulations
- PRESCRIBE, PCL 6, PCL 5c, PCL 6 (XL), PostScript 3, KPDL3, PDF, XPS, TIFF, JPEG, URF, PWG, PCLm, IBM Proprinter, EPSON LQ-850
- First Print Out Time B/W
- 5.3 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
- Grayscale Depth
- 8-bit
- Scanning Resolution Details
- 300 x 300 dpi , 200 x 200 dpi , 600 x 600 dpi , 400 x 400 dpi
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- JBIG, MH, MMR, MR
- Fax Resolutions
- Reception Memory Capacity
- Up to 256 pages
Fax Machine Features
- Duplex Fax, poll receive
Document & Media Handling
- Min Original Size
- A6 (105 x 148 mm)
- Max Original Size
- Supported Original Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm)
- Original Type
- Sheets
- 75 sheets
- Min Media Size
- 70 x 140 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Plain paper
- Supported Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), B6 (125 x 176 mm), A6 (105 x 148 mm), ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Folio (203 x 330 mm), 70 x 140 mm
- 675 sheets
- 2600 sheets
- 100 sheets
- 250 sheets
- Multi-purpose tray - 100 sheets size: 70 x 140 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , Paper cassette - 500 sheets size: 140 x 210 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 120 g/m² , RADF - 75 sheets size: 105 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 120 g/m² , Output tray - 250 sheets size: 70 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) , ADF size: 140 x 210 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 120 g/m²
- Speed Details
- Printing: up to 45 ppm (A4) - B/W , Printing: up to 22.5 ppm (A4) - B/W duplex , Copying: up to 45 ppm (A4) - B/W , Copying: up to 22.5 ppm (A4) - B/W duplex , Scanning: up to 60 ipm (A4) - B/W (300 dpi) , Scanning: up to 40 ipm (A4) - colour (300 dpi) , Scanning: up to 26 ipm (A4) - B/W duplex (300 dpi) , Scanning: up to 17 ipm (A4) - colour duplex (300 dpi)
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- Operating System Support
- Apple Mac OS X 10.9 or later, Chrome OS, Linux, MS Windows
- Voltage Required
- 594.1 watt
- Power Consumption Sleep
- 0.6 watt
- Warm-Up Time
- 16 sec
- First Copy Out Time B/W
- 6 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 6000 pages - Kyocera TK-3400
- TUV, GS, ISO 7779, ISO 9296
- Limited warranty - 1 year
- 47.5 cm
- 47.6 cm
- 57.5 cm
- 22.3 kg
- Shipping Width
- 60.7 cm
- Shipping Depth
- 57 cm
- Shipping Height
- 69.5 cm
- Shipping Weight
- 30 kg
- Sound Emission
- 30 dBA (idle) / 54 dBA (operating)
