Efficient printing capabilities
This multifunction printer can print, copy, and scan at speeds of up to 40 pages per minute while maintaining a resolution of 1200 x 1200 DPI for high-quality output. -
Robust security features
Equipped with multiple security protocols, including TLS, Kerberos, and IPsec, the MA4000x ensures safe operations in busy office environments. -
Flexible connectivity options
The printer supports various connectivity options, including USB 2.0 and Gigabit Ethernet, along with mobile printing capabilities to facilitate printing from various devices. -
User-friendly document handling
This printer features an automatic document feeder with a capacity of 50 sheets and supports a variety of media types and sizes, making it easy to manage different tasks. -
Enhanced productivity features
With its automatic duplexing capability and various copy modes such as ID card copy and multiple copies, the MA4000x promotes efficient workflows while optimizing resource usage.
- Kyocera ECOSYS MA4000x - multifunction printer - B/W
- Multifunction printer
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 80000 pages
- Recommended Monthly Volume
- 2000 pages
- Max Copying Speed
- Up to 40 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 40 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Scanning
- 600 x 600 dpi
- Original Size
- A6 (105 x 148 mm) (min) - Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 70 x 148 mm (min) - Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
- Media Type
- Plain paper, recycled paper, preprinted paper, bond paper, coloured paper, letterheaded paper, thick paper, transparencies, labels, card stock, envelopes, prepunched paper
- Standard Media Capacity
- 350 sheets
- Max Media Capacity
- 850 sheets
- Bypass Feeder Capacity
- 50 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB host, USB 2.0, Gigabit LAN
- AirPrint Enabled
- Office Machine Features
- Proof and Hold, Job Storage, Quick Copy, Private print, IPP printing, save to USB flash drive, scan to e-mail, scan to FTP, scan to network, scan to SMB, scan to USB host, embedded OCR
- Power
- AC 220-240 V (50/60Hz)
- 41.7 cm x 41.2 cm x 43.7 cm
- 19.5 kg
- 3-year warranty
- Printer Fonts
- Outline , Bitmapped x 1 , Calibri x 4 , Cambria x 4 , Barcode x 45
- Laser - monochrome
- 80000 pages
- 2000 pages
- Display
- 5 lines x 21 characters
- Display Features
- LCD display
- Interface
- AirPrint Enabled
- Standard Memory
- 1 GB
- Supported Flash Memory
- SD Memory Card, SDHC Memory Card
Copying
- Max Copying Speed
- Up to 40 ppm
- Grayscale Half-Tones
- 256
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Exposure Control
- Automatic, manual
- Exposure Modes
- Text, photo, text and photo, map, printed document
- Copying Features
- Watermark, Multiple Copy, electronic sorting, blank page skipping, 2 on 1, 4 on 1, Split Scan, auto crop to content, ID Card Copy, Borderless copy, Toner Save, economy mode, Base Colour Removal, adjustable copy density, auto colour select
Printing
- Up to 40 ppm
- Printer Drivers / Emulations
- PRESCRIBE, PCL 6 (XL), PCL 5e, PostScript 3, KPDL3, PDF 1.7, XPS, TIFF, IBM Proprinter, EPSON LQ-850, JPEG
- First Print Out Time B/W
- 6.4 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
Document & Media Handling
- Min Original Size
- A6 (105 x 148 mm)
- Max Original Size
- Supported Original Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm)
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 70 x 148 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), B6 (125 x 176 mm), A6 (105 x 148 mm), ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), 70 x 148 mm, Statement (139.7 x 215.9 mm), Oficio (215 x 335 mm)
- Supported Envelope Sizes
- Monarch (98.4 x 190.5 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm)
- 350 sheets
- 850 sheets
- 50 sheets
- 150 sheets
- Multi-purpose tray - 100 sheets size: 70 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , Paper cassette - 250 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , ADF - 50 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 160 g/m² , Output tray - 150 sheets size: 70 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm)
- Speed Details
- Printing: up to 40 ppm (A4) - B/W , Printing: up to 20 ppm (A4) - B/W duplex , Scanning: up to 40 ipm (A4) - B/W (300 dpi) , Scanning: up to 23 ipm (A4) - colour (300 dpi) , Scanning: up to 80 ipm (A4) - B/W duplex (300 dpi) , Scanning: up to 46 ipm (A4) - colour duplex (300 dpi)
- 1 x USB 2.0 - 4 pin USB Type B ¦ 1 x USB host - 4 pin USB Type A ¦ 1 x Gigabit LAN - RJ-45
- TLS 1.3 Encryption, IPsec, NTLM v2, Kerberos, IP filtering, port blocking, active directory, LDAP, TLS
- Operating System Support
- MS Windows, Apple Mac OS X 10.9 or later, Chrome OS
- Voltage Required
- 574.4 Watt
- Power Consumption Standby
- 10.8 Watt
- Power Consumption Sleep
- 0.4 Watt
- Warm-Up Time
- 19 sec
- First Copy Out Time B/W
- 6.4 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 3600 pages ISO/IEC 19752 - Kyocera TK-1270 Starter
- ISO 7779, ISO 9296, TUV-GS, ISO 9001, ISO 14001
- Limited warranty - 1 year , Limited hardware warranty - drum - 3 years / 100000 pages
- 41.7 cm
- 41.2 cm
- 43.7 cm
- 19.5 kg
- Shipping Width
- 55.5 cm
- Shipping Depth
- 54.1 cm
- Shipping Height
- 57.2 cm
- Shipping Weight
- 24 kg
- Sound Emission
- 29 dBA (idle) / 52 dBA (operating)
- 10 °C
- 32.5 °C
- 10 - 80% RH
