Kyocera ECOSYS MA4000x Mono Laser Multifunction Printer
UP TO £125 CASHBACK OR 1 YEAR WARRANTY EXTENSION AVAILABLE!
Cashback
Quicklinx: HW46WS00 Mfr#: 110C143NL0
19 In Stock
£339.67 ex VAT
£407.60 inc VAT
Marketing description is not available.
  • Efficient printing capabilities
    This multifunction printer can print, copy, and scan at speeds of up to 40 pages per minute while maintaining a resolution of 1200 x 1200 DPI for high-quality output.
  • Robust security features
    Equipped with multiple security protocols, including TLS, Kerberos, and IPsec, the MA4000x ensures safe operations in busy office environments.
  • Flexible connectivity options
    The printer supports various connectivity options, including USB 2.0 and Gigabit Ethernet, along with mobile printing capabilities to facilitate printing from various devices.
  • User-friendly document handling
    This printer features an automatic document feeder with a capacity of 50 sheets and supports a variety of media types and sizes, making it easy to manage different tasks.
  • Enhanced productivity features
    With its automatic duplexing capability and various copy modes such as ID card copy and multiple copies, the MA4000x promotes efficient workflows while optimizing resource usage.
Kyocera ECOSYS MA4000x - multifunction printer - B/W
Multifunction printer
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
80000 pages
Recommended Monthly Volume
2000 pages
Max Copying Speed
Up to 40 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 40 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Scanning
600 x 600 dpi
Original Size
A6 (105 x 148 mm) (min) - Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
70 x 148 mm (min) - Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
Media Type
Plain paper, recycled paper, preprinted paper, bond paper, coloured paper, letterheaded paper, thick paper, transparencies, labels, card stock, envelopes, prepunched paper
Standard Media Capacity
350 sheets
Max Media Capacity
850 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB host, USB 2.0, Gigabit LAN
AirPrint Enabled
Office Machine Features
Proof and Hold, Job Storage, Quick Copy, Private print, IPP printing, save to USB flash drive, scan to e-mail, scan to FTP, scan to network, scan to SMB, scan to USB host, embedded OCR
AC 220-240 V (50/60Hz)
41.7 cm x 41.2 cm x 43.7 cm
19.5 kg
3-year warranty
Printer Fonts
Outline , Bitmapped x 1 , Calibri x 4 , Cambria x 4 , Barcode x 45
Printing Technology
Laser - monochrome
80000 pages
2000 pages
Display
5 lines x 21 characters
Display Features
LCD display
AirPrint Enabled
Standard Memory
1 GB
Supported Flash Memory
SD Memory Card, SDHC Memory Card
Copying
Max Copying Speed
Up to 40 ppm
Up to 600 x 600 dpi
Grayscale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Exposure Control
Automatic, manual
Exposure Modes
Text, photo, text and photo, map, printed document
Automatic Duplexing
Copying Features
Watermark, Multiple Copy, electronic sorting, blank page skipping, 2 on 1, 4 on 1, Split Scan, auto crop to content, ID Card Copy, Borderless copy, Toner Save, economy mode, Base Colour Removal, adjustable copy density, auto colour select
Printing
Max Printing Speed
Up to 40 ppm
Printer Drivers / Emulations
PRESCRIBE, PCL 6 (XL), PCL 5e, PostScript 3, KPDL3, PDF 1.7, XPS, TIFF, IBM Proprinter, EPSON LQ-850, JPEG
Automatic Duplexing
First Print Out Time B/W
6.4 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Document & Media Handling
Min Original Size
A6 (105 x 148 mm)
Max Original Size
Supported Original Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm)
Original Type
Sheets
50 sheets
Min Media Size
70 x 148 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), B6 (125 x 176 mm), A6 (105 x 148 mm), ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), 70 x 148 mm, Statement (139.7 x 215.9 mm), Oficio (215 x 335 mm)
Supported Envelope Sizes
Monarch (98.4 x 190.5 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm)
350 sheets
Max Media Capacity
850 sheets
50 sheets
150 sheets
Multi-purpose tray - 100 sheets size: 70 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , Paper cassette - 250 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , ADF - 50 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 160 g/m² , Output tray - 150 sheets size: 70 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm)
Speed Details
Printing: up to 40 ppm (A4) - B/W , Printing: up to 20 ppm (A4) - B/W duplex , Scanning: up to 40 ipm (A4) - B/W (300 dpi) , Scanning: up to 23 ipm (A4) - colour (300 dpi) , Scanning: up to 80 ipm (A4) - B/W duplex (300 dpi) , Scanning: up to 46 ipm (A4) - colour duplex (300 dpi)
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
TLS 1.3 Encryption, IPsec, NTLM v2, Kerberos, IP filtering, port blocking, active directory, LDAP, TLS
Operating System Support
MS Windows, Apple Mac OS X 10.9 or later, Chrome OS
574.4 Watt
Power Consumption Standby
10.8 Watt
Power Consumption Sleep
0.4 Watt
Warm-Up Time
19 sec
First Copy Out Time B/W
6.4 sec
Consumables Included
1 x toner cartridge (black) - up to 3600 pages ISO/IEC 19752 - Kyocera TK-1270 Starter
ISO 7779, ISO 9296, TUV-GS, ISO 9001, ISO 14001
Limited warranty - 1 year , Limited hardware warranty - drum - 3 years / 100000 pages
41.7 cm
41.2 cm
43.7 cm
19.5 kg
Shipping Width
55.5 cm
Shipping Depth
54.1 cm
Shipping Height
57.2 cm
Shipping Weight
24 kg
Sound Emission
29 dBA (idle) / 52 dBA (operating)
10 °C
32.5 °C
10 - 80% RH
Type: Printer / copier / scanner
Functionality: Copier
Functionality: Printer
Functionality: Scanner
Max Paper Size: Legal (216 x 356 mm)/A4 (210 x 297 mm)
Brand: Kyocera
