Kyocera ECOSYS MA4000fx Mono Laser Multifunction Printer
Quicklinx: HW47WS00 Mfr#: 110C1B3NL0
Hurry, only 1 left in stock!
£508.03 ex VAT
£609.63 inc VAT
Marketing description is not available.
  • Versatile connectivity options
    Equipped with USB 2.0, Gigabit LAN, and USB host, the Kyocera ECOSYS MA4000fx provides a variety of connectivity methods to suit different work environments, enhancing flexibility and productivity.
  • High-volume performance
    With a monthly duty cycle of 80,000 pages and a recommended monthly volume of 2,000 pages, this device is built to handle extensive workload demands efficiently.
  • Comprehensive copying features
    This multifunction device offers numerous copying features, such as automatic duplexing, ID card copy, and adjustable copy density, providing customizable options to meet various document needs.
  • Efficient scanning capabilities
    Designed for efficiency, the Kyocera ECOSYS MA4000fx can achieve scanning speeds of up to 80 ipm, with optical resolution up to 600 x 600 DPI, making it suitable for scanning multiple documents quickly.
  • Robust security protocols
    Incorporating advanced security measures like Kerberos, TLS, IPsec, and more, the device protects sensitive information and ensures secure printing in any environment.
Kyocera ECOSYS MA4000fx - multifunction printer - B/W
Multifunction printer
Fax Type
Super G3
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
80000 pages
Recommended Monthly Volume
2000 pages
Max Copying Speed
Up to 40 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 40 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
JBIG, MH, MMR, MR
Fax Resolutions
200 x 100 dpi, 200 x 200 dpi, 200 x 400 dpi, 400 x 400 dpi
Scanning
600 x 600 dpi
Original Size
A6 (105 x 148 mm) (min) - Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
70 x 148 mm (min) - Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
Media Type
Plain paper, recycled paper, preprinted paper, bond paper, coloured paper, letterheaded paper, thick paper, transparencies, labels, card stock, envelopes, prepunched paper
Standard Media Capacity
350 sheets
Max Media Capacity
850 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB host, USB 2.0, Gigabit LAN
AirPrint Enabled
Office Machine Features
Proof and Hold, Job Storage, Quick Copy, Private print, IPP printing, save to USB flash drive, scan to e-mail, scan to FTP, scan to network, scan to SMB, scan to USB host, embedded OCR, Network fax server
AC 220-240 V (50/60Hz)
41.7 cm x 41.2 cm x 43.7 cm
19.5 kg
3-year warranty
Printer Fonts
Outline , Bitmapped x 1 , Calibri x 4 , Cambria x 4 , Barcode x 45
Printing Technology
Laser - monochrome
80000 pages
2000 pages
Display
5 lines x 21 characters
Display Features
LCD display
AirPrint Enabled
Standard Memory
1 GB
Supported Flash Memory
SD Memory Card, SDHC Memory Card
Copying
Max Copying Speed
Up to 40 ppm
Up to 600 x 600 dpi
Grayscale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Exposure Control
Automatic, manual
Exposure Modes
Text, photo, text and photo, map, printed document
Automatic Duplexing
Copying Features
Watermark, Multiple Copy, electronic sorting, blank page skipping, 2 on 1, 4 on 1, Split Scan, auto crop to content, ID Card Copy, Borderless copy, Toner Save, economy mode, Base Colour Removal, adjustable copy density, auto colour select
Printing
Max Printing Speed
Up to 40 ppm
Printer Drivers / Emulations
PRESCRIBE, PCL 6 (XL), PCL 5e, PostScript 3, KPDL3, PDF 1.7, XPS, TIFF, IBM Proprinter, EPSON LQ-850, JPEG
Automatic Duplexing
First Print Out Time B/W
6.4 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
JBIG, MH, MMR, MR
Fax Resolutions
Reception Memory Capacity
Up to 256 pages
Fax Machine Features
Remote Fax Retrieval (Polling)
Duplex Fax, fax forwarding, direct fax
Document & Media Handling
Min Original Size
A6 (105 x 148 mm)
Max Original Size
Supported Original Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm)
Original Type
Sheets
50 sheets
Min Media Size
70 x 148 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), B6 (125 x 176 mm), A6 (105 x 148 mm), ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), 70 x 148 mm, Statement (139.7 x 215.9 mm), Oficio (215 x 335 mm)
Supported Envelope Sizes
Monarch (98.4 x 190.5 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm)
350 sheets
Max Media Capacity
850 sheets
50 sheets
150 sheets
Multi-purpose tray - 100 sheets size: 70 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , Paper cassette - 250 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , ADF - 50 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 160 g/m² , Output tray - 150 sheets size: 70 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm)
Speed Details
Printing: up to 40 ppm (A4) - B/W , Printing: up to 20 ppm (A4) - B/W duplex , Scanning: up to 40 ipm (A4) - B/W (300 dpi) , Scanning: up to 23 ipm (A4) - colour (300 dpi) , Scanning: up to 80 ipm (A4) - B/W duplex (300 dpi) , Scanning: up to 46 ipm (A4) - colour duplex (300 dpi)
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
TLS 1.3 Encryption, IPsec, NTLM v2, Kerberos, IP filtering, port blocking, active directory, LDAP, TLS
Operating System Support
MS Windows, Apple Mac OS X 10.9 or later, Chrome OS
574.4 Watt
Power Consumption Standby
10.8 Watt
Power Consumption Sleep
0.4 Watt
Warm-Up Time
19 sec
First Copy Out Time B/W
6.4 sec
Consumables Included
1 x toner cartridge (black) - up to 3600 pages ISO/IEC 19752 - Kyocera TK-1270 Starter
ISO 7779, ISO 9296, TUV-GS, ISO 9001, ISO 14001
Limited warranty - 1 year , Limited hardware warranty - drum - 3 years / 100000 pages
41.7 cm
41.2 cm
43.7 cm
19.5 kg
Shipping Width
55.5 cm
Shipping Depth
54.1 cm
Shipping Height
57.2 cm
Shipping Weight
24 kg
Sound Emission
29 dBA (idle) / 52 dBA (operating)
10 °C
32.5 °C
10 - 80% RH
Functionality: Scanner
Functionality: Copier
Functionality: Printer
Functionality: Fax
Max Paper Size: Legal (216 x 356 mm)/A4 (210 x 297 mm)
Brand: Kyocera
Price Range Ex VAT: £500 - £750
