                Versatile connectivity optionsEquipped with USB 2.0, Gigabit LAN, and USB host, the Kyocera ECOSYS MA4000fx provides a variety of connectivity methods to suit different work environments, enhancing flexibility and productivity.
                High-volume performanceWith a monthly duty cycle of 80,000 pages and a recommended monthly volume of 2,000 pages, this device is built to handle extensive workload demands efficiently.
                Comprehensive copying featuresThis multifunction device offers numerous copying features, such as automatic duplexing, ID card copy, and adjustable copy density, providing customizable options to meet various document needs.
                Efficient scanning capabilitiesDesigned for efficiency, the Kyocera ECOSYS MA4000fx can achieve scanning speeds of up to 80 ipm, with optical resolution up to 600 x 600 DPI, making it suitable for scanning multiple documents quickly.
                Robust security protocolsIncorporating advanced security measures like Kerberos, TLS, IPsec, and more, the device protects sensitive information and ensures secure printing in any environment.
- Kyocera ECOSYS MA4000fx - multifunction printer - B/W
- Multifunction printer
- Fax Type
- Super G3
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 80000 pages
- Recommended Monthly Volume
- 2000 pages
- Max Copying Speed
- Up to 40 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 40 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Data Compression System
- JBIG, MH, MMR, MR
- Fax Resolutions
- 200 x 100 dpi, 200 x 200 dpi, 200 x 400 dpi, 400 x 400 dpi
- Scanning
- 600 x 600 dpi
- Original Size
- A6 (105 x 148 mm) (min) - Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 70 x 148 mm (min) - Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
- Media Type
- Plain paper, recycled paper, preprinted paper, bond paper, coloured paper, letterheaded paper, thick paper, transparencies, labels, card stock, envelopes, prepunched paper
- Standard Media Capacity
- 350 sheets
- Max Media Capacity
- 850 sheets
- Bypass Feeder Capacity
- 50 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB host, USB 2.0, Gigabit LAN
- AirPrint Enabled
- Office Machine Features
- Proof and Hold, Job Storage, Quick Copy, Private print, IPP printing, save to USB flash drive, scan to e-mail, scan to FTP, scan to network, scan to SMB, scan to USB host, embedded OCR, Network fax server
- Power
- AC 220-240 V (50/60Hz)
- 41.7 cm x 41.2 cm x 43.7 cm
- 19.5 kg
- 3-year warranty
- Printer Fonts
- Outline , Bitmapped x 1 , Calibri x 4 , Cambria x 4 , Barcode x 45
- Laser - monochrome
- 80000 pages
- 2000 pages
- Display
- 5 lines x 21 characters
- Display Features
- LCD display
- Interface
- AirPrint Enabled
- Standard Memory
- 1 GB
- Supported Flash Memory
- SD Memory Card, SDHC Memory Card
Copying
- Max Copying Speed
- Up to 40 ppm
- Grayscale Half-Tones
- 256
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Exposure Control
- Automatic, manual
- Exposure Modes
- Text, photo, text and photo, map, printed document
- Copying Features
- Watermark, Multiple Copy, electronic sorting, blank page skipping, 2 on 1, 4 on 1, Split Scan, auto crop to content, ID Card Copy, Borderless copy, Toner Save, economy mode, Base Colour Removal, adjustable copy density, auto colour select
Printing
- Up to 40 ppm
- Printer Drivers / Emulations
- PRESCRIBE, PCL 6 (XL), PCL 5e, PostScript 3, KPDL3, PDF 1.7, XPS, TIFF, IBM Proprinter, EPSON LQ-850, JPEG
- First Print Out Time B/W
- 6.4 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- JBIG, MH, MMR, MR
- Fax Resolutions
- Reception Memory Capacity
- Up to 256 pages
Fax Machine Features
- Remote Fax Retrieval (Polling)
- Duplex Fax, fax forwarding, direct fax
Document & Media Handling
- Min Original Size
- A6 (105 x 148 mm)
- Max Original Size
- Supported Original Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm)
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 70 x 148 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), B6 (125 x 176 mm), A6 (105 x 148 mm), ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), 70 x 148 mm, Statement (139.7 x 215.9 mm), Oficio (215 x 335 mm)
- Supported Envelope Sizes
- Monarch (98.4 x 190.5 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm)
- 350 sheets
- 850 sheets
- 50 sheets
- 150 sheets
- Multi-purpose tray - 100 sheets size: 70 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , Paper cassette - 250 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , ADF - 50 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 160 g/m² , Output tray - 150 sheets size: 70 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm)
- Speed Details
- Printing: up to 40 ppm (A4) - B/W , Printing: up to 20 ppm (A4) - B/W duplex , Scanning: up to 40 ipm (A4) - B/W (300 dpi) , Scanning: up to 23 ipm (A4) - colour (300 dpi) , Scanning: up to 80 ipm (A4) - B/W duplex (300 dpi) , Scanning: up to 46 ipm (A4) - colour duplex (300 dpi)
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- TLS 1.3 Encryption, IPsec, NTLM v2, Kerberos, IP filtering, port blocking, active directory, LDAP, TLS
- Operating System Support
- MS Windows, Apple Mac OS X 10.9 or later, Chrome OS
- Voltage Required
- 574.4 Watt
- Power Consumption Standby
- 10.8 Watt
- Power Consumption Sleep
- 0.4 Watt
- Warm-Up Time
- 19 sec
- First Copy Out Time B/W
- 6.4 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 3600 pages ISO/IEC 19752 - Kyocera TK-1270 Starter
- ISO 7779, ISO 9296, TUV-GS, ISO 9001, ISO 14001
- Limited warranty - 1 year , Limited hardware warranty - drum - 3 years / 100000 pages
- 41.7 cm
- 41.2 cm
- 43.7 cm
- 19.5 kg
- Shipping Width
- 55.5 cm
- Shipping Depth
- 54.1 cm
- Shipping Height
- 57.2 cm
- Shipping Weight
- 24 kg
- Sound Emission
- 29 dBA (idle) / 52 dBA (operating)
- 10 °C
- 32.5 °C
- 10 - 80% RH
