The Kyocera ECOSYS MA4000CIX multifunction printer is a versatile and efficient solution for any office environment. It offers a comprehensive suite of features designed to enhance productivity and streamline workflow. With its advanced connectivity options, including Gigabit Ethernet, USB 2.0, and extensive mobile printing capabilities, this device ensures easy integration into your existing network. The MA4000CIX also features automatic duplexing, high-quality printing and scanning resolutions, and robust document handling capabilities, supporting a wide range of media sizes and types. Its eco-friendly design, characterized by low power consumption and compliance with environmental standards, makes it a responsible choice for businesses looking to reduce their environmental impact. Whether you're printing, scanning, or copying, the Kyocera ECOSYS MA4000CIX is engineered to meet the demands of modern workplaces, offering reliability, efficiency, and superior performance.
Efficient connectivity
With a wide range of connectivity options including Gigabit Ethernet, USB 2.0, and USB host, alongside mobile printing capabilities such as Apple AirPrint, Kyocera Mobile Print, Microsoft Mobile Print, and Mopria Print Service, this device ensures seamless integration into any work environment. -
Advanced copying features
The Kyocera ECOSYS MA4000CIX boasts automatic duplexing, multiple copying features like 2 on 1, 4 on 1, ID Card Copy, and electronic sorting, enhancing productivity and efficiency in document management. -
High-quality printing and scanning
Experience superior printing and scanning with up to 1200 x 1200 DPI resolution for both color and B/W, automatic duplexing, and fast first print out times. The device supports a variety of media sizes and types, catering to all your office needs. -
Robust document handling
Equipped with a dual scan document feeder (DSDF), the device can handle up to 2210 sheets, supporting a wide range of media sizes and weights. This robust document handling capability ensures smooth operation for large jobs. -
Eco-friendly and user-friendly design
The Kyocera ECOSYS MA4000CIX is designed with the environment and user in mind, featuring a low power consumption sleep mode, a user-friendly 7" touchscreen display, and compliance with multiple environmental standards.
- Kyocera ECOSYS MA4000CIX - multifunction printer - colour
- Multifunction printer
- Printing Technology
- Laser (colour)
- Max Copying Speed
- Up to 40 ppm (mono) / up to 40 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
- Scanning
- 600 x 600 dpi
- Display
- 7"
- Original Size
- A6 (105 x 148 mm) (min) - Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 100 sheets
- Media Size
- 70 x 140 mm (min) - 216 x 356 mm (max)
- Media Type
- Plain paper
- Standard Media Capacity
- 250 sheets
- Max Media Capacity
- 2210 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 250 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- AirPrint Enabled
- Office Machine Features
- Scan to e-mail, scan to FTP, scan to network, scan to SMB, scan to USB host, HyPAS (Hybrid Platform for Advanced Solutions)
- Power
- AC 220-240 V (50/60Hz)
- 48 cm x 57.75 cm x 57.15 cm
- 39 kg
- 1-year warranty
- Printer Fonts
- Outline x 93 , Bitmapped x 1 , Barcode x 45 , Cambria x 4 , Calibri x 4
- Laser - colour
- Display Diagonal Size
- 7"
- Display Colour Support
- Display Features
- Touch screen, speaker
- Interface
- AirPrint Enabled
- Standard Memory
- 2 GB
- Max Supported Memory
- 3 GB
- Supported Flash Memory
- SD Memory Card
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Exposure Modes
- Text, photo, text and photo, map
- Copying Features
- Electronic sorting, ID Card Copy, 2 on 1, 4 on 1, auto cassette change, blank page skipping, auto crop to content
Printing
- Printer Drivers / Emulations
- PRESCRIBE, PCL 6, PCL 5c, PCL 6 (XL), PostScript 3, KPDL3, PDF, XPS, TIFF, JPEG, URF, PWG, PCLm
- First Print Out Time B/W
- 5.4 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
- Scanning Resolution Details
- 300 x 300 dpi , 200 x 200 dpi , 200 x 100 dpi , 600 x 600 dpi , 400 x 400 dpi , 200 x 400 dpi , 1200 x 1200 dpi
Document & Media Handling
- Min Original Size
- A6 (105 x 148 mm)
- Max Original Size
- Supported Original Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm), ANSI A (Letter) (216 x 279 mm)/Legal (216 x 356 mm)
- Original Type
- Sheets
- 100 sheets
- Min Media Size
- 70 x 140 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Plain paper
- Supported Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), B6 (125 x 176 mm), A6 (105 x 148 mm), ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Folio (203 x 330 mm), 70 x 140 mm
- 250 sheets
- 2210 sheets
- 100 sheets
- 250 sheets
- Multi-purpose tray - 100 sheets size: 70 x 140 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , Paper cassette - 250 sheets size: 105 x 140 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , ADF size: 140 x 210 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Output tray - 250 sheets , DSDF - 100 sheets size: 105 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 120 g/m²
- Speed Details
- Printing: up to 40 ppm (A4) - B/W , Printing: up to 40 ppm (A4) - colour , Printing: up to 20 ppm (A4) - B/W duplex , Printing: up to 20 ppm (A4) - colour duplex , Copying: up to 17.5 ppm (A4) - B/W duplex , Copying: up to 17.5 ppm (A4) - colour duplex , Scanning: up to 60 ipm (A4) - B/W (300 dpi) , Scanning: up to 50 ipm (A4) - colour (300 dpi) , Scanning: up to 120 ipm (A4) - B/W duplex (300 dpi) , Scanning: up to 100 ipm (A4) - colour duplex (300 dpi)
- 1 x USB 2.0 - 4 pin USB Type B ¦ 2 x USB host - 4 pin USB Type A ¦ 1 x Gigabit LAN - RJ-45
- Operating System Support
- Apple Mac OS X 10.9 or later, Chrome OS, Linux, MS Windows
- Voltage Required
- Power Consumption Sleep
- 0.5 Watt
- Warm-Up Time
- 26 sec
- First Copy Out Time B/W
- 5.8 sec
- First Copy Out Time Colour
- 6.2 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 6000 pages , 1 x toner cartridge (yellow) - up to 5000 pages , 1 x toner cartridge (magenta) - up to 5000 pages , 1 x toner cartridge (cyan) - up to 5000 pages
- TUV, GS, ISO 7779, ISO 9296, ISO 14001
- Limited warranty - 1 year
- 48 cm
- 57.75 cm
- 57.15 cm
- 39 kg
- Shipping Width
- 62.3 cm
- Shipping Depth
- 72.8 cm
- Shipping Height
- 78.9 cm
- Shipping Weight
- 51 kg
- Sound Emission
- 30 dB (idle) / 53 dB (operating)
