Kyocera ECOSYS MA4000cix Colour Laser Multifunction Printer
Quicklinx: J12BWS00 Mfr#: 1102Z43NL0
£976.55 ex VAT
£1,171.86 inc VAT
The Kyocera ECOSYS MA4000CIX multifunction printer is a versatile and efficient solution for any office environment. It offers a comprehensive suite of features designed to enhance productivity and streamline workflow. With its advanced connectivity options, including Gigabit Ethernet, USB 2.0, and extensive mobile printing capabilities, this device ensures easy integration into your existing network. The MA4000CIX also features automatic duplexing, high-quality printing and scanning resolutions, and robust document handling capabilities, supporting a wide range of media sizes and types. Its eco-friendly design, characterized by low power consumption and compliance with environmental standards, makes it a responsible choice for businesses looking to reduce their environmental impact. Whether you're printing, scanning, or copying, the Kyocera ECOSYS MA4000CIX is engineered to meet the demands of modern workplaces, offering reliability, efficiency, and superior performance.
  • Efficient connectivity
    With a wide range of connectivity options including Gigabit Ethernet, USB 2.0, and USB host, alongside mobile printing capabilities such as Apple AirPrint, Kyocera Mobile Print, Microsoft Mobile Print, and Mopria Print Service, this device ensures seamless integration into any work environment.
  • Advanced copying features
    The Kyocera ECOSYS MA4000CIX boasts automatic duplexing, multiple copying features like 2 on 1, 4 on 1, ID Card Copy, and electronic sorting, enhancing productivity and efficiency in document management.
  • High-quality printing and scanning
    Experience superior printing and scanning with up to 1200 x 1200 DPI resolution for both color and B/W, automatic duplexing, and fast first print out times. The device supports a variety of media sizes and types, catering to all your office needs.
  • Robust document handling
    Equipped with a dual scan document feeder (DSDF), the device can handle up to 2210 sheets, supporting a wide range of media sizes and weights. This robust document handling capability ensures smooth operation for large jobs.
  • Eco-friendly and user-friendly design
    The Kyocera ECOSYS MA4000CIX is designed with the environment and user in mind, featuring a low power consumption sleep mode, a user-friendly 7" touchscreen display, and compliance with multiple environmental standards.
Kyocera ECOSYS MA4000CIX - multifunction printer - colour
Multifunction printer
Printing Technology
Laser (colour)
Max Copying Speed
Up to 40 ppm (mono) / up to 40 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
Scanning
600 x 600 dpi
Display
7"
Original Size
A6 (105 x 148 mm) (min) - Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
Original Type
Sheets
Document Feeder Capacity
100 sheets
Media Size
70 x 140 mm (min) - 216 x 356 mm (max)
Media Type
Plain paper
Standard Media Capacity
250 sheets
Max Media Capacity
2210 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
250 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
Office Machine Features
Scan to e-mail, scan to FTP, scan to network, scan to SMB, scan to USB host, HyPAS (Hybrid Platform for Advanced Solutions)
AC 220-240 V (50/60Hz)
48 cm x 57.75 cm x 57.15 cm
39 kg
1-year warranty
Printer Fonts
Outline x 93 , Bitmapped x 1 , Barcode x 45 , Cambria x 4 , Calibri x 4
Printing Technology
Laser - colour
Display Diagonal Size
7"
Display Colour Support
Display Features
Touch screen, speaker
AirPrint Enabled
Standard Memory
2 GB
Max Supported Memory
3 GB
Supported Flash Memory
SD Memory Card
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Exposure Modes
Text, photo, text and photo, map
Automatic Duplexing
Copying Features
Electronic sorting, ID Card Copy, 2 on 1, 4 on 1, auto cassette change, blank page skipping, auto crop to content
Printing
Max Printing Speed
Printer Drivers / Emulations
PRESCRIBE, PCL 6, PCL 5c, PCL 6 (XL), PostScript 3, KPDL3, PDF, XPS, TIFF, JPEG, URF, PWG, PCLm
Automatic Duplexing
First Print Out Time B/W
5.4 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Scanning Resolution Details
300 x 300 dpi , 200 x 200 dpi , 200 x 100 dpi , 600 x 600 dpi , 400 x 400 dpi , 200 x 400 dpi , 1200 x 1200 dpi
Document & Media Handling
Min Original Size
A6 (105 x 148 mm)
Max Original Size
Supported Original Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm), ANSI A (Letter) (216 x 279 mm)/Legal (216 x 356 mm)
Original Type
Sheets
100 sheets
Min Media Size
70 x 140 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Plain paper
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), B6 (125 x 176 mm), A6 (105 x 148 mm), ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Folio (203 x 330 mm), 70 x 140 mm
250 sheets
Max Media Capacity
2210 sheets
100 sheets
250 sheets
Multi-purpose tray - 100 sheets size: 70 x 140 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , Paper cassette - 250 sheets size: 105 x 140 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , ADF size: 140 x 210 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Output tray - 250 sheets , DSDF - 100 sheets size: 105 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 120 g/m²
Speed Details
Printing: up to 40 ppm (A4) - B/W , Printing: up to 40 ppm (A4) - colour , Printing: up to 20 ppm (A4) - B/W duplex , Printing: up to 20 ppm (A4) - colour duplex , Copying: up to 17.5 ppm (A4) - B/W duplex , Copying: up to 17.5 ppm (A4) - colour duplex , Scanning: up to 60 ipm (A4) - B/W (300 dpi) , Scanning: up to 50 ipm (A4) - colour (300 dpi) , Scanning: up to 120 ipm (A4) - B/W duplex (300 dpi) , Scanning: up to 100 ipm (A4) - colour duplex (300 dpi)
1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Operating System Support
Apple Mac OS X 10.9 or later, Chrome OS, Linux, MS Windows
Power Consumption Sleep
0.5 Watt
Warm-Up Time
26 sec
First Copy Out Time B/W
5.8 sec
First Copy Out Time Colour
6.2 sec
Consumables Included
1 x toner cartridge (black) - up to 6000 pages , 1 x toner cartridge (yellow) - up to 5000 pages , 1 x toner cartridge (magenta) - up to 5000 pages , 1 x toner cartridge (cyan) - up to 5000 pages
TUV, GS, ISO 7779, ISO 9296, ISO 14001
Limited warranty - 1 year
48 cm
57.75 cm
57.15 cm
39 kg
Shipping Width
62.3 cm
Shipping Depth
72.8 cm
Shipping Height
78.9 cm
Shipping Weight
51 kg
Sound Emission
30 dB (idle) / 53 dB (operating)
Brand: Kyocera
Price Range Ex VAT: £750 - £1000
