Kyocera ECOSYS MA3501wfx Mono Laser Multifunction Printer
Quicklinx: J5TYWS00 Mfr#: 110C3C3NL0
Hurry, only 1 left in stock!
£357.63 ex VAT
£429.15 inc VAT
Featuring Wi-Fi Direct, mobile printing capabilities, and upgraded memory, the MA3501wfx is a productivity powerhouse tailored for modern workplaces. This multifunctional printer ensures outstanding quality while keeping printing costs to a minimum.
  • Efficient printing technology
    The Kyocera ECOSYS MA3501wfx utilizes laser printing technology to produce high-quality monochrome prints, ensuring clarity and precision for professional documents.
  • Advanced document handling
    This printer features a robust automatic document feeder (ADF) with a capacity of 50 sheets, allowing for efficient multi-page scanning and copying without manual intervention.
  • Multiple connectivity options
    Equipped with USB 2.0, Gigabit Ethernet, and Wi-Fi connectivity, the MA3501wfx facilitates easy integration into various network environments, enhancing collaboration among users.
  • Varied media support
    Supporting a wide range of media sizes from A6 to Legal, this printer provides flexibility for different printing needs, accommodating various paper types and formats.
  • User-friendly interface
    The intuitive 4.3-inch touchscreen simplifies navigation, making it easy for users to access all functions including copying, scanning, and faxing for improved productivity.
Kyocera ECOSYS MA3501wfx - multifunction printer - B/W
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
50000 pages
Recommended Monthly Volume
2000
Max Copying Speed
Up to 35 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 35 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
JBIG, MH, MMR, MR
Fax Resolutions
200 x 100 dpi, 200 x 200 dpi, 200 x 350 dpi, 350 x 350 dpi
Scanning
600 x 600 dpi
Display
4.3"
Original Size
70 x 148 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
70 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper
Standard Media Capacity
350 sheets
Max Media Capacity
850 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, Wi-Fi, USB host
AirPrint Enabled
Office Machine Features
Proof and Hold, Job Storage, Quick Copy, Private print, Authentication Password Encryption, EcoPrint, IPP printing, print from e-mail, scan to e-mail, scan to FTP, scan to PC, scan to USB host, scan to WSD
AC 220-240 V (50/60Hz)
41.7 cm x 41.2 cm x 43.7 cm
19 kg
1-year warranty
Printer Fonts
Outline x 93 , Calibri x 4 , Cambria x 4 , Bitmapped x 1 , Barcode x 128
Fax Type
Plain paper
Printing Technology
Laser - monochrome
50000 pages
2000
Display Diagonal Size
4.3"
Display Colour Support
Display Features
Touch screen
AirPrint Enabled
Standard Memory
2 GB
Supported Flash Memory
SD Memory Card, SDHC Memory Card
Copying
Max Copying Speed
Up to 35 ppm
Up to 600 x 600 dpi
Max Document Enlargement
350%
Max Document Reduction
25%
Maximum Copies
999
Exposure Modes
Text, photo, text and photo, map
Automatic Duplexing
Copying Features
Electronic sorting, blank page skipping, line skip, duplex copy, 2 on 1, 4 on 1, split mode, DP auto cropping, ID Card Copy, folded corner detection, continuous scan, priority override, Toner Save, specific color removal, border erase, auto paper select, auto background density adjustment, manual background density adjustment, auto reduction, manual reduction, auto enlargement, manual enlargement
Printing
Max Printing Speed
Up to 35 ppm
Automatic Duplexing
First Print Out Time B/W
6.4 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
JBIG, MH, MMR, MR
Fax Resolutions
Document & Media Handling
Min Original Size
70 x 148 mm
Max Original Size
Supported Original Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm)
Original Type
Sheets
50 sheets
Min Media Size
70 x 148 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Plain paper
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), B6 (125 x 176 mm), A6 (105 x 148 mm), ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), 70 x 148 mm
350 sheets
Max Media Capacity
850 sheets
150 sheets
Multi-purpose tray - 100 sheets size: 70 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Paper cassette - 250 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , ADF - 50 sheets size: 100 x 148 mm - Legal (216 x 356 mm) weight: 50 g/m² - 160 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 35 ppm (A4) - B/W , Scanning: up to 40 ppm (A4) - B/W , Scanning: up to 23 ppm (A4) - colour
1 x USB 2.0 , 1 x USB host , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
Wi-Fi Direct
Operating System Support
MS Windows, Apple Mac OS X 10.9 or later, Chrome OS
Software Included
OKI Universal Scanner Driver (TWAIN), OKI Universal Scanner Driver (WIA)
534.4 Watt
Power Consumption Standby
11.8 Watt
Power Consumption Sleep
0.4 Watt
Warm-Up Time
29 sec
Consumables Included
1 x toner cartridge (black) - up to 1000 pages
ISO 7779, ISO 9296, GS, TUV, ISO 9001, ISO 14001
Limited warranty - 1 year , Limited warranty - drum - 3 years / 85000 pages , Limited warranty - developer - 3 years / 85000 pages
41.7 cm
41.2 cm
43.7 cm
19 kg
Shipping Width
55.5 cm
Shipping Depth
54.1 cm
Shipping Height
43.7 cm
Shipping Weight
24 kg
Sound Emission
29 dBA (idle) / 52 dBA (operating)
Functionality: Copier
Functionality: Printer
Functionality: Scanner
Functionality: Fax
Max Paper Size: A4 (210 x 297 mm)
Brand: Kyocera
