Designed to meet the diverse needs of medium and large-sized companies, the ECOSYS MA3500fx is a flexible device that provides an all-in-one solution to increase productivity at a low running cost. With a very short wait time to first print, users enjoy fast, reliable, and efficient printing for less.
                Efficient printing capabilityThe MA3500fx prints at a maximum resolution of 1200 x 1200 DPI, delivering sharp and clear text along with vibrant graphics, suitable for both professional documents and presentations.
                High-speed copyingWith a maximum copying speed of 35 pages per minute and various exposure modes, including text and photo, this device provides flexible copying solutions for diverse document requirements.
                Robust fax functionalitiesThis model features high-speed fax capability with a maximum transmission speed of 33.6 Kbps, ensuring quick and reliable document deliveries. It also supports network server fax enablement for increased operational efficiency.
                Versatile media handlingThe MA3500fx can accommodate various media sizes from A6 to Legal, with a standard media capacity of 350 sheets and a maximum capacity of 850 sheets, allowing for prolonged printing without frequent reloads.
                User-friendly interfaceEquipped with a clear LCD display that shows up to 5 lines of text, the device offers intuitive access to functions, settings, and job statuses, enhancing overall user experience.
- Kyocera ECOSYS MA3500fx - multifunction printer - B/W
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 50000 pages
- Recommended Monthly Volume
- 2000 pages
- Max Copying Speed
- Up to 35 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 35 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Data Compression System
- JBIG, MMR, MR, MH
- Fax Resolutions
- 200 x 100 dpi, 200 x 200 dpi, 200 x 400 dpi, 400 x 400 dpi
- Scanning
- 600 x 600 dpi
- Original Size
- A6 (105 x 148 mm) (min) - Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
- Original Type
- Sheets
- Media Size
- 70 x 148 mm (min) - Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
- Media Type
- Plain paper
- Standard Media Capacity
- 350 sheets
- Max Media Capacity
- 850 sheets
- Bypass Feeder Capacity
- 50 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- Office Machine Features
- Proof and Hold, Job Storage, Quick Copy, Private print, IPP printing, save to USB flash drive, scan to e-mail, scan to FTP, scan to network, scan to SMB, scan to USB host, embedded OCR, Network fax server
- Power
- AC 220-240 V (50/60Hz)
- 41.7 cm x 41.2 cm x 43.7 cm
- 19 kg
- 1-year warranty
- Printer Fonts
- Outline x 93 , Bitmapped x 1 , Barcode x 45 , Calibri x 4 , Cambria x 4
- Fax Type
- Plain paper
- Laser - monochrome
- 50000 pages
- 2000 pages
- Display
- 5 lines x 21 characters
- Display Features
- LCD display
- Interface
- Standard Memory
- 1 GB
- Supported Flash Memory
- SD Memory Card, SDHC Memory Card
Copying
- Max Copying Speed
- Up to 35 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Exposure Control
- Automatic, manual
- Exposure Modes
- Text and photo, text, photo, map, printed document
- Copying Features
- Blank page skipping, 2 on 1, 4 on 1, Split Scan, ID Card Copy, auto crop to content, folded corner detection, economy mode, Base Colour Removal, adjustable copy density, auto colour select
Printing
- Up to 35 ppm
- Printer Drivers / Emulations
- PRESCRIBE, PCL 5e, PCL 6 (XL), KPDL3, PostScript 3, PDF 1.7, XPS, TIFF, IBM Proprinter, EPSON LQ-850, JPEG
- First Print Out Time B/W
- 6.4 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- JBIG, MMR, MR, MH
- Fax Resolutions
- Reception Memory Capacity
- Up to 300 pages
Fax Machine Features
- Remote Fax Retrieval (Polling)
- Fax polling, Duplex Fax, network server fax enablement, memory reception, fax forwarding, direct fax
Document & Media Handling
- Min Original Size
- A6 (105 x 148 mm)
- Max Original Size
- Supported Original Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm)
- Original Type
- Sheets
- Min Media Size
- 70 x 148 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Plain paper
- Supported Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), B6 (125 x 176 mm), A6 (105 x 148 mm), ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), 70 x 148 mm, Statement (139.7 x 215.9 mm), Oficio (215 x 335 mm)
- 350 sheets
- 850 sheets
- 50 sheets
- 150 sheets
- Multi-purpose tray - 100 sheets size: 70 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , Paper cassette - 250 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Output tray - 150 sheets size: 70 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) , ADF - 50 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 160 g/m²
- Speed Details
- Printing: up to 35 ppm (A4) - B/W , Printing: up to 17.5 ppm (A4) - B/W duplex
- 1 x USB 2.0 , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- TLS 1.3 Encryption, IPsec
- Operating System Support
- MS Windows, Apple Mac OS X 10.9 or later, Chrome OS
- Voltage Required
- 534.4 Watt
- Power Consumption Standby
- 10.8 Watt
- Power Consumption Sleep
- 0.4 Watt
- Warm-Up Time
- 19 sec
- First Copy Out Time B/W
- 7.4 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 1000 pages ISO/IEC 19752 - Kyocera TK-1250 Starter
- ISO 7779, ISO 9296, TUV-GS, ISO 9001, ISO 14001
- Limited warranty - 1 year , Limited hardware warranty - drum - 3 years / 85000 pages
- 41.7 cm
- 41.2 cm
- 43.7 cm
- 19 kg
- Shipping Width
- 55.5 cm
- Shipping Depth
- 54.1 cm
- Shipping Height
- 57.2 cm
- Shipping Weight
- 24 kg
- Sound Emission
- 29 dBA (idle) / 52 dBA (operating)
