Designed to meet the diverse needs of medium and large-sized companies, the ECOSYS MA3500fx is a flexible device that provides an all-in-one solution to increase productivity at a low running cost. With a very short wait time to first print, users enjoy fast, reliable, and efficient printing for less.
Efficient printing capability
The MA3500fx prints at a maximum resolution of 1200 x 1200 DPI, delivering sharp and clear text along with vibrant graphics, suitable for both professional documents and presentations. -
High-speed copying
With a maximum copying speed of 35 pages per minute and various exposure modes, including text and photo, this device provides flexible copying solutions for diverse document requirements. -
Robust fax functionalities
This model features high-speed fax capability with a maximum transmission speed of 33.6 Kbps, ensuring quick and reliable document deliveries. It also supports network server fax enablement for increased operational efficiency. -
Versatile media handling
The MA3500fx can accommodate various media sizes from A6 to Legal, with a standard media capacity of 350 sheets and a maximum capacity of 850 sheets, allowing for prolonged printing without frequent reloads. -
User-friendly interface
Equipped with a clear LCD display that shows up to 5 lines of text, the device offers intuitive access to functions, settings, and job statuses, enhancing overall user experience.
 - Kyocera ECOSYS MA3500fx - multifunction printer - B/W
 - Multifunction printer
- Fax Type
 - Super G3 - plain paper
- Printing Technology
 - Laser (monochrome)
- Monthly Duty Cycle (max)
 - 50000 pages
- Recommended Monthly Volume
 - 2000 pages
- Max Copying Speed
 - Up to 35 ppm
- Max Copying Resolution
 - Up to 600 x 600 dpi
- Max Printing Speed
 - Up to 35 ppm
- Max Printing Resolution
 - Up to 1200 x 1200 dpi
- Max Fax Transmission Speed
 - 33.6 Kbps
- Data Compression System
 - JBIG, MMR, MR, MH
- Fax Resolutions
 - 200 x 100 dpi, 200 x 200 dpi, 200 x 400 dpi, 400 x 400 dpi
- Scanning
 - 600 x 600 dpi
- Original Size
 - A6 (105 x 148 mm) (min) - Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
- Original Type
 - Sheets
- Media Size
 - 70 x 148 mm (min) - Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
- Media Type
 - Plain paper
- Standard Media Capacity
 - 350 sheets
- Max Media Capacity
 - 850 sheets
- Bypass Feeder Capacity
 - 50 sheets
- Output Trays Capacity
 - 150 sheets
- Automatic Duplexing
 - Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
 - USB 2.0, Gigabit LAN, USB host
- Office Machine Features
 - Proof and Hold, Job Storage, Quick Copy, Private print, IPP printing, save to USB flash drive, scan to e-mail, scan to FTP, scan to network, scan to SMB, scan to USB host, embedded OCR, Network fax server
- Power
 - AC 220-240 V (50/60Hz)
 - 41.7 cm x 41.2 cm x 43.7 cm
 - 19 kg
 - 1-year warranty
- Printer Fonts
 - Outline x 93 , Bitmapped x 1 , Barcode x 45 , Calibri x 4 , Cambria x 4
- Fax Type
 - Plain paper
 - Laser - monochrome
 - 50000 pages
 - 2000 pages
- Display
 - 5 lines x 21 characters
- Display Features
 - LCD display
- Interface
- Standard Memory
 - 1 GB
- Supported Flash Memory
 - SD Memory Card, SDHC Memory Card
Copying
- Max Copying Speed
 - Up to 35 ppm
- Max Document Enlargement
 - 400%
- Max Document Reduction
 - 25%
- Maximum Copies
 - 999
- Exposure Control
 - Automatic, manual
- Exposure Modes
 - Text and photo, text, photo, map, printed document
- Copying Features
 - Blank page skipping, 2 on 1, 4 on 1, Split Scan, ID Card Copy, auto crop to content, folded corner detection, economy mode, Base Colour Removal, adjustable copy density, auto colour select
Printing
 - Up to 35 ppm
- Printer Drivers / Emulations
 - PRESCRIBE, PCL 5e, PCL 6 (XL), KPDL3, PostScript 3, PDF 1.7, XPS, TIFF, IBM Proprinter, EPSON LQ-850, JPEG
- First Print Out Time B/W
 - 6.4 sec
Scanning
- Optical Resolution
 - 600 x 600 dpi
Fax Machine
- Compatibility
 - Super G3
- Max Transmission Speed
 - 33.6 Kbps
 - JBIG, MMR, MR, MH
- Fax Resolutions
- Reception Memory Capacity
 - Up to 300 pages
Fax Machine Features
- Remote Fax Retrieval (Polling)
 - Fax polling, Duplex Fax, network server fax enablement, memory reception, fax forwarding, direct fax
Document & Media Handling
- Min Original Size
 - A6 (105 x 148 mm)
- Max Original Size
- Supported Original Sizes
 - A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm)
- Original Type
 - Sheets
- Min Media Size
 - 70 x 148 mm
- Max Media Size
 - A4/Legal
- Min Media Weight
 - 60 g/m²
- Max Media Weight
 - 220 g/m²
- Supported Media Type
 - Plain paper
- Supported Media Sizes
 - A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), B6 (125 x 176 mm), A6 (105 x 148 mm), ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), 70 x 148 mm, Statement (139.7 x 215.9 mm), Oficio (215 x 335 mm)
 - 350 sheets
 - 850 sheets
 - 50 sheets
 - 150 sheets
 - Multi-purpose tray - 100 sheets size: 70 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , Paper cassette - 250 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Output tray - 150 sheets size: 70 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) , ADF - 50 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 160 g/m²
- Speed Details
 - Printing: up to 35 ppm (A4) - B/W , Printing: up to 17.5 ppm (A4) - B/W duplex
 - 1 x USB 2.0 , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
 - TLS 1.3 Encryption, IPsec
- Operating System Support
 - MS Windows, Apple Mac OS X 10.9 or later, Chrome OS
- Voltage Required
 - 534.4 Watt
- Power Consumption Standby
 - 10.8 Watt
- Power Consumption Sleep
 - 0.4 Watt
- Warm-Up Time
 - 19 sec
- First Copy Out Time B/W
 - 7.4 sec
- Consumables Included
 - 1 x toner cartridge (black) - up to 1000 pages ISO/IEC 19752 - Kyocera TK-1250 Starter
 - ISO 7779, ISO 9296, TUV-GS, ISO 9001, ISO 14001
 - Limited warranty - 1 year , Limited hardware warranty - drum - 3 years / 85000 pages
 - 41.7 cm
 - 41.2 cm
 - 43.7 cm
 - 19 kg
- Shipping Width
 - 55.5 cm
- Shipping Depth
 - 54.1 cm
- Shipping Height
 - 57.2 cm
- Shipping Weight
 - 24 kg
- Sound Emission
 - 29 dBA (idle) / 52 dBA (operating)
