Kyocera ECOSYS MA3500fx Mono Laser Multifunction Printer
Quicklinx: J5TXWS00 Mfr#: 110C3F3NL0
£332.64 ex VAT
£399.16 inc VAT
Designed to meet the diverse needs of medium and large-sized companies, the ECOSYS MA3500fx is a flexible device that provides an all-in-one solution to increase productivity at a low running cost. With a very short wait time to first print, users enjoy fast, reliable, and efficient printing for less.
  • Efficient printing capability
    The MA3500fx prints at a maximum resolution of 1200 x 1200 DPI, delivering sharp and clear text along with vibrant graphics, suitable for both professional documents and presentations.
  • High-speed copying
    With a maximum copying speed of 35 pages per minute and various exposure modes, including text and photo, this device provides flexible copying solutions for diverse document requirements.
  • Robust fax functionalities
    This model features high-speed fax capability with a maximum transmission speed of 33.6 Kbps, ensuring quick and reliable document deliveries. It also supports network server fax enablement for increased operational efficiency.
  • Versatile media handling
    The MA3500fx can accommodate various media sizes from A6 to Legal, with a standard media capacity of 350 sheets and a maximum capacity of 850 sheets, allowing for prolonged printing without frequent reloads.
  • User-friendly interface
    Equipped with a clear LCD display that shows up to 5 lines of text, the device offers intuitive access to functions, settings, and job statuses, enhancing overall user experience.
Kyocera ECOSYS MA3500fx - multifunction printer - B/W
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
50000 pages
Recommended Monthly Volume
2000 pages
Max Copying Speed
Up to 35 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 35 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
JBIG, MMR, MR, MH
Fax Resolutions
200 x 100 dpi, 200 x 200 dpi, 200 x 400 dpi, 400 x 400 dpi
Scanning
600 x 600 dpi
Original Size
A6 (105 x 148 mm) (min) - Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
Original Type
Sheets
Media Size
70 x 148 mm (min) - Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
Media Type
Plain paper
Standard Media Capacity
350 sheets
Max Media Capacity
850 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB host
Office Machine Features
Proof and Hold, Job Storage, Quick Copy, Private print, IPP printing, save to USB flash drive, scan to e-mail, scan to FTP, scan to network, scan to SMB, scan to USB host, embedded OCR, Network fax server
AC 220-240 V (50/60Hz)
41.7 cm x 41.2 cm x 43.7 cm
19 kg
1-year warranty
Printer Fonts
Outline x 93 , Bitmapped x 1 , Barcode x 45 , Calibri x 4 , Cambria x 4
Fax Type
Plain paper
Printing Technology
Laser - monochrome
50000 pages
2000 pages
Display
5 lines x 21 characters
Display Features
LCD display
Standard Memory
1 GB
Supported Flash Memory
SD Memory Card, SDHC Memory Card
Copying
Max Copying Speed
Up to 35 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Exposure Control
Automatic, manual
Exposure Modes
Text and photo, text, photo, map, printed document
Automatic Duplexing
Copying Features
Blank page skipping, 2 on 1, 4 on 1, Split Scan, ID Card Copy, auto crop to content, folded corner detection, economy mode, Base Colour Removal, adjustable copy density, auto colour select
Printing
Max Printing Speed
Up to 35 ppm
Printer Drivers / Emulations
PRESCRIBE, PCL 5e, PCL 6 (XL), KPDL3, PostScript 3, PDF 1.7, XPS, TIFF, IBM Proprinter, EPSON LQ-850, JPEG
Automatic Duplexing
First Print Out Time B/W
6.4 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
JBIG, MMR, MR, MH
Fax Resolutions
Reception Memory Capacity
Up to 300 pages
Fax Machine Features
Remote Fax Retrieval (Polling)
Fax polling, Duplex Fax, network server fax enablement, memory reception, fax forwarding, direct fax
Document & Media Handling
Min Original Size
A6 (105 x 148 mm)
Max Original Size
Supported Original Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm)
Original Type
Sheets
Min Media Size
70 x 148 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Plain paper
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), B6 (125 x 176 mm), A6 (105 x 148 mm), ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), 70 x 148 mm, Statement (139.7 x 215.9 mm), Oficio (215 x 335 mm)
350 sheets
Max Media Capacity
850 sheets
50 sheets
150 sheets
Multi-purpose tray - 100 sheets size: 70 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , Paper cassette - 250 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Output tray - 150 sheets size: 70 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) , ADF - 50 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 160 g/m²
Speed Details
Printing: up to 35 ppm (A4) - B/W , Printing: up to 17.5 ppm (A4) - B/W duplex
1 x USB 2.0 , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
TLS 1.3 Encryption, IPsec
Operating System Support
MS Windows, Apple Mac OS X 10.9 or later, Chrome OS
534.4 Watt
Power Consumption Standby
10.8 Watt
Power Consumption Sleep
0.4 Watt
Warm-Up Time
19 sec
First Copy Out Time B/W
7.4 sec
Consumables Included
1 x toner cartridge (black) - up to 1000 pages ISO/IEC 19752 - Kyocera TK-1250 Starter
ISO 7779, ISO 9296, TUV-GS, ISO 9001, ISO 14001
Limited warranty - 1 year , Limited hardware warranty - drum - 3 years / 85000 pages
41.7 cm
41.2 cm
43.7 cm
19 kg
Shipping Width
55.5 cm
Shipping Depth
54.1 cm
Shipping Height
57.2 cm
Shipping Weight
24 kg
Sound Emission
29 dBA (idle) / 52 dBA (operating)
Functionality: Printer
Functionality: Scanner
Functionality: Copier
Max Paper Size: Legal (216 x 356 mm)/A4 (210 x 297 mm)
Brand: Kyocera
