This compact, A4/A3 format colour multifunctional, designed to meet the requirements of small offices and workgroups, will satisfy even the most demanding environment. Engineered with KYOCERA's renowned longlife components, this ECOSYS device ensures unprecedented reliability and exceptionally low printing costs with significantly less environmental impact.
Efficient connectivity
With a range of interface options including Gigabit Ethernet, NFC, USB 2.0, and USB host, alongside mobile printing capabilities like Apple AirPrint, Google Cloud Print, and Mopria Print Service, this device ensures seamless integration into any modern workspace. -
Advanced security
Equipped with robust security protocols including IPsec, SSL, and Wi-Fi Direct, the Kyocera ECOSYS M8130cidn safeguards sensitive information, making it a suitable choice for environments where data protection is important. -
High-quality printing
Boasting a maximum printing resolution of 1200 x 1200 DPI for both black and white and color documents, this printer delivers crisp, clear, and vibrant prints every time. -
Versatile media handling
From small A6 (105 x 148 mm) to large A3 (297 x 420 mm) sizes, the printer accommodates a wide range of media sizes and types, including plain paper, with a maximum media capacity of 1600 sheets, catering to diverse printing needs. -
Eco-friendly design
ENERGY STAR certification ensures that the Kyocera ECOSYS M8130cidn is not only efficient in performance but also in energy consumption, aligning with eco-friendly business practices.
- Kyocera ECOSYS M8130cidn - multifunction printer - colour
- Multifunction printer
- Printing Technology
- Laser (colour)
- Max Copying Speed
- Up to 30 ppm (mono) / up to 30 ppm (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
- Scanning
- 600 x 600 dpi
- Display
- 7"
- Original Size
- A3 (297 x 420 mm), Ledger (279 x 432 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 98 x 148 mm (min) - A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm) (max)
- Media Type
- Plain paper
- Standard Media Capacity
- 600 sheets
- Max Media Capacity
- 1600 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 280 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host, NFC
- AirPrint Enabled
- Office Machine Features
- Scan to e-mail, HyPAS (Hybrid Platform for Advanced Solutions), Kyocera ECOSYS Technology, scan to FTP, scan to SMB, scan to USB host
- Power
- AC 230 V (50/60Hz)
- 59 cm x 59 cm x 75.3 cm
- 79 kg
- Environmental Standards
- ENERGY STAR Qualified
- Laser - colour
- Display Diagonal Size
- 7"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Standard Memory
- 1.5 GB
- Max Supported Memory
- 3 GB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Exposure Modes
- Text, photo, text and photo, map
- Copying Features
- 2 on 1, 4 on 1, ID Card Copy, electronic sorting, Scan-once-copy-many
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, KPDL3, PCL 6 (XL), PDF, XPS, PRESCRIBE IIc
- First Print Out Time B/W
- 6.5 sec
- First Print Out Time Colour
- 8.3 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 98 x 148 mm
- Max Media Size
- A3/Ledger
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 256 g/m²
- Supported Media Type
- Plain paper
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), Folio (216 x 330 mm)
- 600 sheets
- 1600 sheets
- 100 sheets
- 280 sheets
- Input tray - 500 sheets - A3 (297 x 420 mm) weight: 60 g/m² - 256 g/m² , Bypass tray - 100 sheets size: 98 x 148 mm - A3 (297 x 420 mm) weight: 60 g/m² - 256 g/m² , ADF - 50 sheets size: 140 x 182 mm - A3 (297 x 420 mm) weight: 45 g/m² - 160 g/m² , Output tray - 250 sheets , Job separator tray - 30 sheets
- Speed Details
- Printing: up to 30 ppm (A4) - B/W , Printing: up to 30 ppm (A4) - colour , Copying: up to 30 ppm (A4) - B/W , Copying: up to 30 ppm (A4) - colour , Printing: up to 15 ppm (A3) - B/W , Printing: up to 15 ppm (A3) - colour , Printing: up to 26 ppm (A4) - B/W duplex , Printing: up to 26 ppm (A4) - colour duplex , Copying: up to 26 ppm (A4) - B/W duplex , Copying: up to 26 ppm (A4) - colour duplex , Scanning: up to 50 ipm (A4) - B/W (300 dpi) , Scanning: up to 50 ipm (A4) - colour (300 dpi)
- 1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- SSL, IPsec, Wi-Fi Direct
- Operating System Support
- UNIX, Linux, Apple Mac OS X 10.5 or later, MS Windows
- Voltage Required
- 600 Watt
- Power Consumption Standby
- 70 Watt
- Power Consumption Sleep
- 0.5 Watt
- Warm-Up Time
- 30 sec
- First Copy Out Time B/W
- 6.5 sec
- First Copy Out Time Colour
- 8.3 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 3000 pages ISO/IEC 19798 , 1 x toner cartridge (cyan) - up to 1500 pages ISO/IEC 19798 , 1 x toner cartridge (magenta) - up to 1500 pages ISO/IEC 19798 , 1 x toner cartridge (yellow) - up to 1500 pages ISO/IEC 19798
- TUV, ISO 9001, GS
- ENERGY STAR Certified
- 59 cm
- 59 cm
- 75.3 cm
- 79 kg
- Sound Emission
- 34 dBA (idle) / 54 dBA (operating)
Ink (4)
Kyocera TK 8115C Cyan Toner Kit for ECOSYS M8124cidn & ECOSYS M8130cidn | In Stock | £54.17 |
Kyocera TK 8115K Black Toner Kit for ECOSYS M8124cidn & ECOSYS M8130cidn | In Stock | £69.97 |
Kyocera TK 8115M Magenta Toner Kit for ECOSYS M8124cidn & ECOSYS M8130cidn | In Stock | £54.17 |
Kyocera TK 8115Y Yellow Toner Kit for M8124cidn & ECOSYS M8130cidn | In Stock | £54.17 |
Other bundles (1)
Kyocera pf-470 500 Sheet Drawer | In Stock | £399.65 |
