Kyocera ECOSYS M8130cidn Colour Laser Multifunction Printer
Quicklinx: DD7TWS00 Mfr#: 1102P33NL0
Hurry, only 2 left in stock!
£3,150.38 ex VAT
£3,780.45 inc VAT
This compact, A4/A3 format colour multifunctional, designed to meet the requirements of small offices and workgroups, will satisfy even the most demanding environment. Engineered with KYOCERA's renowned longlife components, this ECOSYS device ensures unprecedented reliability and exceptionally low printing costs with significantly less environmental impact.
  • Efficient connectivity
    With a range of interface options including Gigabit Ethernet, NFC, USB 2.0, and USB host, alongside mobile printing capabilities like Apple AirPrint, Google Cloud Print, and Mopria Print Service, this device ensures seamless integration into any modern workspace.
  • Advanced security
    Equipped with robust security protocols including IPsec, SSL, and Wi-Fi Direct, the Kyocera ECOSYS M8130cidn safeguards sensitive information, making it a suitable choice for environments where data protection is important.
  • High-quality printing
    Boasting a maximum printing resolution of 1200 x 1200 DPI for both black and white and color documents, this printer delivers crisp, clear, and vibrant prints every time.
  • Versatile media handling
    From small A6 (105 x 148 mm) to large A3 (297 x 420 mm) sizes, the printer accommodates a wide range of media sizes and types, including plain paper, with a maximum media capacity of 1600 sheets, catering to diverse printing needs.
  • Eco-friendly design
    ENERGY STAR certification ensures that the Kyocera ECOSYS M8130cidn is not only efficient in performance but also in energy consumption, aligning with eco-friendly business practices.
Kyocera ECOSYS M8130cidn - multifunction printer - colour
Multifunction printer
Printing Technology
Laser (colour)
Max Copying Speed
Up to 30 ppm (mono) / up to 30 ppm (colour)
Max Printing Speed
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
Scanning
600 x 600 dpi
Display
7"
Original Size
A3 (297 x 420 mm), Ledger (279 x 432 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
98 x 148 mm (min) - A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm) (max)
Media Type
Plain paper
Standard Media Capacity
600 sheets
Max Media Capacity
1600 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
280 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB host, NFC
AirPrint Enabled
Office Machine Features
Scan to e-mail, HyPAS (Hybrid Platform for Advanced Solutions), Kyocera ECOSYS Technology, scan to FTP, scan to SMB, scan to USB host
AC 230 V (50/60Hz)
59 cm x 59 cm x 75.3 cm
79 kg
Environmental Standards
ENERGY STAR Qualified
Printing Technology
Laser - colour
Display Diagonal Size
7"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
1.5 GB
Max Supported Memory
3 GB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Exposure Modes
Text, photo, text and photo, map
Automatic Duplexing
Copying Features
2 on 1, 4 on 1, ID Card Copy, electronic sorting, Scan-once-copy-many
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, KPDL3, PCL 6 (XL), PDF, XPS, PRESCRIBE IIc
Automatic Duplexing
First Print Out Time B/W
6.5 sec
First Print Out Time Colour
8.3 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
98 x 148 mm
Max Media Size
A3/Ledger
Min Media Weight
60 g/m²
Max Media Weight
256 g/m²
Supported Media Type
Plain paper
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), Folio (216 x 330 mm)
600 sheets
Max Media Capacity
1600 sheets
100 sheets
280 sheets
Input tray - 500 sheets - A3 (297 x 420 mm) weight: 60 g/m² - 256 g/m² , Bypass tray - 100 sheets size: 98 x 148 mm - A3 (297 x 420 mm) weight: 60 g/m² - 256 g/m² , ADF - 50 sheets size: 140 x 182 mm - A3 (297 x 420 mm) weight: 45 g/m² - 160 g/m² , Output tray - 250 sheets , Job separator tray - 30 sheets
Speed Details
Printing: up to 30 ppm (A4) - B/W , Printing: up to 30 ppm (A4) - colour , Copying: up to 30 ppm (A4) - B/W , Copying: up to 30 ppm (A4) - colour , Printing: up to 15 ppm (A3) - B/W , Printing: up to 15 ppm (A3) - colour , Printing: up to 26 ppm (A4) - B/W duplex , Printing: up to 26 ppm (A4) - colour duplex , Copying: up to 26 ppm (A4) - B/W duplex , Copying: up to 26 ppm (A4) - colour duplex , Scanning: up to 50 ipm (A4) - B/W (300 dpi) , Scanning: up to 50 ipm (A4) - colour (300 dpi)
1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
SSL, IPsec, Wi-Fi Direct
Operating System Support
UNIX, Linux, Apple Mac OS X 10.5 or later, MS Windows
AC 230 V (50/60Hz)
600 Watt
Power Consumption Standby
70 Watt
Power Consumption Sleep
0.5 Watt
Warm-Up Time
30 sec
First Copy Out Time B/W
6.5 sec
First Copy Out Time Colour
8.3 sec
Consumables Included
1 x toner cartridge (black) - up to 3000 pages ISO/IEC 19798 , 1 x toner cartridge (cyan) - up to 1500 pages ISO/IEC 19798 , 1 x toner cartridge (magenta) - up to 1500 pages ISO/IEC 19798 , 1 x toner cartridge (yellow) - up to 1500 pages ISO/IEC 19798
TUV, ISO 9001, GS
ENERGY STAR Certified
59 cm
59 cm
75.3 cm
79 kg
Sound Emission
34 dBA (idle) / 54 dBA (operating)
DD7T Kyocera TK 8115C Cyan Toner Kit for ECOSYS M8124cidn & ECOSYS M8130cidn In Stock £54.61
DD7T Kyocera TK 8115K Black Toner Kit for ECOSYS M8124cidn & ECOSYS M8130cidn In Stock £64.56
DD7T Kyocera TK 8115M Magenta Toner Kit for ECOSYS M8124cidn & ECOSYS M8130cidn In Stock £54.61
DD7T Kyocera TK 8115Y Yellow Toner Kit for M8124cidn & ECOSYS M8130cidn In Stock £54.61
Type: Printer / copier / scanner
Functionality: Copier
Functionality: Printer
Functionality: Scanner
Max Paper Size: ANSI B (Ledger) (279 x 432 mm)
Max Paper Size: A3 (297 x 420 mm)
Brand: Kyocera
Price Range Ex VAT: £1500+
