This compact, A4/A3 format colour multifunctional, designed to meet the requirements of small offices and workgroups, will satisfy even the most demanding environment. Engineered with KYOCERA's renowned longlife components, this ECOSYS device ensures unprecedented reliability and exceptionally low printing costs with significantly less environmental impact.
- Kyocera ECOSYS M8124cidn - multifunction printer - colour
- Multifunction printer
- Printing Technology
- Laser (colour)
- Max Copying Speed
- Up to 24 ppm (mono) / up to 24 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
- Scanning
- 600 x 600 dpi
- Display
- 4.3"
- Original Size
- A3/Ledger (297 x 432 mm) (max)
- Original Type
- Sheets
- Media Size
- 98 x 148 mm (min) - A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm) (max)
- Media Type
- Plain paper
- Standard Media Capacity
- 100 sheets
- Max Media Capacity
- 1600 sheets
- Output Trays Capacity
- 280 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- AirPrint Enabled
- Office Machine Features
- Scan to e-mail, scan to network, HyPAS (Hybrid Platform for Advanced Solutions), scan to FTP, scan to SMB, scan to USB host
- Power
- AC 230 V (50/60Hz)
- 59 cm x 59 cm x 75.3 cm
- 76 kg
- Environmental Standards
- ENERGY STAR Qualified
- Laser - colour
- Display Diagonal Size
- 4.3"
- Display Colour Support
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Standard Memory
- 1.5 GB
- Max Supported Memory
- 3 GB
- Supported Flash Memory
- SD Memory Card
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Exposure Control
- Automatic, manual
- Exposure Modes
- Text, photo, text and photo, map
- Copying Features
- ID Card Copy, blank page skipping, electronic sorting, Scan-once-copy-many
Printing
- Printer Drivers / Emulations
- PCL 6, PCL 5c, KPDL3, PCL 6 (XL), PDF, XPS, PRESCRIBE IIc
- First Print Out Time B/W
- 7.5 sec
- First Print Out Time Colour
- 10.2 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- Min Media Size
- 98 x 148 mm
- Max Media Size
- A3/Ledger
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 256 g/m²
- Media Thickness Range
- Up to 0.11 mm
- Supported Media Type
- Plain paper
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), Folio (216 x 330 mm), 297 x 432 mm, 98 x 148 mm
- 100 sheets
- 1600 sheets
- 280 sheets
- Input tray - 250 sheets size: 98 x 148 mm - A3/Ledger (297 x 432 mm) weight: 60 g/m² - 256 g/m²
- Speed Details
- Printing: up to 24 ppm (A4) - B/W , Printing: up to 24 ppm (A4) - colour , Copying: up to 24 ppm (A4) - B/W , Copying: up to 24 ppm (A4) - colour , Printing: up to 12 ppm (A3) - B/W , Printing: up to 12 ppm (A3) - colour , Copying: up to 12 ppm (A3) - B/W , Copying: up to 12 ppm (A3) - colour , Printing: up to 22 ppm (A4) - B/W duplex , Printing: up to 22 ppm (A4) - colour duplex , Scanning: up to 50 ipm (A4) - B/W , Scanning: up to 50 ipm (A4) - colour
- 1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- SSL, IPsec
- Operating System Support
- UNIX, Linux, Apple Mac OS X 10.5 or later, MS Windows
- Voltage Required
- 550 Watt
- Power Consumption Sleep
- 0.5 Watt
- Warm-Up Time
- 30 sec
- First Copy Out Time B/W
- 8.5 sec
- First Copy Out Time Colour
- 11 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 3000 pages , 1 x toner cartridge (cyan) - up to 1500 pages , 1 x toner cartridge (magenta) - up to 1500 pages , 1 x toner cartridge (yellow) - up to 1500 pages
- TUV GS, ISO 9001, ISO 14001, ISO 7779, ISO 9296
- ENERGY STAR Certified
- 59 cm
- 59 cm
- 75.3 cm
- 76 kg
- Sound Emission
- 34 dBA (idle) / 53 dBA (operating)
Ink (4)
Kyocera TK 8115C Cyan Toner Kit for ECOSYS M8124cidn & ECOSYS M8130cidn | In Stock | £56.22 |
Kyocera TK 8115K Black Toner Kit for ECOSYS M8124cidn & ECOSYS M8130cidn | In Stock | £61.38 |
Kyocera TK 8115M Magenta Toner Kit for ECOSYS M8124cidn & ECOSYS M8130cidn | In Stock | £56.10 |
Kyocera TK 8115Y Yellow Toner Kit for M8124cidn & ECOSYS M8130cidn | In Stock | £56.10 |
Other bundles (1)
Kyocera pf-470 500 Sheet Drawer | In Stock | £377.67 |
