Kyocera ECOSYS M8124cidn Colour Laser Multifunction Printer
Quicklinx: DD7WWS00 Mfr#: 1102P43NL0
£2,729.01 ex VAT
£3,274.81 inc VAT
This compact, A4/A3 format colour multifunctional, designed to meet the requirements of small offices and workgroups, will satisfy even the most demanding environment. Engineered with KYOCERA's renowned longlife components, this ECOSYS device ensures unprecedented reliability and exceptionally low printing costs with significantly less environmental impact.
  • Efficient connectivity
    With a suite of connectivity options including Gigabit Ethernet, USB 2.0, and USB host, alongside mobile printing capabilities through Apple AirPrint, Google Cloud Print 2.0, and Mopria Print Service, this device ensures seamless integration into any workflow.
  • Advanced security
    Equipped with robust security protocols such as IPsec and SSL, the Kyocera ECOSYS M8124cidn safeguards sensitive information, ensuring peace of mind for users.
  • High-quality copying
    Features like automatic duplexing, ID Card Copy, and scan-once-copy-many, combined with a max copying resolution of 600 x 600 DPI for both black and white and color, enhance productivity while maintaining clarity.
  • Versatile media handling
    Supports a wide range of media sizes and types, accommodating everything from plain paper to thicker media up to 256 g/m2, making it ideal for diverse printing needs.
  • Eco-friendly design
    ENERGY STAR certified, the Kyocera ECOSYS M8124cidn is designed for efficiency, with a sound emission as low as 34 dBA in idle mode, contributing to a quieter, more sustainable work environment.
Kyocera ECOSYS M8124cidn - multifunction printer - colour
Multifunction printer
Printing Technology
Laser (colour)
Max Copying Speed
Up to 24 ppm (mono) / up to 24 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
Scanning
600 x 600 dpi
Display
4.3"
Original Size
A3/Ledger (297 x 432 mm) (max)
Original Type
Sheets
Media Size
98 x 148 mm (min) - A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm) (max)
Media Type
Plain paper
Standard Media Capacity
100 sheets
Max Media Capacity
1600 sheets
Output Trays Capacity
280 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
Office Machine Features
Scan to e-mail, scan to network, HyPAS (Hybrid Platform for Advanced Solutions), scan to FTP, scan to SMB, scan to USB host
AC 230 V (50/60Hz)
59 cm x 59 cm x 75.3 cm
76 kg
Environmental Standards
ENERGY STAR Qualified
Printing Technology
Laser - colour
Display Diagonal Size
4.3"
Display Colour Support
Display Features
Touch screen
AirPrint Enabled
Standard Memory
1.5 GB
Max Supported Memory
3 GB
Supported Flash Memory
SD Memory Card
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Exposure Control
Automatic, manual
Exposure Modes
Text, photo, text and photo, map
Automatic Duplexing
Copying Features
ID Card Copy, blank page skipping, electronic sorting, Scan-once-copy-many
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PCL 5c, KPDL3, PCL 6 (XL), PDF, XPS, PRESCRIBE IIc
Automatic Duplexing
First Print Out Time B/W
7.5 sec
First Print Out Time Colour
10.2 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Document & Media Handling
Max Original Size
Original Type
Sheets
Min Media Size
98 x 148 mm
Max Media Size
A3/Ledger
Min Media Weight
60 g/m²
Max Media Weight
256 g/m²
Media Thickness Range
Up to 0.11 mm
Supported Media Type
Plain paper
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), Folio (216 x 330 mm), 297 x 432 mm, 98 x 148 mm
100 sheets
Max Media Capacity
1600 sheets
280 sheets
Input tray - 250 sheets size: 98 x 148 mm - A3/Ledger (297 x 432 mm) weight: 60 g/m² - 256 g/m²
Speed Details
Printing: up to 24 ppm (A4) - B/W , Printing: up to 24 ppm (A4) - colour , Copying: up to 24 ppm (A4) - B/W , Copying: up to 24 ppm (A4) - colour , Printing: up to 12 ppm (A3) - B/W , Printing: up to 12 ppm (A3) - colour , Copying: up to 12 ppm (A3) - B/W , Copying: up to 12 ppm (A3) - colour , Printing: up to 22 ppm (A4) - B/W duplex , Printing: up to 22 ppm (A4) - colour duplex , Scanning: up to 50 ipm (A4) - B/W , Scanning: up to 50 ipm (A4) - colour
1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
SSL, IPsec
Operating System Support
UNIX, Linux, Apple Mac OS X 10.5 or later, MS Windows
AC 230 V (50/60Hz)
550 Watt
Power Consumption Sleep
0.5 Watt
Warm-Up Time
30 sec
First Copy Out Time B/W
8.5 sec
First Copy Out Time Colour
11 sec
Consumables Included
1 x toner cartridge (black) - up to 3000 pages , 1 x toner cartridge (cyan) - up to 1500 pages , 1 x toner cartridge (magenta) - up to 1500 pages , 1 x toner cartridge (yellow) - up to 1500 pages
TUV GS, ISO 9001, ISO 14001, ISO 7779, ISO 9296
ENERGY STAR Certified
59 cm
59 cm
75.3 cm
76 kg
Sound Emission
34 dBA (idle) / 53 dBA (operating)
Ink (4)
DD7W Kyocera TK 8115C Cyan Toner Kit for ECOSYS M8124cidn & ECOSYS M8130cidn In Stock £54.14
DD7W Kyocera TK 8115K Black Toner Kit for ECOSYS M8124cidn & ECOSYS M8130cidn In Stock £63.99
DD7W Kyocera TK 8115M Magenta Toner Kit for ECOSYS M8124cidn & ECOSYS M8130cidn In Stock £54.14
DD7W Kyocera TK 8115Y Yellow Toner Kit for M8124cidn & ECOSYS M8130cidn In Stock £54.14
Other bundles (1)
DD7W Kyocera pf-470 500 Sheet Drawer In Stock £399.65
Type: Printer / copier / scanner
Functionality: Copier
Functionality: Printer
Functionality: Scanner
Max Paper Size: A3 (297 x 420 mm)
Max Paper Size: ANSI B (Ledger) (279 x 432 mm)
Brand: Kyocera
Price Range Ex VAT: £1500+
