Efficient connectivity
With options like Gigabit Ethernet, USB 2.0, and USB host, alongside mobile printing capabilities through Apple AirPrint and Google Cloud Print, this device ensures seamless integration into any work environment. -
Advanced copying features
The Kyocera ECOSYS M6635cidn enhances productivity with automatic duplexing, ID Card Copy, and electronic sorting, coupled with exposure controls for optimal copy quality. -
Intuitive display
A 7-inch touchscreen display offers easy navigation and control of the multifunction printer, making complex tasks simpler. -
Versatile media handling
Accommodates a wide range of media sizes and weights, from A6 to Legal and 60 g/m2 to 220 g/m2, ensuring flexibility in printing needs. -
Eco-friendly operation
ENERGY STAR certification signifies efficient power usage, while Kyocera's ECOSYS technology promotes long-life components and sustainability.
- Kyocera ECOSYS M6635cidn - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (colour)
- Max Copying Speed
- Up to 35 ppm (mono) / up to 35 ppm (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Data Compression System
- MH, MR, MMR, JBIG
- Fax Resolutions
- 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 400 x 400 dpi
- Scanning
- 600 x 600 dpi
- Display
- 7"
- Original Size
- Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 100 sheets
- Media Size
- 70 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Plain paper
- Standard Media Capacity
- 350 sheets
- Max Media Capacity
- 1850 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 250 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- AirPrint Enabled
- Office Machine Features
- Scan to e-mail, HyPAS (Hybrid Platform for Advanced Solutions), Kyocera ECOSYS Technology, scan to FTP, scan to SMB
- Power
- AC 230 V (50/60Hz)
- 48 cm x 57.7 cm x 61.95 cm
- 36.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- Fax Type
- Plain paper
- Laser - colour
- Display Diagonal Size
- 7"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Standard Memory
- 1 GB
- Max Supported Memory
- 3 GB
- Supported Flash Memory
- SD Memory Card, SDHC Memory Card
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Exposure Control
- Automatic, manual
- Exposure Modes
- Text, photo, text and photo, map
- Copying Features
- ID Card Copy, blank page skipping, electronic sorting, Scan-once-copy-many
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, KPDL3, PCL 6 (XL), XPS, PRESCRIBE IIc
- First Print Out Time B/W
- 7.5 sec
- First Print Out Time Colour
- 8.5 sec
- Colour Management Features
- Mopria
Scanning
- Optical Resolution
- 600 x 600 dpi
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- MH, MR, MMR, JBIG
- Fax Resolutions
- Reception Memory Capacity
- Up to 256 pages
Fax Machine Features
- One-Touch Dialing
- 200 station(s)
- Fax polling, Duplex Fax
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 100 sheets
- Min Media Size
- 70 x 148 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Plain paper
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), B6 (125 x 176 mm)
- 350 sheets
- 1850 sheets
- 100 sheets
- 250 sheets
- Input tray - 250 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 100 sheets size: 70 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , DSDF - 100 sheets size: 105 x 148 mm - Legal (216 x 356 mm) weight: 50 g/m² - 120 g/m² , Output tray - 250 sheets
- Speed Details
- Printing: up to 35 ppm (A4) - B/W , Printing: up to 35 ppm (A4) - colour , Copying: up to 35 ppm (A4) - B/W , Copying: up to 35 ppm (A4) - colour , Scanning: up to 62 ipm (A4) - B/W (300 dpi) , Scanning: up to 46 ipm (A4) - colour (300 dpi) , Printing: up to 17 ppm (A4) - duplex normal , Copying: up to 17 ppm (A4) - duplex normal
- 1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- SSL, IPsec
- Voltage Required
- 547 watt
- Power Consumption Standby
- 84 watt
- Power Consumption Sleep
- 0.6 watt
- Warm-Up Time
- 25 sec
- First Copy Out Time B/W
- 8.5 sec
- First Copy Out Time Colour
- 10 sec
- TUV, ISO 9001, GS, ISO 14001, ISO 7779, ISO 9296
- ENERGY STAR Certified
- 48 cm
- 57.7 cm
- 61.95 cm
- 36.5 kg
- Sound Emission
- 30 dBA (idle) / 52 dBA (operating)
