Kyocera ECOSYS M6630cidn Colour Laser Multifunction Printer
Quicklinx: F3MGWS00 Mfr#: 1102TZ3NL1
£771.27 ex VAT
£925.52 inc VAT
Marketing description is not available.
  • Efficient connectivity
    With features like Gigabit Ethernet, USB 2.0, and USB host, alongside mobile printing capabilities through Apple AirPrint and Google Cloud Print, this device ensures seamless integration into any work environment.
  • Advanced copying features
    The Kyocera ECOSYS M6630cidn enhances productivity with features like automatic duplexing, ID Card Copy, and electronic sorting, making it easier to manage documents efficiently.
  • Intuitive display
    A 7-inch touchscreen display offers easy navigation and control of the multifunction printer, ensuring a user-friendly experience.
  • Eco-friendly design
    ENERGY STAR certified, this printer meets strict energy efficiency guidelines, making it an environmentally responsible choice for any office.
  • High-quality printing and scanning
    With a maximum printing and scanning resolution of 1200 x 1200 DPI and automatic duplexing, the device delivers high-quality outputs efficiently.
Kyocera ECOSYS M6630cidn - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (colour)
Max Copying Speed
Up to 30 ppm (mono) / up to 30 ppm (colour)
Max Printing Speed
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG
Fax Resolutions
200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 400 x 400 dpi
Scanning
600 x 600 dpi
Display
7"
Original Size
Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
Original Type
Sheets
Document Feeder Capacity
75 sheets
Media Size
70 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper
Standard Media Capacity
350 sheets
Max Media Capacity
1850 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
250 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
Office Machine Features
Scan to e-mail, HyPAS (Hybrid Platform for Advanced Solutions), Kyocera ECOSYS Technology, scan to FTP, scan to SMB
AC 230 V (50/60Hz)
47.5 cm x 55.8 cm x 61.6 cm
35.4 kg
Environmental Standards
ENERGY STAR Qualified
Fax Type
Plain paper
Printing Technology
Laser - colour
Display Diagonal Size
7"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
1 GB
Max Supported Memory
3 GB
Supported Flash Memory
SD Memory Card, SDHC Memory Card
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Exposure Control
Automatic, manual
Exposure Modes
Text, photo, text and photo, map
Automatic Duplexing
Copying Features
ID Card Copy, blank page skipping, electronic sorting, Scan-once-copy-many
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, KPDL3, PCL 6 (XL), XPS, PRESCRIBE IIc
Automatic Duplexing
First Print Out Time B/W
6.5 sec
First Print Out Time Colour
7.5 sec
Colour Management Features
Mopria
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JBIG
Fax Resolutions
Reception Memory Capacity
Up to 256 pages
Fax Machine Features
One-Touch Dialing
200 station(s)
Fax polling, Duplex Fax
Document & Media Handling
Max Original Size
Original Type
Sheets
75 sheets
Min Media Size
70 x 148 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Plain paper
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), B6 (125 x 176 mm)
350 sheets
Max Media Capacity
1850 sheets
100 sheets
250 sheets
Input tray - 250 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 100 sheets size: 70 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , ADF - 75 sheets size: 105 x 148 mm - Legal (216 x 356 mm) weight: 50 g/m² - 120 g/m² , Output tray - 250 sheets
Speed Details
Printing: up to 30 ppm (A4) - B/W , Printing: up to 30 ppm (A4) - colour , Copying: up to 30 ppm (A4) - B/W , Copying: up to 30 ppm (A4) - colour , Scanning: up to 60 ipm (A4) - B/W (300 dpi) , Scanning: up to 40 ipm (A4) - colour (300 dpi) , Printing: up to 15 ppm (A4) - duplex normal , Copying: up to 15 ppm (A4) - duplex normal , Scanning: up to 26 ipm (A4) - B/W duplex (300 dpi) , Scanning: up to 17 ipm (A4) - colour duplex (300 dpi)
1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
SSL, IPsec
AC 230 V (50/60Hz)
496 Watt
Power Consumption Standby
70 Watt
Power Consumption Sleep
0.6 Watt
Warm-Up Time
26 sec
First Copy Out Time B/W
8.5 sec
First Copy Out Time Colour
10 sec
TUV, ISO 9001, GS, ISO 14001, ISO 7779, ISO 9296
ENERGY STAR Certified
47.5 cm
55.8 cm
61.6 cm
35.4 kg
Sound Emission
30 dBA (idle) / 49.5 dBA (operating)
F3MG Kyocera Black toner Cartridge for P6230CDN In Stock £90.77
Functionality: Printer
Functionality: Fax
Functionality: Scanner
Functionality: Copier
Max Paper Size: A4 (210 x 297 mm)
Brand: Kyocera
Price Range Ex VAT: £750 - £1000
