Efficient connectivity
With a range of connectivity options including Gigabit Ethernet, USB 2.0, and USB host, alongside mobile printing capabilities like Apple AirPrint and Google Cloud Print, this device ensures seamless integration into any work environment. -
Advanced copying features
Features automatic duplexing, ID Card Copy, and electronic sorting among other features, making it efficient for handling complex copying tasks. The inclusion of blank page skipping optimizes workflow and conserves resources. -
Intuitive display
Features a 7" touchscreen display that offers easy navigation and control of the multifunction printer's extensive functions, enhancing user experience. -
Versatile media handling
Accommodates a wide range of media sizes and types, with a maximum media capacity of 1850 sheets. This flexibility ensures the printer can handle diverse printing needs, from standard documents to more specialized media. -
Eco-friendly performance
ENERGY STAR certified, reflecting a commitment to environmental sustainability without compromising performance. Kyocera's ECOSYS Technology further enhances efficiency and longevity, reducing waste and operating costs.
- Kyocera ECOSYS M6235cidn - multifunction printer - colour
- Multifunction printer
- Printing Technology
- Laser (colour)
- Max Copying Speed
- Up to 35 ppm (mono) / up to 35 ppm (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
- Scanning
- 600 x 600 dpi
- Display
- 7"
- Original Size
- Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 100 sheets
- Media Size
- 70 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Plain paper
- Standard Media Capacity
- 350 sheets
- Max Media Capacity
- 1850 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 250 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- AirPrint Enabled
- Office Machine Features
- Scan to e-mail, HyPAS (Hybrid Platform for Advanced Solutions), Kyocera ECOSYS Technology, scan to FTP, scan to SMB
- Power
- AC 230 V (50/60Hz)
- 48 cm x 57.7 cm x 61.95 cm
- 36.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- Laser - colour
- Display Diagonal Size
- 7"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Standard Memory
- 1 GB
- Max Supported Memory
- 3 GB
- Supported Flash Memory
- SD Memory Card, SDHC Memory Card
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Exposure Control
- Automatic, manual
- Exposure Modes
- Text, photo, text and photo, map
- Copying Features
- ID Card Copy, blank page skipping, electronic sorting, Scan-once-copy-many
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, KPDL3, PCL 6 (XL), XPS, PRESCRIBE IIc
- First Print Out Time B/W
- 7.5 sec
- First Print Out Time Colour
- 8.5 sec
- Colour Management Features
- Mopria
Scanning
- Optical Resolution
- 600 x 600 dpi
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 100 sheets
- Min Media Size
- 70 x 148 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Plain paper
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), B6 (125 x 176 mm)
- 350 sheets
- 1850 sheets
- 100 sheets
- 250 sheets
- Input tray - 250 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 100 sheets size: 70 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , DSDF - 100 sheets size: 105 x 148 mm - Legal (216 x 356 mm) weight: 50 g/m² - 120 g/m² , Output tray - 250 sheets
- Speed Details
- Printing: up to 35 ppm (A4) - B/W , Printing: up to 35 ppm (A4) - colour , Copying: up to 35 ppm (A4) - B/W , Copying: up to 35 ppm (A4) - colour , Scanning: up to 62 ipm (A4) - B/W (300 dpi) , Scanning: up to 46 ipm (A4) - colour (300 dpi) , Printing: up to 17 ppm (A4) - duplex normal , Copying: up to 17 ppm (A4) - duplex normal
- 1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- SSL, IPsec
- Voltage Required
- 547 Watt
- Power Consumption Standby
- 84 Watt
- Power Consumption Sleep
- 0.6 Watt
- Warm-Up Time
- 25 sec
- First Copy Out Time B/W
- 8.5 sec
- First Copy Out Time Colour
- 10 sec
- TUV, ISO 9001, GS, ISO 14001, ISO 7779, ISO 9296
- ENERGY STAR Certified
- 48 cm
- 57.7 cm
- 61.95 cm
- 36.5 kg
- Sound Emission
- 30 dBA (idle) / 52 dBA (operating)
Kyocera TK-5280K Black Toner | In Stock | £147.68 |
Kyocera TK-5280C Cyan Toner | In Stock | £188.61 |
Kyocera TK-5280M Magenta Toner | In Stock | £163.42 |
Kyocera TK-5280Y Yellow Toner | In Stock | £188.61 |
