Kyocera ECOSYS M6230cidn Colour Laser Multifunction Printer
Quicklinx: FM54WS00 Mfr#: 1102TY3NL1
£599.03 ex VAT
£718.83 inc VAT
Marketing description is not available.
  • Efficient connectivity
    With options like Gigabit Ethernet, USB 2.0, and USB host, alongside mobile printing capabilities through Apple AirPrint and Google Cloud Print, this device ensures seamless integration into any work environment.
  • Advanced copying features
    The Kyocera ECOSYS M6230cidn boasts automatic duplexing, ID Card Copy, and electronic sorting among other features, making it efficient for handling complex copying tasks.
  • High-quality printing
    Achieve crisp, clear prints with a maximum resolution of 1200 x 1200 DPI for both black and white and color documents, ensuring high-quality outputs every time.
  • Robust document handling
    From its 75-sheet Automatic Document Feeder (ADF) to a maximum media capacity of 1850 sheets, this device is designed to support high-volume printing and copying tasks.
  • Eco-friendly technology
    Leveraging Kyocera's ECOSYS technology, this printer offers long-life components that reduce waste and provide a sustainable solution to your office's printing needs.
Kyocera ECOSYS M6230cidn - multifunction printer - colour
Multifunction printer
Printing Technology
Laser (colour)
Max Copying Speed
Up to 30 ppm (mono) / up to 30 ppm (colour)
Max Printing Speed
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
Scanning
600 x 600 dpi
Display
7"
Original Size
Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
Original Type
Sheets
Document Feeder Capacity
75 sheets
Media Size
70 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper
Standard Media Capacity
350 sheets
Max Media Capacity
1850 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
250 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
Office Machine Features
Scan to e-mail, HyPAS (Hybrid Platform for Advanced Solutions), Kyocera ECOSYS Technology, scan to FTP, scan to SMB
AC 230 V (50/60Hz)
47.5 cm x 55.8 cm x 61.6 cm
35.4 kg
Environmental Standards
ENERGY STAR Qualified
Printing Technology
Laser - colour
Display Diagonal Size
7"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
1 GB
Max Supported Memory
3 GB
Supported Flash Memory
SD Memory Card, SDHC Memory Card
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Exposure Control
Automatic, manual
Exposure Modes
Text, photo, text and photo, map
Automatic Duplexing
Copying Features
ID Card Copy, blank page skipping, electronic sorting, Scan-once-copy-many
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, KPDL3, PCL 6 (XL), XPS, PRESCRIBE IIc
Automatic Duplexing
First Print Out Time B/W
6.5 sec
First Print Out Time Colour
7.5 sec
Colour Management Features
Mopria
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Document & Media Handling
Max Original Size
Original Type
Sheets
75 sheets
Min Media Size
70 x 148 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Plain paper
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), B6 (125 x 176 mm)
350 sheets
Max Media Capacity
1850 sheets
100 sheets
250 sheets
Input tray - 250 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 100 sheets size: 70 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , ADF - 75 sheets size: 105 x 148 mm - Legal (216 x 356 mm) weight: 50 g/m² - 120 g/m² , Output tray - 250 sheets
Speed Details
Printing: up to 30 ppm (A4) - B/W , Printing: up to 30 ppm (A4) - colour , Copying: up to 30 ppm (A4) - B/W , Copying: up to 30 ppm (A4) - colour , Scanning: up to 60 ipm (A4) - B/W (300 dpi) , Scanning: up to 40 ipm (A4) - colour (300 dpi) , Printing: up to 15 ppm (A4) - duplex normal , Copying: up to 15 ppm (A4) - duplex normal , Scanning: up to 26 ipm (A4) - B/W duplex (300 dpi) , Scanning: up to 17 ipm (A4) - colour duplex (300 dpi)
1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
SSL, IPsec
AC 230 V (50/60Hz)
496 Watt
Power Consumption Standby
70 Watt
Power Consumption Sleep
0.6 Watt
Warm-Up Time
26 sec
First Copy Out Time B/W
8.5 sec
First Copy Out Time Colour
10 sec
TUV, ISO 9001, GS, ISO 14001, ISO 7779, ISO 9296
ENERGY STAR Certified
47.5 cm
55.8 cm
61.6 cm
35.4 kg
Sound Emission
30 dBA (idle) / 49.5 dBA (operating)
FM54 Kyocera Black toner Cartridge for P6230CDN In Stock £90.39
Type: Printer / copier / scanner
Functionality: Copier
Functionality: Printer
Functionality: Scanner
Max Paper Size: A4 (210 x 297 mm)
Brand: Kyocera
Price Range Ex VAT: £500 - £750
